undoctor
Joined: 21 Oct 2008 Posts: 212 Location: Bethelhem, PA
whiskeyvictor36(at)aol.co Guest
Posted: Fri Jan 08, 2010 8:05 pm Post subject: Comedy act for all Kolbers |
Wow,Wow & Wow again ! That guy can really fly that Cub. I've watched it at least a dozen times now.
AV Web Flash, Jan 4, 2010 also has a link to that video including an interview with Kyle Franklin about how hard it is to fly that routine. Go to:
http://www.avweb.com/avwebflash/exclusivevids/ExclusiveVideo_KyleFranklin_AirShowComedyAct_201761-1.html
On a Kolb note, I just finished installing a much larger trim tab on the aileron to counter a tendency for the left wing to go down. I had a small metal tab before, but it just wasn't up to the job. I followed the Kolb plan and used a piece of .063 Lexan. Now, if I can just get some decent weather to test it out (it's 20F, light snow on the ground and windy). As per the Kolb plan, If the tab is too large, I'll just trim some off until it flies true.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 1/4/2010 7:01:34 P.M. Eastern Standard Time, undoctor(at)ptd.net writes:
