Question for Europa reed switch fuel sender
rparigoris
PostPosted: Tue Feb 23, 2010 9:50 pm    Post subject: Question for Europa reed switch fuel sender Reply with quote
Hi group
When equipped with a factory reed switch style fuel sender installed on the port side of the tank (main), if you were to run on starboard tank (reserve) heading for exhaustion, at what indication on the fuel gauge would the needle stop going down because sender is still floating on the fuel trapped below the tunnel hump on the port side.
Thx.
Ron Parigoris
