smullins(at)drury.edu Guest
Posted: Fri Jan 15, 2010 9:22 am Post subject: Flap Leading edge protection |
Good morning everyone. I just had my RV4 painted and the paint shop forgot to install the tape on the leading edge to protect the flap surface. Do the flaps have to be removed to install the protective tape?
Thanks in advance for the help!
Steve Mullins
Associate Professor of Economics
Breech School of Business Administration
Drury University
417.873.7299
"Preparing Ethical Leaders for the Global Business Community"
| | - The Matronics RV4-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV4-List |
SSampson.SLN21(at)london. Guest
Posted: Fri Jan 15, 2010 9:59 am Post subject: Flap Leading edge protection |
Steve, if you disconnect the pushrods inside the fuselage, the flaps will hang vertically down so it will be easy for you to put the protective tape on. Did the shop paint the aircraft with them on then?
Before you move them you might want to slide some stiff brown paper between the flap/wing to protect them while you move them down. Goodluck.
Regards, Steve.
2010/1/15 Steven Mullins <smullins(at)drury.edu (smullins(at)drury.edu)>
Steve Mullins
Drury University
417.873.7299
et="_blank">http://www.matronics.com/Navigator?RV4-List
tp://forums.matronics.com
Posted: Fri Jan 15, 2010 7:19 pm Post subject: Flap Leading edge protection |
Thanks for the tip, Stephen. They did remove the old tape and "forgot" to replace it.
Steve MullinsAssociate Professor of Economics
Drury University
417.873.7299
Sent via Iphone
On Jan 15, 2010, at 11:59 AM, "Stephen Sampson" <SSampson.SLN21(at)london.edu (SSampson.SLN21(at)london.edu)> wrote:
| Quote: | Steve, if you disconnect the pushrods inside the fuselage, the flaps will hang vertically down so it will be easy for you to put the protective tape on. Did the shop paint the aircraft with them on then?
Regards, Steve.
2010/1/15 Steven Mullins <[url=mailto:smullins(at)drury.edu]smullins(at)drury.edu (smullins(at)drury.edu)[/url]>
Steve Mullins
Drury University
417.873.7299
