cox.ken(at)gmail.com Guest
Posted: Sun Feb 07, 2010 6:46 am Post subject: Autopilot |
I am just getting started on a 7 empennage and would like to know if I
need to be aware of any special planning if I will be installing an
autopilot? I have no idea of how and where the autopilot servos are
installed? Any help from the more experienced would be much
appreciated.
KC
c-817.832.3711
"You had better live every day like it's your last day 'cause one day
you're going to be right."
-Ray Charles
Posted: Sun Feb 07, 2010 7:06 am Post subject: Autopilot |
Ken,
There is nothing special you need to do on the empennage to prepare for an
autopilot. Some point during wing construction is a good time to start that
process and at least lay the groundwork. It is easier to install your roll
servo in the wing before the wing is closed, but even if you defer that
choice, you can retrofit a servo into the wing or fuse later, but with a
higher degree of difficulty.
Kyle Boatright
2001 RV-6
flylists(at)dbarrett.net Guest
Posted: Sun Feb 07, 2010 7:38 am Post subject: Autopilot |
KC -
I think you'll find the TruTrak pitch servo installation typical of all the
autopilots that you'll be considering. Here's a link that showing that
installation:
http://www.trutrakflightsystems.com/documents/RV-679PitchInstall.pdf It's
just aft of the F-706 (baggage) bulkhead. You won't get to that until
you're working on the fuselage kit.
Build on!
David Barrett
RV-7 fuselage
ralphmariafinch(at)gmail. Guest
Posted: Sun Feb 07, 2010 9:16 am Post subject: Autopilot |
Not the autopilot, but the trim, concerns the empennage. Electric or manual
elevator trim is different there.
Ralph Finch
Davis, California
RV-9A QB-SA
appreciated.
KC
c-817.832.3711
__________ Information from ESET Smart Security, version of virus signature
database 4844 (20100207) __________
The message was checked by ESET Smart Security.
dan.pat.b(at)gmail.com Guest
Posted: Sun Feb 07, 2010 10:44 am Post subject: Autopilot |
KC: IN THE RV-7 THE AUTOPILOT ELEVATOR SERVO MOUNTS BEHIND THE ELEVATOR BELLCRANK ASSEMBLY BACK BEHIND THE BAGGAGE COMPARTMENT AND CONNECTS TO THE BELLCRANK VIA A SHORT PUSH/PULL ROD. IT LITERALLY MOVES THE ELEVATOR PUSH ROD BACK AND FORTH - THEREBY MOVING THE ELEVATOR UP/DOWN. THERE IS NOTHING YOU NEED TO BE CONCERNED ABOUT OR MAKE PROVISIONS FOR WHILE ASSEMBLING THE TAIL COMPONENENTS. YOU'VE PROBABLY BEEN THINKING ABOUT THE ELEVATOR TRIM TAB AND MAYBE THE TRIM TAB IS MOVED BY THE AUTO PILOT. THAT IS NOT THE CASE.
DAN BERGERON
RV-7A, N307TB
98 HOURS SINCE FIRST FLIGHT ON 8/4/09
On Sun, Feb 7, 2010 at 12:09 PM, Ralph & Maria Finch <ralphmariafinch(at)gmail.com (ralphmariafinch(at)gmail.com)> wrote:
[quote]--> RV-List message posted by: "Ralph & Maria Finch" <ralphmariafinch(at)gmail.com (ralphmariafinch(at)gmail.com)>
Ralph Finch
Davis, California
RV-9A QB-SA
--> RV-List message posted by: Ken Cox <cox.ken(at)gmail.com (cox.ken(at)gmail.com)>
appreciated.
KC
c-817.832.3711
get="_blank">http://www.matronics.com/Navigator?RV-List
http://forums.matronics.com
le, List Admin.
swayze(at)europa.com Guest
Posted: Mon Feb 08, 2010 11:20 am Post subject: Autopilot |
Ken,
I installed TruTrak servo brackets in my RV-7A while building.
There's nothing to worry about with the empennage. One servo goes in
the wings and the other one in the fuselage, as others have pointed
out. So there's nothing to worry about until you're about finished
with your wings. One aileron bellcrank bracket is replaced with the
one designed to hold the servo in the wing. You can see how I did it here:
http://www.europa.com/~swayze/RV-7A/Wings/20080908.html
And here's how I installed the bracket for the pitch servo in the fuselage:
http://www.europa.com/~swayze/RV-7A/Fuselage/20090620.html
Good luck with your project.
Bruce Swayze
At 06:40 AM 2/7/2010, you wrote:
appreciated.
KC
c-817.832.3711
