Thom Riddle
Posted: Sat Feb 27, 2010 12:20 pm Post subject: not Kolb related but fascinating |
If you don't want to see something NOT KOLB RELATED hit the delete key now.
BUT if you are not immune to the attraction of other things that fly, you might find this video worth your while. The audio is German but the important points are captioned in English.
http://vimeo.com/6194911
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Ralph B
Posted: Mon Mar 01, 2010 6:47 am Post subject: Re: not Kolb related but fascinating |
This is got to be one of the coolest things I've seen in a long time ...
(click on the link in Thom's post above)
Ralph
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours
russkinne(at)mac.com Guest
Posted: Mon Mar 01, 2010 7:03 am Post subject: not Kolb related but fascinating |
What is? No image or link came thru
On Mar 1, 2010, at 9:47 AM, Ralph B wrote:
time ...
Ralph
Ralph B
Original Firestar 447
N91493 E-AB
1000 hours
23 years flying it
Kolbra 912UL
N20386
2 years flying it
120 hrs
http://forums.matronics.com/viewtopic.php?p=288730#288730
Thom Riddle
Posted: Mon Mar 01, 2010 7:10 am Post subject: Re: not Kolb related but fascinating |
Russ,
This....
Buffalo, NY (9G0)
- Anonymous
Posted: Mon Mar 01, 2010 7:17 am Post subject: not Kolb related but fascinating |
Yeah, Ralph, that's what I thought, too. Thom says you may be able to buy a kit from the guy that built it. I wouldn't think it is very cheap, though. But, still.....it is a nice toy, and we all need more toys!!
Kolb guys in general,
I have a question regarding flaps on a MkIII. For those of you with flaps on your plane, you know I'm reinstalling my wings, tailfeathers, etc, now that the Poly Fiber/paint is finished.
I just got the flaps and ailerons rehung this last weekend. I notived that if you stand behind the flap(s), you can get a fair amount of "reflex" by pushing them up. I assume that with a load on the wings, the flaps will flex upward, unless you preset them slightly lower.
So, here's my question for you guys that have flaps on your Kolb planes; are your flaps adjusted slightly low, to account for upward flexing, or do you not worry about it, and just set them flat with the underside of the wing, even though they will flex up while in flight?
Thanks, Mike Welch
Hotmail: Powerful Free email with security by Microsoft. Get it now. [quote][b]
Posted: Mon Mar 01, 2010 7:38 am Post subject: not Kolb related but fascinating |
Just the opposite, Mike W.
Air coming over the top of the wing pushes down on the flaps when they are in the neutral position. If you kick the flap handle out of the detent, while in flight, the flaps will fly about half way between neutral and 20% (middle flap position), maybe less.
john hauck
[quote] I assume that with a load on the wings, the flaps will flex upward, unless you preset them slightly lower.
Thanks, Mike Welch
_________________ John Hauck
Titus, Alabama |
clrprop
Posted: Mon Mar 01, 2010 7:46 am Post subject: Re: not Kolb related but fascinating |
re: the hexacopter
A friend in my rc club has met the guy and says it costs $1800.00
p.s. The scale model of my MarkIII is almost finished.
Keath T
S.C.
brett(at)xtc-paragliding. Guest
Posted: Mon Mar 01, 2010 9:58 am Post subject: not Kolb related but fascinating |
You are going to have to explain that to me. I understood we had high pressure 'under' the wing and low 'above' the wing, so I can't see how the flaps would be pushed down. I can understand staying neutral with the airflow or the weight of the flap pulling it down as they have no balance weight, but not being pushed down by the airflow surely???
Brett
MkIIIc
On 01/03/2010 16:31, John Hauck wrote: [quote] .hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-TOP: 0px } BODY.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Verdana } Just the opposite, Mike W.
john hauck
Posted: Mon Mar 01, 2010 10:51 am Post subject: not Kolb related but fascinating |
Have no explanation other than that is the way it is.
john hauck
[quote] You are going to have to explain that to me. I understood we had high pressure 'under' the wing and low 'above' the wing, so I can't see how the flaps would be pushed down. I can understand staying neutral with the airflow or the weight of the flap pulling it down as they have no balance weight, but not being pushed down by the airflow surely???
Brett
MkIIIc
| Quote: | .hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; MARGIN: 0px; PADDING-TOP: 0px } BODY.hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Verdana } Just the opposite, Mike W.
john hauck
| [b]
Titus, Alabama |
rmurrill(at)cox.net Guest
Kutta condition from many may years ago in my Aero 1 class claimed...Pressure distribution on most conventional camber airfoils actually is downward near the trailing edge at positive angles of attack. Would expect to free float downwards a few degrees even without the weight moment best I can remember...
Posted: Mon Mar 01, 2010 10:55 am Post subject: not Kolb related but fascinating |
Thanx Thom
On Mar 1, 2010, at 10:10 AM, Thom Riddle wrote:
Posted: Mon Mar 01, 2010 11:44 am Post subject: not Kolb related but fascinating |
If you can find one of those computer-generated color charts showing
pressure distribution over an a/c, you'll see what John describes. If
you can find a Thorp T-18 driver, you can see it in action. The canopy
on a low wing plane is an airfoil, too. The fresh air *intake* on a
Thorp is at the lower back edge of the sliding canopy. The breeze coming
forward is so strong, it will part the hair on the back of your head.
On 3/1/2010 12:50 PM, Bob wrote:
[quote] Kutta condition from many may years ago in my Aero 1 class
