bakerocb
Posted: Sun Jan 17, 2010 6:12 am Post subject: Encoder Certification |
1/17/2009
Hello Steve Thomas, You wrote:
1) "Can I fly somewhere else to get it done once I have flown off my hours?"
Here is what 14 CFR says:
"91.215 ATC transponder and altitude reporting equipment and use.
(d) ATC authorized deviations. Requests for ATC authorized deviations must
be made to the ATC facility having jurisdiction over the concerned airspace
within the time periods specified as follows:
(2) For operation of an aircraft with an inoperative transponder to the
airport of ultimate destination, including any intermediate stops, or to
proceed to a place where suitable repairs can be made or both, the request
may be made at any time."
So you see that it is possible to fly your airplane without an operating
transponder where one is required if you obtain ATC permission to do so. Why
not do some research to:
A) Determine how amenable your local ATC coverage people are to letting you
make a one time flight without a transponder IAW 91.215 (d) (2) above.
B) Find a facility that will do your transponder cert and design your flight
test area to include that facility. Then make your request to ATC and on a
flight subsequent to your first flight fly to that location to have the
certification done. (I recommend that the first test flight be just a 20-30
minute orbit over the originating field.)
It would not be reasonable to expect permission to perform the entire Phase
one testing without a transponder unless you were able to do the testing in
airspace that did not require a transponder.
2) "Do I need a transponder cert for my DAR inspection?"
The regulations do not require this -- see 91.215 (d) (2). But a DAR, or FAA
inspector, has wide discretion and the power of the FAA Administrator in
that original airworthiness inspection and he may choose to require one.
If you have not already established some contact and level of rapport with
your prospective inspector you should start now -- and ask him that
question. An FAA inspector would be my first choice. How are you doing with
the program letter and all of the other paperwork required?
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 10:04:13 AM PST US
Subject: AeroElectric-List: Encoder Certification
A message to Stan Sutterfield:
You wrote last June:
| Quote: | This may not be the ideal forum for asking this question, but I'll try
it
| Quote: | anyway.
I want to certify my RV-8 for IFR flight. I know the FARs - I've
looked at
| Quote: | them.
I have the Blue Mountain EFIS One as primary instrumentation.
I have the Blue Mountain EFIS Lite as a backup.
Both EFISs are on different electrical busses - the main and the
standby.
| Quote: | -
which can be tied together, if needed.
I asked a local avionics guy about doing a pitot-static and
transponder
check for IFR. He said I would have to install a separate altimeter
and
encoder in order to get IFR certification. The EFIS has a built-in
encod
| Quote: | er.
Has anyone else encountered this obstacle?
Stan Sutterfield
There were several replies that mostly focused on finding the right
avionics guy. I have the exact same setup in my panel as do you and am
ready for certification. Can you share your experience? Are you
certified and flying? Who did you use for your certification and how
did you go about getting it?
I am in Southern California, and anyone else who can offer any advice on
this topic will be welcome. My local shop mostly deals with biz jets
and large non-jets. I don't think they will be very helpful with an
experimental. Also, exorbitantly expensive. Do I need a transponder
cert for my DAR inspection? Can I fly somewhere else to get it done
Steve Thomas
speedy11(at)aol.com Guest
Posted: Sun Jan 17, 2010 8:42 am Post subject: Encoder Certification |
All of this is correct, but why does ATC need to be involved? Unless you will be flying under airspace that requires a transponder, then there is no need to contact ATC unless you want them to check your transponder code and mode C. If you are transiting under class B, then coordinate with approach control by phone for instructions.
My DAR did not ask for proof of pitot-static or transponder certification - although I had them available.
Stan Sutterfield
| Quote: | 1/17/2009
it
| Quote: | anyway.
looked at
| Quote: | them.
standby.
| Quote: | -
transponder
and
encod
| Quote: | er.
Stan Sutterfield
Steve Thomas |
bakerocb
Posted: Sun Jan 17, 2010 1:02 pm Post subject: Encoder Certification |
1/17/2010
Hello Stan Sutterfield, You wrote:
1) "All of this is correct, but why does ATC need to be involved?"
Valid question. ATC does not need to be involved in approving non
transponder flight operations if one is not flying in airspace where the
aircraft must be transponder equipped.
Note my wording copied from below "......where one is required....".
See 14 CFR 91.215 (b) (1) through (5) for a description of the airspace
where the aircraft must be transponder equipped. We are assuming an aircraft
that has been originally certificated with an engine-driven electrical
system.
2) "Unless you will be flying under airspace that requires a transponder,
then there is no
need to contact ATC ..........skip....."
I agree, providing the word "under" is changed to the word "in" as "in" is a
more inclusive word and also the wording used in 14 CFR 91.215.
3) "........... coordinate with approach control by phone for
instructions."
Approach Control is part of the ATC (Air Traffic Control) system. When you
talk to approach control you are talking to ATC.
4) "My DAR did not ask for proof of pitot-static or transponder
certification ..........."
Good, I think that is the way that it should be done. However, as I
mentioned earlier the inspector during the initial airworthiness inspection
is endowed with the power of the Administrator and some inspectors swing a
too heavy hammer. If one disagrees with the inspector one is left with
either swallowing that disagreement or going over the inspector's head
within the FAA.
One should proceed with caution in going over the inspector's head on a
specific item because the inspector may find other areas to show that he is
really the boss. I recall a particularly stubborn DAR that required
direction from FAA Headquarters, at my request, through the supervising FSDO
before he would yield on an inspection issue. He got so mad when he was over
ruled that he refused to acknowledge to me that he had been wrong.
bakerocb
Posted: Mon Jan 18, 2010 10:24 am Post subject: Encoder Certification |
1/18/2010
Hello Sam Hoskins, You wrote:
1) "Without looking at the regs, I seem to recall that if the aircraft is
equipped with an operating transponder, it must be turned on."
That is correct. Here is what 14 CFR 91.215 (c) says:
"(c) Transponder-on operation. While in the airspace as specified in
paragraph (b) of this section or in all controlled airspace, each person
operating an aircraft equipped with an operable ATC transponder maintained
in accordance with §91.413 of this part shall operate the transponder,
including Mode C equipment if installed, and shall reply on the appropriate
code or as assigned by ATC."
2) "My simple minded solution would to pull the transponder and stuff it
into a flight
bag. You could even apply a sticker that says "INOP". Fly to the shop, then
install it for the test."
That would be a violation of 14 CFR 91.215 which says, in part:
"(b) All airspace. Unless otherwise authorized or directed by ATC, no person
may operate an aircraft in the airspace described in paragraphs (b)(1)
through (b)(5) of this section, unless that aircraft is equipped with an
operable coded radar beacon transponder having either Mode 3/A 4096 code
capability,.............."
91.215 goes on to provide some exceptions to the above requirement such as
aircraft originally certified with no electrical system and getting
permission from ATC to operate with no transponder. What you describe is not
one of the exceptions.
Time: 07:16:01 AM PST US
Subject: Re: AeroElectric-List: Encoder Certification
equipped with an operating transponder, it must be turned on. My simple
minded solution would to pull the transponder and stuff it into a flight
Fly to the shop, then install it for the test.
Sam
bakerocb
Posted: Mon Jan 18, 2010 9:15 pm Post subject: Encoder Certification |
1/18/2010
1) "Being able to do my own pitot-static check will also get me a long way
to being able to discuss with some authority."
A) There is no regulatory requirement for a pitot system check, but you may
gain some confidence in the accuracy of your airspeed indicator by
performing one.
B) The static pressure system check performed in order to meet the
requirements of 14 CFR 91.411 quoted here:
"Altimeter system and altitude reporting equipment tests and inspections.
(a) No person may operate an airplane, or helicopter, in controlled airspace
under IFR unless-
(1) Within the preceding 24 calendar months, each static pressure system,
each altimeter instrument, and each automatic pressure altitude reporting
system has been tested and inspected and found to comply with appendices E
and F of part 43 of this chapter;"
Must be performed in accordance with the portion of 14 CFR 91.411 quoted
here:
"(b) The tests required by paragraph (a) of this section must be conducted
by-
(1) The manufacturer of the airplane, or helicopter, on which the tests and
inspections are to be performed;
(2) A certificated repair station properly equipped to perform those
functions and holding-
(i) An instrument rating, Class I;
(ii) A limited instrument rating appropriate to the make and model of
appliance to be tested;
(iii) A limited rating appropriate to the test to be performed;
(iv) An airframe rating appropriate to the airplane, or helicopter, to be
tested; or
(3) A certificated mechanic with an airframe rating (static pressure system
tests and inspections only)."
So only if you hold one of the qualifications listed above, would you be
able to perform the regulatory requirement of the static pressure system
tests. But otherwise, as you point out, performing the test yourself could
help you in your discussions. The equipment and parameters to perform the
test are described in 14 CFR Appendix E to Part 43 (a).
2) "Being able to calibrate my BMA EFIS ahead of time will be a giant step
in the right
direction."
Good idea.
3) "I will report back and detail my experience."
I would appreciate that -- thank you.
Time: 09:36:20 AM PST US
Subject: Re: AeroElectric-List: Re: Encoder Certification
A discussion is already underway. What is most important to me is to
know the facts. You cannot argue with "experts" if you don't know the
facts. Being able to do my own pitot-static check will also get me a
long way to being able to discuss with some authority. Being able to
calibrate my BMA EFIS ahead of time will be a giant step in the right
direction.
Thanks to all of you for this invaluable help! I will report back and
Steve Thomas
bakerocb
Posted: Tue Jan 19, 2010 6:19 am Post subject: Encoder Certification |
1/19/2010
Hello Jon Finley, Many thanks for your input and raising this point again.
You wrote:
1) "Everything noted so far in this thread assumes controlled airspace."
I did not make this assumption.
2) "If I missed where that was stated in this thread then ignore my
comments."
Here is my wording: "It would not be reasonable to expect permission to
airspace that did not require a transponder."
This specifically raises the point that there is indeed airspace that does
not require a transponder. I also point out that 14 CFR 91.215 (b) (1)
through (b) (5) and 91.215 (c) identifies the airspace where you must have a
transponder. If one is not flying in the airspace identified then there is
no requirement for a transponder.
3) "If you read the full text of 14 CFR 91.215 (b),........"
Absolutely on point.
Up on my soap box now: I have been working on people sized airplanes (as
opposed to models) since 1950 and flying since 1958 -- all that time I was
planning and gathering information with the intent of building my own
airplane some day. When that day came and I started to build and the
internet allowed me to see what other builders were thinking and writing I
was appalled at the ignorance and assumptions regarding applicable
regulations displayed by my fellow builders.
Here we had the greatest opportunity on our planet to do this wonderful
homebuilding and flying thing and there were many builders so willing to
operate on hearsay, gossip, and rumor and possibly violate regulations
rather than educate themselves. Each notorious violation bringing us closer
to the day when we could lose the opportunity to homebuild and fly.
So my mission in life became to educate my fellow homebuilders and pilots
regarding what the regulations actually say with the hope and belief that
education would encourage compliance. That is why many of my postings read
the way they do.
4) "Additionally, 91.215 (c), does not apply as almost all of our airspace
is uncontrolled."
Let's see what 14 CFR definitions says:
"Controlled airspace means an airspace of defined dimensions within which
air traffic control service is provided to IFR flights and to VFR flights in
accordance with the airspace classification.
Note: Controlled airspace is a generic term that covers Class A, Class B,
Class C, Class D, and Class E airspace."
So as long as one is flying outside of the airspace identified in 91.215 (b)
(1) through (5) and outside the definition of controlled airspace then one
indeed does not need to have or operate a transponder.
Time: 07:10:22 PM PST US
Subject: RE: AeroElectric-List: Encoder Certification
Bakerocb,
Everything noted so far in this thread assumes controlled airspace. If I
missed where that was stated in this thread then ignore my comments. No
doubt that what has been said is applicable given the right environment
(controlled airspace).
If you read the full text of 14 CFR 91.215 (b), you will find that folks
living in a place like me (middle of nowhere in New Mexico) can fly for
hours and hours in most any direction and NOT come upon ANY of the
airspace listed in (b)(1) through (b)(5). Additionally, 91.215 (c), does
not
apply as almost all of our airspace is uncontrolled.
So, given MY environment, I can fly without a transponder and/or without
it turned on. There are huge expanses of this country where this is true.
If someone can prove the above wrong, I would be interested in hearing.
Jon
Float Flyr
Posted: Tue Jan 19, 2010 4:29 pm Post subject: Encoder Certification |
Calibration is generally done with a Barfield tester... Bring $$$$.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
bakerocb
Posted: Wed Jan 20, 2010 5:02 am Post subject: Encoder Certification |
1/20/2010
Hello Steve Thomas, You write: "I am the manufacturer of the airplane."
{Response} Nice try, but no cigar.
In the eyes of the FAA you are not the manufacturer of a type certificated
airplane (which title carrys many significant qualifications, approvals, and
inspections), but instead the "fabicator and assembler" of an experimental
amateur built airplane.
The regulatory permission and description that allows our category of
aircraft to exist does not use the word "manufactured". See here:
" 14 CFR 21.191 Experimental certificates. Experimental certificates are
issued for the following purposes:
(g) Operating amateur-built aircraft. Operating an aircraft the major
portion of which has been fabricated and assembled by persons who undertook
the construction project solely for their own education or recreation."
Time: 06:49:15 AM PST US
OC,
As I read the regs. you quote below, it sounds like I am qualified to
perform the
tests.
| Quote: | "(b) The tests required by paragraph (a) of this section must be conducted
by-
and inspections
Steve Thomas
bakerocb
Posted: Wed Jan 20, 2010 7:01 am Post subject: Encoder Certification |
1/20/2010
Hello Again Jon Finley, Can we please beat on this subject a bit more with
your help?
You write:
1) "..... almost all of our airspace is uncontrolled." and "There are huge
expanses of this country where this is true."
{Response} I wonder if this is so. Years ago when I would freely roam the
wild west in my many different flying machines I would eye the uncontrolled
airspace (delineated by brown shading as opposed to white on the low
altitude IFR charts) and wonder about its significance.
There was damn little brown shading then and probably much less now. Can you
please obtain a copy of a recent low altitude IFR chart for your area and
confirm that the statements you made above are true? I tend to doubt them.
Note that all airspace in our country above 14,500 is Class E airspace and
therefore is controlled.
2) "If you read the full text of 14 CFR 91.215 (b), you will find that folks
airspace listed in (b)(1) through (b)(5)."
{Response} If you get above 10,000 feet MSL and not within 2,500 feet of the
surface you will definitely be in the airspace identified by 91.215 (b) (5)
(i). See here:
operable coded radar beacon transponder.......
(i) In all airspace of the 48 contiguous states and the District of Columbia
at and above 10,000 feet MSL, excluding the airspace at and below 2,500 feet
above the surface; and....."
3) "So, given MY environment, I can fly without a transponder and/or without
it turned on."
{Response} Note that 91.215 (b) (5) (i) in effect permits aircraft with no
transponders to operate below 10,000 feet MSL and above 10,000 feet MSL if
within 2,500 feet of the surface, even if that airspace is controlled, as
long as the rest of 91.215 (b) is complied with.
Could it be that this vast amount of airspace is the airspace that you have
in mind to operate in and not uncontrolled airspace per se?
Anyway the real issue here when it comes to requiring a transponder or not
is not the existence or not of generic controlled airspace, but rather the
specific airspaces identified in 91.215 (b). The term "controlled airspace"
is not used once in the entire 91.215 (b) parargraph and this is the 14 CFR
paragaph that regulates whether an aircraft must be equipped with a
transponder or not.
Hoping to read about what you find out -- sure wish I had access to a set of
low altitude IFR charts for the entire country.
PS: I just went on line and checked in the vicinity of Socorro NM. Yes there
is some brown (uncontrolled airspace) out there, but one would be hard
pressed to fly around and avoid all surrounding white (controlled airspace)
unless a special navigation effort was made.
Bakerocb,
I missed where that was stated in this thread then ignore my comments. No
not
Jon
wjrhamilton(at)optusnet.c Guest
Posted: Wed Jan 20, 2010 8:05 pm Post subject: Encoder Certification |
Folks,
Using the term "controlled airspace" is a bit of a misnomer.
Airspace is categorized as A, B, C, D, E, F and G.
Only F and G are "uncontrolled", there is no F in the US, and very little G, outside Alaska.
For those with a long memory, what is now E, in the US was once called "Controlled/VFR Exempt".
In regular day to day flying, it is very hard to dodge E airspace in US, as it is most common airspace below below A.
Generally, B,C and D are terminal/tower airspace.
Below 10,000', for Part 91 operations, the requirement for a transponder relates to the transponder veil withing 30 miles of the airfields on which Class B is centered, or as otherwise noted/charted.
In my opinion, as an individual, you can only satisfy the requirements for a Mode C encoder by having a TSO unit, with the necessary initial/recurrent testing.
How?? do you establish the 95% probability performance otherwise required in Part 91, already mentioned, a simple test of an installation does not do that, it does not establish the in-service performance is maintained.
Bill Hamilton
| Quote: | bakerocb(at)cox.net wrote:
1/20/2010
with
your help?
You write:
huge
the
uncontrolled
you
and
them.
and
folks
the
(5)
(i). See here:
person
Columbia
feet
without
it turned on."
no
if
as
have
not
the
airspace"
CFR
transponder or not.
set of
there
airspace)
Bakerocb,
No
does
not
true.
Jon
bakerocb
Posted: Thu Jan 21, 2010 4:35 am Post subject: Encoder Certification |
1/21/2010
Hello Bill Boyd, You wrote:
1) "OC, I'm pretty sure my experimental airworthiness certificate has a
blank on
it for "manufacturer.""
{Response} That is correct. FAA Form 8130-7 SPECIAL AIRWORTHINESS
CERTIFICATE block B is entitled MANUFACTURER. This form is used for many
different kinds of aircraft than just experimental amateur built. Some of
these different kinds of aircraft could indeed have been created by an FAA
recognized manufacturer such as Boeing, Piper, Cessna, etc.
2) "I've seen some builders put their last name there, while others put
"Vans" or whatever."
{Response} Not likely. That form is filled out and signed by the FAA
Representative, either an FAA Employee or a DAR, who signs it in block E.
3) "I'm not looking at my cert right now it's in the plane), but I'm
reasonably sure the box I'm referring to is not labeled "Fabricator.""
{Response} I am looking at my SPECIAL AIRWORTHINESS CERTIFICATE right now.
Block B, MANUFACTURER has N/A as an entry. Block D, BUILDER has my name.
I hope that every homebuilder who has read this thread is now convinced that
they are not their aircraft's manufacturer, which is one of the
qualifications listed in 14 CFR 91.411 as needed in order to perform the
tests required by that paragraph (91.411 Atimeter system and altitude
reporting equipment tests and inspection).
PS: I write not to pick on you Bill, but to encourage my fellow builders to
move from the casual arena of "pretty sure" or "hearsay, gossip, and rumor"
to the available facts (which are usually not that hard to come by)
regarding our hobby.
Time: 06:00:47 AM PST US
OC, I'm pretty sure my experimental airworthiness certificate has a blank on
it for "manufacturer." I've seen some builders put their last name there,
while others put "Vans" or whatever. I'm not looking at my cert right now
(it's in the plane), but I'm reasonably sure the box I'm referring to is not
-Bill B
lessdragprod(at)aol.com Guest
Posted: Thu Jan 21, 2010 9:23 am Post subject: Encoder Certification |
Hi All,
I just checked the FAA records: William E. Boyd, Jr is the "manufacturer" of a RV-6A.
There is no BUILDER block on the aircraft registration form. What did you put on the 8050-1 form you sent to FAA Oklahoma City to register your aircraft? I think this is the first form the FAA sees for a new homebuilt.
Jim Ayers
bakerocb
Posted: Thu Jan 21, 2010 2:52 pm Post subject: Encoder Certification |
1/21/2010
Hello Again Jon Finley, Thank you for responding to my request (copied
below) to review the charting of controlled and uncontrolled airspace in
your area.
Before I respond to the specific points that you made in that charting
regard I would like to again remind all of the readers regarding the non
relevance of generic controlled airspace when it comes to determining
whether or not an aircraft must be equipped with an operable coded
transponder.
I repeat: "Anyway the real issue here when it comes to requiring a
transponder or
not is not the existence or not of generic controlled airspace, but rather
the
transponder or not."
You wrote:
1) ".............. one has to actually look at a sectional (NOT IFR chart)
to see where true "uncontrolled airspace" exists."
{Response} Is that really true? I don't have the current appropriate
sectional and low altitude IFR charts of the areas out west to compare side
by side, but the few sectional charts that I do have (outdated) of the areas
where I think there should be some uncontrolled Class G airspace going from
the surface up to 14,500 MSL feet do not identify this airspace. But this
Class G airspace going from the surface up to 14,500 feet MSL is the
airspace that I believe is shown in brown on the low altitude IFR charts.
2) "Said another way,one has to look at a sectional to see at what altitude
the floor of Class E
airspace exists."
{Response} I agree, the sectionals do show where the floor of controlled
Class E airspace is at either 700 feet (using magenta colored shading) or
1,200 feet (using blue color shading) above the surface.
But do the sectionals in your area also show the uncontrolled Class G
airspace that goes from the surface up to 14,500 feet MSL like the low
altitude charts show with brown shading? If so how do the sectionals show
this same airspace?
3) "There is quite a bit of area (many, many, many square miles) where Class
E starts
at 14,500' AGL and a few locations where it starts at 11,500' and 12,000'."
{Response} And again it does not matter where Class E starts, 700 feet above
the surface, 1,200 feet above the surface, 11,500 feet MSL, 12,000 feet MSL
or 14,500 feet MSL when it comes to where one needs an operable coded
transponder in an aircraft because it is paragraph 14 CFR 91.215 (b) (5)
(i), (along with the other relevant paragraphs in 91.215 (b)), that
determines transponder requirement. The relevant numbers in 91.215 (b) (5)
(i) are to be below 10,000 feet MSL or within 2,500 feet of the surface in
order to operate without a transponder. Even if one is operating in that
uncontrolled Class G airspace between 10,000 feet MSL and the beginning of
controlled Class E airspace at 14,500 feet MSL one must have an operable
coded transponder.
4) "Here, it is possible/legal (due to the airspace) to pull the transponder
(or
leave it off) and fly to a repair shop (obviously depending on where the
repair shop is..).'
{Response} Agreed, as long as one is in compliance with 14 CFR 91.215 (b).
Time: 09:08:18 AM PST US
Bakerocb,
SkyVector.com is an awesome resource. You can view any sectional or IFR
chart in the US (maybe more, I haven't tried) with it and do some very neat
trip planning.
You are absolutely right, one has to actually look at a sectional (NOT IFR
chart) to see where true "uncontrolled airspace" exists. Said another way,
one has to look at a sectional to see at what altitude the floor of Class E
airspace exists.
I admit that I took some liberty with my previous statement to make a point.
Obviously we have plenty of Class E space here. The Class E airspace where
I live (E98) starts at 1200' AGL (about 6,000' MSL). That is true for most
of the northern half of the state except where an airport with an approach
exists (the Class E floor extends to 700'/ground at those locations). There
is quite a bit of area (many, many, many square miles) where Class E starts
With that in mind, I do not have a good guess at how much of my actual
flying is in uncontrolled airspace (i.e. beneath the floor of Class E) but I
would guess about 40%. When going x-country (i.e. hundreds of miles), a
higher altitude is typical which places me in Class E. Most of my flying is
recreational (to from breakfast, sightseeing, having fun) and is fairly low
- I do get above 1200' AGL but also spend a lot of time below 1200' AGL.
Here, it is possible/legal (due to the airspace) to pull the transponder (or
repair shop is..).
Jon Finley
| Quote: | Hello Again Jon Finley, Can we please beat on this subject a bit more
| Quote: | 1) "..... almost all of our airspace is uncontrolled." and "There are
| Quote: | expanses of this country where this is true."
| Quote: | {Response} I wonder if this is so. Years ago when I would freely roam
| Quote: | wild west in my many different flying machines I would eye the
| Quote: | airspace (delineated by brown shading as opposed to white on the low
| Quote: | altitude IFR charts) and wonder about its significance.
| Quote: | There was damn little brown shading then and probably much less now.
| Quote: | please obtain a copy of a recent low altitude IFR chart for your area
| Quote: | confirm that the statements you made above are true? I tend to doubt
| Quote: | Note that all airspace in our country above 14,500 is Class E airspace
| Quote: | therefore is controlled.
| Quote: | 2) "If you read the full text of 14 CFR 91.215 (b), you will find that
| Quote: | living in a place like me (middle of nowhere in New Mexico) can fly for
| Quote: | hours and hours in most any direction and NOT come upon ANY of the
| Quote: | airspace listed in (b)(1) through (b)(5)."
| Quote: | {Response} If you get above 10,000 feet MSL and not within 2,500 feet
| Quote: | surface you will definitely be in the airspace identified by 91.215 (b)
| Quote: | "(b) All airspace. Unless otherwise authorized or directed by ATC, no
| Quote: | may operate an aircraft in the airspace described in paragraphs (b)(1)
| Quote: | through (b)(5) of this section, unless that aircraft is equipped with
| Quote: | operable coded radar beacon transponder.......
| Quote: | (i) In all airspace of the 48 contiguous states and the District of
| Quote: | at and above 10,000 feet MSL, excluding the airspace at and below 2,500
| Quote: | above the surface; and....."
| Quote: | 3) "So, given MY environment, I can fly without a transponder and/or
| Quote: | {Response} Note that 91.215 (b) (5) (i) in effect permits aircraft with
| Quote: | transponders to operate below 10,000 feet MSL and above 10,000 feet MSL
| Quote: | within 2,500 feet of the surface, even if that airspace is controlled,
| Quote: | long as the rest of 91.215 (b) is complied with.
| Quote: | Could it be that this vast amount of airspace is the airspace that you
| Quote: | in mind to operate in and not uncontrolled airspace per se?
| Quote: | Anyway the real issue here when it comes to requiring a transponder or
| Quote: | is not the existence or not of generic controlled airspace, but rather
| Quote: | specific airspaces identified in 91.215 (b). The term "controlled
| Quote: | is not used once in the entire 91.215 (b) parargraph and this is the 14
| Quote: | paragaph that regulates whether an aircraft must be equipped with a
| Quote: | transponder or not.
| Quote: | Hoping to read about what you find out -- sure wish I had access to a
| Quote: | low altitude IFR charts for the entire country.
| Quote: | 'OC' Says: "The best investment we can make is the effort to gather and
| Quote: | understand knowledge."
| Quote: | PS: I just went on line and checked in the vicinity of Socorro NM. Yes
| Quote: | is some brown (uncontrolled airspace) out there, but one would be hard
| Quote: | pressed to fly around and avoid all surrounding white (controlled
| Quote: | unless a special navigation effort was made.
bakerocb
Posted: Sun Jan 24, 2010 2:54 pm Post subject: Encoder Certification |
1/24/2010
Hello John Grosse, You wrote: "I personally don't understand why you just
wouldn't buy a transponder..."
{Response} Recall that this thread began with a posting by Steve Thomas (Msg
# 48119 on Jan 16, 2010 using the subject "Encoder Certification") who
wanted to know if he
could fly away from his home base with his newly certified experimental
amateur built airplane without an operating and certified transponder in
order to have the appropriate transponder checks done at another location.
Sorry that it got so drawn out and exhausting as we initially tried to help
him and then got bogged down while trying to clarify some subsequent
postings.
Time: 10:04:57 PM PST US
Subject: Re: AeroElectric-List: RE: Encoder Certification
This whole discussion has me totally exhausted. I personally don't
understand why you just wouldn't buy a transponder... unless, of course.
you're smuggling drugs or are flying some WWI vintage rag bag with no
electrical system. Then I get it, and why would you even care?
John Grosse
bakerocb
Posted: Mon Jan 25, 2010 6:55 am Post subject: Encoder Certification |
1/25/2010
Hello Angier Ames, You wrote 1) 2) and 3) below:
1) "Altitude encoders are required equipment for IFR flight in controlled
airspace."
{Response} Not true for all controlled airspace -- just that airspace
identified in 91.215 (b). Can you show otherwise?
2) "And unless the operation is conducted under part 121 or 135, as per
FARS, 14CFR Section215(a), they do NOT need to be certified/ TSO'd."
{Response} Not true because 14 CFR Section 215 (a) says exactly the
opposite. Read here:
(a) All airspace: U.S.-registered civil aircraft. For operations not
conducted under part 121 or 135 of this chapter, ATC transponder equipment
installed must meet the performance and environmental requirements of any
class of TSO-C74b (Mode A) or any class of TSO-C74c (Mode A with altitude
reporting capability) as appropriate, or the appropriate class of TSO-C112
(Mode S)."
3) "So, go to your basement and create your own altitude encoder. Your only
obligation under Part 91 is to demonstrate that it meets the performance and
environmental standards of any class of TSO-C47b or c or TSO-C112."
{Response} More than a bit misleading. The FAA requirements of proving "the
performance and environmental standards" of a TSO, or an alternate method of
complying with the requirements, for avionics are very extensive, demanding,
and expensive. This is why most of the altitude encoding EFIS' available to
the experimental amateur built community are not TSO'd. There is extensive
material in the aeroelectric list archives on the significance of
paragraph14 CFR 91.217, particularly 91.217 (b). Just help yourself.
Time: 07:07:12 AM PST US
Subject: AeroElectric-List: Re: Encoder Certification
Since we are all now exhausted by this subject, lets beat this dead
horse one more time.
airspace. And unless the operation is conducted under part 121 or 135,
as per FARS, 14CFR Section215(a), they do NOT need to be certified/
TSO'd.
only obligation under Part 91 is to demonstrate that it meets the
performance and environmental standards of any class of TSO-C47b or c
or TSO-C112.
Angier Ames
N4ZQ
kpc(at)speakeasy.net Guest
Posted: Mon Jan 25, 2010 9:44 am Post subject: Encoder Certification |
/set mode = "dead horse"
/enable beat
On Jan 25, 2010, at 9:35 AM, <bakerocb(at)cox.net> wrote:
1/25/2010
airspace identified in 91.215 (b). Can you show otherwise?
TSO'd."
equipment installed must meet the performance and environmental
requirements of any class of TSO-C74b (Mode A) or any class of TSO-
C74c (Mode A with altitude reporting capability) as appropriate, or
the appropriate class of TSO-C112 (Mode S)."
Your only obligation under Part 91 is to demonstrate that it meets
the performance and environmental standards of any class of TSO-C47b
or c or TSO-C112."
proving "the performance and environmental standards" of a TSO, or
an alternate method of complying with the requirements, for avionics
are very extensive, demanding, and expensive. This is why most of
the altitude encoding EFIS' available to the experimental amateur
built community are not TSO'd. There is extensive material in the
aeroelectric list archives on the significance of paragraph14 CFR
and understand knowledge."
TSO'd.
or TSO-C112.
Angier Ames
N4ZQ
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Mon Jan 25, 2010 3:38 pm Post subject: Encoder Certification |
<LOOP UNTIL Reader.Count = 0>
/enable beat
</LOOP>
| Quote: | On Jan 25, 2010, at 9:35 AM, <bakerocb(at)cox.net> wrote:
> 1/25/2010
that airspace
> TSO'd."
vipin
Posted: Sun Dec 05, 2010 8:05 pm Post subject: Re: Encoder Certification |
more inclusive word
_________________ Slimming Pills
Slimming Pill |
bakerocb
Posted: Mon Dec 06, 2010 5:28 am Post subject: Encoder Certification |
12/6/2010
Hello vipin,
On Jan 24, 2010 Angier Ames wrote: "And unless the operation is conducted
under part 121 or 135, as per FARS, 14CFR Section215(a), they do NOT need
On Jan 25, 2010 I wrote: "{Response} Not true because 14 CFR Section 215 (a)
says exactly the opposite......"
On Dec 05, 2010 8:05 pm you wrote: "I agree, providing the word "under" is
changed to the word "in"....."
{Response 1} Wow! I am both astounded and curious. Why are you responding to
a Jan 25, 2010 posting to this thread almost a year later on Dec 5, 2010?
{Response 2} It is not clear whether you are agreeing with what Angier wrote
or what I wrote in response.
{Response 3} I am reluctant to post again to this thread because some
readers became a bit bored / disgusted with it, but your preference for the
word "in" instead of the word "under" when it comes to which part of the
regulations apply to a particular kind of operation does not change what the
FARs actually say. Here is the quote that applies, directly extracted from
14 CFR 91.215 (a):
"All airspace: U.S.-registered civil aircraft. For operations not conducted
under part 121 or 135 of this chapter, ATC transponder equipment installed
must meet ............."
{Response 4} Perhaps you are thinking of operating "in" a particular kind of
airspace instead of operating "under" a particular part of the regulations
that apply to that operation.
'OC' Baker Says: "The best investment we can make is the time and effort to
gather and understand knowledge."
Time: 08:10:10 PM PST US
Subject: Re: Encoder Certification
more inclusive word
http://forums.matronics.com/viewtopic.php?p=322416#322416
luluxiu
Posted: Thu Jul 21, 2011 5:07 pm Post subject: Re: Encoder Certification |
I agree, provided the word "under" words "in the" to "Medium" is a more inclusive word...
