MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Wed Apr 12, 2006 3:19 pm Post subject: adj. hinges |
Howdy all
Someone out ther has pictures of his adjustable stabilizer hinges on a Mk3EX. Could it be the preacher? I don't remember his name or web site.
Mk3EX
Maine
_________________ MKIIIX040
912UL |
rlaird
Posted: Wed Apr 12, 2006 7:28 pm Post subject: adj. hinges |
At 06:18 PM 4/12/2006, you wrote:
Quote: |
Howdy all
This what you mean? (I took it off and painted it right after this photo
was taken.)
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
rlaird
Posted: Wed Apr 12, 2006 7:45 pm Post subject: Re: adj. hinges |
Sorry, here's the photo....
Description: |
Filesize: |
70.63 KB |
Viewed: |
465 Time(s) |
Robert Laird
Houston, TX area
MKIIIX040
Posted: Thu Apr 13, 2006 5:48 am Post subject: adj. hinges |
Thanks Robert that pic may come in handy as I also need to raise the
trailing edge of my right wing. (seems a little too common)
I'm actually looking for adjustable horizontal stabilizer hinges.
Vic MKIIIX 912
Maine
912UL |
Richard Pike
Posted: Thu Apr 13, 2006 7:52 am Post subject: adj. hinges |
Here is how we did it. You could add a couple extra holes to the
brackets and see which worked best.
http://www.bcchapel.org/pages/0003/FSIIelevatorbracket.html
Richard Pike
MKIII N420P (420ldPoops)
Vic MKIIIX 912
Maine
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
Posted: Thu Apr 13, 2006 8:15 am Post subject: adj. hinges |
Richard P/Gang:
Got a lot riding on that Tractor Supply steel strap. Could be as
strong as 4130. Maybe not.
I would go with 4130 on an airplane, especially in a critical area
like the horizontal stabilizers.
My thoughts for what they are worth. What you paid for them.
"Nothing fancy, got a length of .080 x 3/4" steel strap from Tractor
Supply, cut out four brackets, and drilled three 3/16" holes in each
bracket."
MKIII
_________________ John Hauck
Titus, Alabama |
Eugene Zimmerman
Posted: Thu Apr 13, 2006 9:00 am Post subject: adj. hinges |
John,
Did you see the bracket?
Those original stainless brackets on the horizontal stabilizer will
fail long before preacher Pike's tractor supply straps ever do.
On Apr 13, 2006, at 12:15 PM, John Hauck wrote:
Quote: |
Richard P/Gang:
bracket."
MKIII
Posted: Thu Apr 13, 2006 9:43 am Post subject: adj. hinges |
Gene/Gang:
Yes I did see them.
No, I do not have them installed on my MKIII.
Don't think anyone has heard me rave about the durability of the SS
brackets that Old Kolb began using many years ago.
Yes, there have been some failures of the SS brackets, one relatively
recently.
I still stand by my own standards of not using unknown steel on an
airplane, especially on a critical area. That piece of TSC steel
strap my last forever, or maybe a day. I don't know and am not
willing to bet my ass on it.
Take care,
MKIII
Titus, Alabama |
Posted: Thu Apr 13, 2006 9:52 am Post subject: adj. hinges |
will
I might add, SS is far less fatigue resistant that carbon steel.
MKIII
Titus, Alabama |
Eugene Zimmerman
Posted: Thu Apr 13, 2006 10:19 am Post subject: adj. hinges |
On Apr 13, 2006, at 1:53 PM, John Hauck wrote:
Quote: | I might add, SS is far less fatigue resistant that carbon steel.
MKIII
Yup, I'd like to see kolb come up with a better solution for this
vulnerable part.
It may be adequate for flight loads but I know from experience that
that part gets a real workout at times when ground handling the plane.
It is so easy to grab on to the LE of one horizontal stab at that point.
Gene
MKIIIX040
Posted: Thu Apr 13, 2006 11:31 am Post subject: adj. hinges |
Thanks Richard ,gives me ideas at the very least.
Maybe I should run a length of cable around the boom tube an through both
stabilizers just incase. lol
Vic
MKIIIEX 040
912 spacerless Damn it $$$$ never ends
912UL |
Richard Pike
Posted: Thu Apr 13, 2006 12:58 pm Post subject: adj. hinges |
No way it is as strong as 4130. That's why it is eighty thousandths. Per
bracket.
Two per side. To hold two 1/16" thick stainless tangs that are stressed
in twist.
The stress point in that whole assembly is where the tangs are riveted
to the stab.
Which is made out of .049 aluminum tubing. Which is stressed in twist
against the rivet.
Yet you are correct, 4130 would have been more "airplaney,"
but with the original Piper J-3's, J-4's, and J-5's being built out of
1020 mild steel,
and still doing fine today, I doubt I'll lose any sleep worrying about a
couple 3"
long mild steel long brackets that are .080 thick, with the load running
favorably to the bracket.
Does that mean that we can use mild steel just anywhere and get away
with it?
Certainly not. And now that this has come up, I will go back and modify
the web page,
deleting the reference to Tractor Supply so as not to encourage bad habits.
No way would I want to encourage anybody to do anything unsafe.
But I don't plan to change out the present brackets...
Richard Pike
John Hauck wrote:
Quote: |
Richard P/Gang:
bracket."
MKIII
Kingsport, TN 3TN0
