bw12345(at)sbcglobal.net Guest
Posted: Sun Jan 10, 2010 1:57 pm Post subject: Ram Air |
I have a KitFox classic 4 with a 2200.Is it necessary to have Ram air or can the air filter draw from inside the cowl attached directly to carb? I am aware the vacuum hose has to be attached to the air filter.I tried the Jabiru factory filter, Pete has been great, but there is not enough room to mount the ram air filter box.
BOB
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
wb2ssj(at)frontiernet.net Guest
Posted: Sun Jan 10, 2010 4:27 pm Post subject: Ram Air |
I have a model 4 -1200 clasic with the jabiru 2200 and I use air from inside the cowl and have no problems. Over 400 hrs in ten years and its fine. Tex
Clive J
Posted: Mon Jan 11, 2010 12:14 am Post subject: Ram Air |
The only issue with cowl air as I understand it is loss of power if the air is warmed by the engine, can't imagine it's much.
The Jab engine being a clean one should mean your filter with last Ok.
Or is there something else I forgot?
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Tex Mantell
Sent: 11 January 2010 00:24
To: jabiruengine-list(at)matronics.com
Subject: Re: Ram Air
Lynn Matteson
Posted: Mon Jan 11, 2010 5:35 am Post subject: Ram Air |
I have a model IV with a 2200 Jabiru, and I found room to install the
air box as delivered by Pete back in 2005. You might have a larger
air box, as they have changed them over the years. With my Rotec TBI,
when I pull on the "carb heat" the engine actually picks up 40-80
rpm, and the fuel flow meter show a gain in fuel used by about .2-.4
GPH. This could be caused by my particular installation.
Be aware that the Sonex-type planes use only an air filter, and no
air box with their Jabiru installs, so it must work.
If you DO go with the air cleaner only and no air box, how will you
deal with the carb heat issue?
Lynn Matteson
Jabiru 2200, #2062, 834.5 hrs
Countdown to 1000 hrs~167 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Jan 11, 2010, at 2:57 AM, James, Clive R wrote:
[quote] The only issue with cowl air as I understand it is loss of power if
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Mon Jan 11, 2010 7:41 am Post subject: Ram Air |
I have the electric carb heat availible from Pete at Jabiru
BOB
Date: Monday, January 11, 2010, 8:32 AM
--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I have a model IV with a 2200 Jabiru, and I found room to install the air box as delivered by Pete back in 2005. You might have a larger air box, as they have changed them over the years. With my Rotec TBI, when I pull on the "carb heat" the engine actually picks up 40-80 rpm, and the fuel flow meter show a gain in fuel used by about .2-.4 GPH. This could be caused by my particular installation.
Be aware that the Sonex-type planes use only an air filter, and no air box with their Jabiru installs, so it must work.
If you DO go with the air cleaner only and no air box, how will you deal with the carb heat issue?
Lynn Matteson
[quote] The only issue with cowl air as I understand it is loss of power if the air is warmed by the engine, can't imagine it's much.
From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Tex Mantell
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Subject: Re: JabiruEngine-List: Ram Air
Lynn Matteson
Posted: Mon Jan 11, 2010 8:51 am Post subject: Ram Air |
Right, right, right.....I keep forgetting about that....sorry.
Lynn Matteson
On Jan 11, 2010, at 10:37 AM, Robert Rivard wrote:
| Quote: | I have the electric carb heat availible from Pete at Jabiru
BOB
Lynn Matteson
N369LM |
