Z-12, Z-13
RV7ASask
PostPosted: Sun Feb 28, 2010 10:28 am    Post subject: Z-12, Z-13 Reply with quote
Early on I decided to go with the Z-12 architecture but as my wiring came together I became more uncomfortable with it as I am going to be running dual Lightspeeds.
The question kept coming up where should I wire the second ignition? The first one is directly on the Hot battery bus lead, i.e. straight to the battery. The second was planned on the E-Bus?
Still not happy, I then decided to review the whole architecture and to change to Z-13/8. This has not been a big change other than I am running a B&C 20A Aux alternator.
The system is pretty well done and I do not have a relay in place for the E-Bus Alternate feed.
I still have the 1-3 switch in place as per the Z-12 and have not added a fuselink to the E-Bus Alternate feed.
Do I need a relay? If so why? Do I need a fuse link when the alternate feed has a 7A fuse off the Bat Bus? Do I need a fuselink between the Aux Feed Current Limiter and the Bat Contactor?
David Lamb
RV7A Still wiring
PostPosted: Sun Feb 28, 2010 11:46 am    Post subject: Z-12, Z-13 Reply with quote
Or the main bus. Keep in mind that your engine runs perfectly
well on one electronic ignition. During battery only ops, I'd
turn one ignition off to reduce battery loads. In the event
of a VERY rare, dual failure (lost #1 ignition too) then you
can still close the battery contactor and deal with what is
now a more critical situation than the original plan-b.
That relay is only suggested for e-bus loads larger than
7A. But if you have a 20A s/b alternator, suggest you
go with Z-12, put the #1 ignition on the battery bus,
#2 ignition on the main bus. Odds are that you'll never
have to configure for e-bus only ops.
Protecting the alternate feed wire is recommended whether
you have the relay or not. The only decision is to size that
protection commensurate with e-bus, battery only loads.
Suggest you research the e-bus feeder discussions
in Appendix Z notes and in the matronics archives.
Suggest also that you publish your power distribution
diagram that speaks to features of the /8 upsizing to
20A.
