mark.supinski(at)gmail.co Guest
Posted: Tue Mar 16, 2010 11:12 am Post subject: Z-19 question |
Hello all-
I have implemented Z-19 (dual battery, redundant main and engine
busses) for my bird. I would like to add the ability to easily hook
up a float trickle charger to the aircraft to keep both batteries
topped up while sitting in the hangar. Due to the design of Z-19,
however, I can't see a simple way to accomplish this that doesn't
result in the batteries being tied together in what would likely be an
undesireable way.
Is there a straight-forward way to do this? (without having to float
charge the batteries separately, thus requiring 2 chargers).
Mark
Sam
Posted: Tue Mar 16, 2010 1:29 pm Post subject: Z-19 question |
Mark,
Yes there is. Simply connect a 16 gauge wire to the positive terminals of each battery, and connected to a regular panel-type switch. When charging the batteries, simply flip the switch on and both will charge.
It's working well in my setup.
Sam
www.samhoskins.blogspot.com
On Mon, Mar 15, 2010 at 9:26 PM, Mark R. Supinski <mark.supinski(at)gmail.com (mark.supinski(at)gmail.com)> wrote:
[quote] --> AeroElectric-List message posted by: "Mark R. Supinski" <mark.supinski(at)gmail.com (mark.supinski(at)gmail.com)>
Hello all-
undesireable way.
Mark
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Dennis Glaeser
Joined: 10 Jan 2006 Posts: 53 Location: Rochester Hills, Michigan
Posted: Wed Mar 17, 2010 1:59 am Post subject: Z-19 question |
I have a cigarette lighter receptacle for each battery, fused off each
battery's hot bus, on my IP.
I made up a "Y" for my battery charger with lighter plugs, so when I want to
charge the batteries, I just plug it into the receptacle(s).
Dennis Glaeser
Hello all-
undesirable way.
Mark
