bill_dom(at)yahoo.com Guest
Posted: Sat Apr 15, 2006 5:03 am Post subject: Bending Brake Welding Question |
I bought Zenith bending brake plans and I have all the
parts ready for welding. The end plates are 1/8 inch
thick and need to be welded to the end of 4 x 4
angular that are 1/4 of an inch thick. Both material
are steel. My questions are:
- The manual recommends arc welding to avoid heat
distortion. Is there any way that can be gas welded
with no heat distortion?
- If I gas weld, should I use a tip for 1/8 or a tip
for 1/4
- What would be the most economical arc welder for
this job? The cheapest ones welds up to 3/16 in a
single pass, what does this mean? Will it weld thicker
by multi passing?
- Any other recommendation.
I have no welding experience but I want to learn and I
have enough scrap metal to practice. I also have
Richard Finchs Welder Handbook.
William Dominguez
Plansbuilt Zodiac 601XL
Working on bending brake
jean-paul.roy4(at)tlb.sym Guest
Posted: Sat Apr 15, 2006 5:40 am Post subject: Bending Brake Welding Question |
Hi William. Would you have a link to direct me for buying these plans.
Jean-Paul
d.goddard(at)ns.sympatico Guest
Posted: Sat Apr 15, 2006 5:46 am Post subject: Bending Brake Welding Question |
Posted: Sat Apr 15, 2006 6:16 am Post subject: Bending Brake Welding Question |
I ordered them by phone however, it is the same design
as this one:
http://www.ch601.org/tools/sm_brake_1.pdf
http://www.ch601.org/tools/sm_brake_2.pdf
Zenith plans are more detailed and for 20 bucks it is
worth it.
William Dominguez
--- Jean-Paul Roy <jean-paul.roy4(at)tlb.sympatico.ca>
buying these plans.
Jean-Paul
naumuk(at)alltel.net Guest
Posted: Sat Apr 15, 2006 7:02 am Post subject: Bending Brake Welding Question |
Bill-
I've used a Lincoln stick welder of one model or another for over 35
years. Just what I'm familiar with, I suppose. Best if you have access to
240V. You can get a dual steel/aluminum model for around $300 US if you
watch for the sales. Problem is, gold is cheaper than the aluminum rods.
When I was a teenager, I welded the roll cage for a stock car where the
driver caught a T bone right at him. The well case bent as much as 6", but
the welds never broke. I had maybe 75 hours experience with the welder at
that point. Suppose you could say you don't have to worry whether the welder
was capable. Not me, the machine!
Bill
do not
archive
William,
The larger tip would be the better tool for the material as it will
spread the heat better and allow
you to focus on the weld more easily if you decide to gas weld. Trying
to weld with a lesser tip would
require you slow down and spend too much time getting the metal to a
puddle for welding. Arc welding
is so fast that an arc of short segments can be made with very little or
no distortion. Study the shrinkage
that causes distortion and you'll be able to compensate for it.
Welders are best described by their amperage, duty cycle and capacity
for AC or DC. A 125 amp
welder capable of AC or DC and able to switch select straight or reverse
polarity should be a minimum
requirement. You should find these at Harbor Freight for less than
$250. Even a used welder can be a good buy.
Ask for a Miller plastic slide guide that describes amp settings,
polarity and rod size for
most welding jobs. It will get you on centerline faster than a book. Do
study Richards book though, because it is an excellent
reference for aircraft and regular welding.
Good luck,
Larry McFarland
William Dominguez wrote:
for 1/4
by multi passing?
William Dominguez
TH-SR
Posted: Sat Apr 15, 2006 7:08 am Post subject: Bending Brake Welding Question |
Attn: Mark Townsend
I'm sure many posts to the list, from those that have viewed the Homebuilt
Help Video, are looking for plans to the bender you have constructed (as
shown in the video). Are yours plans available to us scratch-builders?
Todd Henning
_________________ Todd
CH701 |
Posted: Sat Apr 15, 2006 8:27 am Post subject: Bending Brake Welding Question |
I think arc welding in all forms is potentially much more dangerous
than gas welding. The energy developed in the arc can produce all
sorts of damage to humans from sunburn to radiation poisoning to
blindness. Gas welding has none of these risks associated with it -
but you certainly can get your fingers burned.
I learned gas welding from a book many years ago and have used it
from time to time. I don't think there are any size limits to the
process - just limits brought on by the size of the acetylene tank
you have. There are also no real limits in the processes you can do
including welding, brazing, cutting, and other useful things.
To prevent warping in heavy steel like you described, all you really
need to do is tack weld the corners and perhaps a couple of places in
the middle of the joint and then fill in the bead for the length of
the joint. The tack welds will hold the pieces in place and prevent bending.
Good luck,
Paul
XL wings
| Quote: | - The manual recommends arc welding to avoid heat
zodierocket(at)hsfx.ca Guest
Posted: Sat Apr 15, 2006 2:19 pm Post subject: Bending Brake Welding Question |
Hi Todd and others, I designed my brake from the ground up for the sole
use of building the Zodiac and Sky Jeep in mind, using simple materials
and a cheap cost. In that, the brake works like a charm, but my hand
scribbling to work out the math necessary to get the brake to work well
is a mess, I did not even use a ruler. I do not own AutoCAD software nor
do I know how to use such software, I am just a plane builder. So
several months ago a fellow visiting my shop asked to take measured
drawings of the brake and has offered to send me the finished drawings
that were mentioned in the DVD from Homebuilthelp.com. To date I still
have not seen those drawings, he is still promising them to me and he is
a trustworthy type of person, after all he is building a Zenith!
Therefore, as soon as I have them (and he will also get this post) I
will add them to the website. I hope that it will be sooner then later!
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701 just started
www.ch601.org / www.ch701.com / www.Osprey2.com
