Vanremog(at)aol.com Guest
Posted: Sat Mar 13, 2010 10:34 pm Post subject: Slowing down the trim |
PWM circuit is the proper way to do this without lowering motor torque, not a voltage regulator. Van's has proven servo controllers.
-GV
In a message dated 3/13/2010 12:24:04 P.M. Pacific Standard Time, jimbean6(at)verizon.net writes:
| Quote: | Early in building my RV-8 I built and installed a 9 volt power supply intending to power the headsets with it.
Foolish boy, that doesn't work.
Since the 9 volts was already there I tried it on the trim motor, leaving the trim indicator supply at 14 volts.
Everything has been working fine with the trim just running slower, a good thing.
I realize that most people will not want to bother installing a separate 9 volt supply but it does work.
For those interested the shack 5 amp regulator has a schematic and parts list on the back of the package.
Contact me off-line for my trim schematic. |
