sawad13(at)msn.com Guest
Posted: Tue Jan 10, 2006 9:21 pm Post subject: Sheetmetal, and radio work needed |
| - The Matronics RVSouthEast-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
bill28104(at)yahoo.com Guest
Posted: Wed Jan 11, 2006 4:23 am Post subject: Sheetmetal, and radio work needed |
Steve Glasgow
![](images/avatars/96330856543c3cdb6e0369.jpg)
Posted: Wed Jan 11, 2006 4:31 am Post subject: Sheetmetal, and radio work needed |
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
Ed Anderson
Posted: Wed Jan 11, 2006 5:48 am Post subject: Sheetmetal, and radio work needed |
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
jclarkmail(at)gmail.com Guest
Posted: Wed Jan 11, 2006 5:54 am Post subject: Sheetmetal, and radio work needed |
Posted: Wed Jan 11, 2006 6:03 am Post subject: Sheetmetal, and radio work needed |
Steve, Where is twin lakes?
And please explain what you mean about working on the plane without being
the builder and not being a A&P. It is my understanding that Anyone can work
on a experimental airplane. They do not have to be the builder, or a A&P, or
the pilot, or the owner, etc...
. The only exceptions to that is for the Condition inspection once a year
which would have to be done by a A&P or the builder if he still holds the
repairmans certificate, And if any Major alterations were done, again it
would need to be signed off by one of those two.
Am I wrong on this?
Ron Awad
Quote: | From: "Steve Glasgow" <willfly(at)carolina.rr.com>
Reply-To: rvsoutheast-list(at)matronics.com
To: <rvsoutheast-list(at)matronics.com>
Subject: Re: Sheetmetal, and radio work needed
Date: Wed, 11 Jan 2006 07:31:02 -0500
If you are going to fly under the Mode C Vail (Goose Creek is under it) you
need to have as a minimum a VFR transponder check every two years. I just
had mine done at Twin Lakes Avionics for $75.
Working on experimental aircraft that were not built by oneself can be a
problematic unless you are an A&P.
Cappy
Posted: Wed Jan 11, 2006 6:27 am Post subject: Sheetmetal, and radio work needed |
Posted: Wed Jan 11, 2006 6:28 am Post subject: Sheetmetal, and radio work needed |
Steve Glasgow
Posted: Wed Jan 11, 2006 8:26 am Post subject: Sheetmetal, and radio work needed |
Cappy's Toy
RV-8 N123SG |
WVSWIFT(at)aol.com Guest
Posted: Wed Jan 11, 2006 4:47 pm Post subject: Sheetmetal, and radio work needed |
Ron:
The answer to your question about who can work on an experimental, anyone
can>>>>>with exception to the condition inspection that is required each year.
FAR Part 43 does not apply to an experimental home built. (with one
exception)
The operating limitations , which is a part of the Special Airworthiness
Certificate, (should be attached to it) outlines how and when the required
inspection is to be accomplished and by whom and how the inspection is signed off.
Both should be in the aircraft at all times with the registration card.
I have recently seen an experimental aircraft logbook that was signed by the
words "annual , no issues". Well, that does NOT meet the rule in the
operating limitations issued to an experimental. These "annuals" were from 1993,
(there is no annual for an experimental, only a condition inspection every
year.) No legal inspection during all those years! Nobody knows who did it.SO, it
was not a legal sign off for 12 years. Bet an insurance company would love to
see the operating limitations not adhered to, SO NO PAYOFF!
The limitations will state what shall be written after the inspection has
been completed and who can conduct a condition inspection.
A big misconception I see a lot is the operating limitations state how and
what must be inspected every year. That is FAR 43 appendix D.. This is the only
time FAR Part 43 applies to an experimental. I HIGHLY RECOMMEND everybody
review their respective operating limitations to see what is in there along
with FAR Part 43 appendix D. You might not be able to fly and conduct aerobatics
without the proper signoff in accordance with the statement in the operating
limitations. Best read it.
Posted: Wed Jan 11, 2006 4:52 pm Post subject: Sheetmetal, and radio work needed |
PS:
On the major repair or alteration question, you can do it, just takes an A&P
or the repairman for that aircraft to sign off a condition inspection every
year.
The only thing to remember on major alterations are you will need to check
the operating limitations on what to do when that is done. The newer operating
limitations now allow you to put the aircraft into a test period yourself and
then sign off the flight test yourself. The old operating limitations
required you to contact the FAA Flight Standards District Office prior to flying
the aircraft and they will put a test period and area restriction on the
aircraft. This change only happened about a year or so ago.
Eddie
Posted: Thu Jan 12, 2006 6:32 am Post subject: Sheetmetal, and radio work needed |
Thanks Eddie. That makes it pretty darn clear!!!
I will try to come by your place at York this weekend
Ron Awad
Date: Wed, 11 Jan 2006 19:47:37 EST
Ron:
year.
exception)
signed off.
the
1993,
it.SO, it
to
only
along
aerobatics
operating
Also, read FAR Part 91.413 for the use of the ATC transponder(VFR). It
doesn't state experimentals are exempt. All transponders that are used in
airspace
must also be inspected every 24 calendar months. Please keep in mind, FAR
Part 91.411 must also be complied with on all aircraft being used in IFR
conditions.
Contact Jerry Boyce at Rock Hill about your cowl, he just finished his RV8
cowl.
He has a hanger facing the runway across the runway from the FBO. He also
might be able to help in the sheetmetal work for your friend. Also there
are
others there that may help.
Please keep in mind about radio repair, only certified avionics shops can
return a TSO'd unit to service within tolerances that are now required.
Gary Wilson is NOT a certified repairman or shop. He cannot certify any
transponders or systems in an aircraft.
If you or any others need more info on this please give me a call at work
or
email me at work. You know where I am.
Hope this helps
Eddie
_Edwin.G.Shields(at)FAA.GOV_ (mailto:Edwin.G.Shields(at)FAA.GOV) (don't forget
the dots between the name)
PS: Come on down for a visit at our strip in York, we always have drinks in
the fridge. May be gone this Saturday picking up another project but will
be
home Sunday and Monday. Debbie and me are working very hard now on my
Swift.
We do have a complete sheetmetal shop here too.
http://toolbar.msn.click-url.com/go/onm00200415ave/direct/01/
Posted: Thu Jan 12, 2006 6:35 am Post subject: Sheetmetal, and radio work needed |
Thanks Eddie.
Ron Awad
Date: Wed, 11 Jan 2006 19:52:26 EST
PS:
A&P
every
year.
operating
and
flying
Eddie
