bakerocb
Posted: Sat Jan 02, 2010 9:13 am Post subject: Questions about circuit protection |
1/2/2010
Hello Matthew Schumacher, You wrote: "I think I will just get fuse blocks
per your recommendation for the reasons you mention, but also because
problems with a fuse can be remedied in the air quickly and easily."
If you are thinking of replacing fuses in the air to trouble shoot and solve
an electrical problem please think again. There are several disadvantages.
Some are:
1) Your airplane's Operating Limitations (part of its airworthiness
certificate) will require you to equip the aircraft in accordance with 14
CFR 91.205 if you fly at night or IFR.
Paragraph 91.205 (c) (6) says: "One spare set of fuses, or three spare fuses
of each kind required, that are accessible to the pilot in flight."
This means that, by regulation, if you design your airplane so that you have
access to those fuse blocks in flight then you must also have available to
you all those spare fuses while in flight. Do you want to create that burden
/ nuisance / danger?
2) Trouble shooting an electrical system in flight by fumbling around to
locate and then insert the appropriate fuse is not a good idea, particularly
at night or IFR when you should be concentrating on flying the airplane.
So fuse blocks are a good idea, but where you locate them has some
operational and safety implications. Please read some more of Bob Nuckolls'
philosophy regarding electrical problems / failures in flight.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 07:42:35 PM PST US
Subject: Re: AeroElectric-List: Questions about circuit protection.
First, thank you very much for looking at my stuff Bob. I greatly
appreciate it and have donated to keep this list going...
..................................... big skip
I know that fuses/breakers/fuselinks protect the wiring, what I was
missing was the part about problems with one component spreading to
others instead of being isolated. I think I will just get fuse blocks
Thanks again,
schu
speedy11(at)aol.com Guest
Posted: Sat Jan 02, 2010 9:25 am Post subject: Questions about circuit protection |
Often times we get admonishments on this forum to not do something and our questions are never answered. While the admonishment is fine (and welcomed) when coming from someone so educated in electricity as Bob, getting the questions answered is the desire.
Yes, you can bundle some of the lighting on a single breaker - realizing that the breaker and wires need to be sized accordingly for the load. Bob's advice is to consider using fuses. You can have a fuse for each light for a fraction of the cost in weight and money as the breaker. Personally, I chose breakers for my airplane.
Personally I would not use a single breaker for the E-bus and omit breakers for individual devices on the bus. Again you would have to size the breaker for the entire load and wiring would have to match. In my opinion, not a logical approach. Bob's argument for fuses should again be considered.
As far as fuselinks, I don't understand them either. I haven't studied them because I had no application for them.
Stan Sutterfield
Quote: | Can I group up some of the lighting on a
single breaker? Also, what about using a breaker for the entire e-bus
then omitting the breakers for the devices on the ebus? The lines will
be real short and it eliminates the single point of failure (breaker.)
Also, what about fuselinks? I understand them to be like a fuse that
blows extremely slowly, but I'm not fully understanding when and where
to use them. |
schu(at)schu.net Guest
Posted: Sat Jan 02, 2010 11:09 am Post subject: Questions about circuit protection |
bakerocb(at)cox.net wrote:
Quote: | If you are thinking of replacing fuses in the air to trouble shoot and
solve an electrical problem please think again. There are several
disadvantages. Some are:
14 CFR 91.205 if you fly at night or IFR.
fuses of each kind required, that are accessible to the pilot in flight."
have access to those fuse blocks in flight then you must also have
available to you all those spare fuses while in flight. Do you want to
create that burden / nuisance / danger?
Hold on, back the truck up. Are you saying that if I put the fuses
under the panel where they aren't accessible then my airplane will still
meet 14 CFR 91.205 (c) and that I won't need to carry spares?
I would read "that are accessible to the pilot in flight" to mean that
the fuse panel is accessible to the pilot, not the fusees since who
cares if you can get to the fuses if you can't get to the panel.
schu
Posted: Sat Jan 02, 2010 10:38 pm Post subject: Questions about circuit protection |
First, 14 CFR 91.205 doesn't apply to an amateur built
airplane. That's not to imply that the FARS don't have
some things to be considered . . . but you have no
obligation to consult these documents that apply to
type certificated aircraft only. Further, 91.205 isn't
the ONLY milestone at which your project is essentially
"un-certifiable".
But assume you adopt failure tolerance as a
design goal. For every piece of equipment
"critical" for the manner in which you plan to use
the airplane, then that piece of equipment needs to
be backed up with a plan-B. There are 100 times
more failures in a piece of electronics that DOES
NOT blow a fuse than there are failures that DO
blow a fuse. If that piece of equipment is deemed
critical, then having spare fuses for the circuit
that supports that system is whistling in the dark.
So assuming you have a back up for every POTENTIALLY
critical system, then if follows that there are NO
critical systems. Hence, whether or not you can reach
breakers or fuses for any system is immaterial.
bakerocb
Posted: Sun Jan 03, 2010 8:32 am Post subject: Questions about circuit protection |
1/3/2009
Hello Again Matthew Schumacher, You wrote:
1) "Are you saying that if I put the fuses under the panel where they aren't
accessible then my airplane will still meet 14 CFR 91.205 (c) and that I
won't need to carry spares?"
Yes. That is exactly what the regulation is saying. If the pilot does not
have access, while in flight, to the location of fuses installed in the
aircraft's electrical system then there is no 91.205 regulatory requirment
to carry any spare fuses.
2) "I would read "that are accessible to the pilot in flight" to mean that
the fuse panel is accessible to the pilot,......."
That is correct.
3) "..........not the fusees since who cares if you can get to the fuses if
you can't get to the panel."
Again correct. Your reasoning, and the reasoning of the regulation, is that
if you cannot get access to the location of the fuses installed in the
electrical system while in flight then there is no reason for the pilot to
carry, and have access to, spare fuses while in flight.
Now the wise pilot would carry some spare fuses, as well as some other spare
items or tools (which can be discussed at length), so that he may perform
some limited trouble shooting / repair work if needed on the ground at some
away from home location in order to get back to home base or some other
location where he might be able to effect a more permanent repair.
PS: If one is designing and manufacturing a 14 CFR Part 23 type certificated
aircraft the regulations / requirements for fuse location in the aircraft's
electrical system are found in
Part 23.1357 (d) which says:
"If the ability to reset a circuit breaker or replace a fuse is essential to
safety in flight, that circuit breaker or fuse must be so located and
identified that it can be readily reset or replaced in flight."
But experimental amateur built aircraft are not required, per se, to comply
with 14 CFR Part 23.
If we build our experimental amateur built aircraft's electrical system in
accordance with the philosophy that things can fail and that we have a plan
B back up that will allow graceful degradation and continued safe flight to
an acceptable landing site then no fuse in our electrical system would be
"essential to safety in flight".
Time: 11:09:21 AM PST US
schu
user9253
Joined: 28 Mar 2008 Posts: 1940 Location: Riley TWP Michigan
Posted: Mon Jan 04, 2010 8:47 am Post subject: Re: Questions about circuit protection |
Schu,
No switch is shown for the Hobbs meter. I assume that an oil pressure switch will be connected in series with it.
The diode across the E-Bus relay is backwards.
The spike protection diode is missing from the dynamo relay coil. The arrow should point towards positive.
No over-voltage protection is shown for the main alternator. Over-voltage protection will do more towards safeguarding avionics than an avionics master switch.
Since there are only two devices connected to the avionics bus, an avionics bus is not needed. Just connect those two devices to the switch without having a bus. Better yet, use two switches. If one of the devices starts smoking, you can shut it off and continue to use the other. Wire the E-Bus diode directly to the main power bus without a switch. An avionics master switch makes it convenient to shut off all of the avionics at once. But when it fails, so will everything connected to it. In addition, individual downstream switches will not get exercised, leading to corrosion and eventual failure of seldom used switches.
Fuses offer better protection than circuit breakers. And fuses are less expensive. Yes, more than one load can be connected to a fuse or circuit breaker. But if one of the loads shorts out, it will blow the fuse and remove power from the other loads. It is better to install a larger fuse block so that each load can have its own fuse. Regulations for type certificated aircraft require that critical fuses be replaceable in flight. However, it is better not to have any critical equipment. Backup equipment makes critical devices non-critical. Fuses should be replaced on the ground, not in the air.
I like your schematic. What program do you use to draw it and to convert it a pdf?
Joe
_________________ Joe Gores |
Posted: Mon Jan 04, 2010 9:51 am Post subject: Questions about circuit protection |
Quote: | Wire the E-Bus diode directly to the main power bus without a
True with one minor exception. Assuming one adds an "avionics master switch"
in series with the normal feed path diode, it's still backed up by the
alternate feed path switch. So its addition doesn't offer an increased
risk for loss of the bus. Both the AV master and E-bus Alt Feed switches
will get operated once per flight cycle as a part of pre-flight . . .
so corrosion from dis-use is not a concern either.
Otherwise . . . well stated sir.
Posted: Mon Jan 04, 2010 11:28 am Post subject: Questions about circuit protection |
user9253 wrote:
Quote: |
Schu,
Joe
Joe,
Thanks for your helpful comments.
I would like to get an oil pressure switch for the hobbs (and for an
idiot light) but I don't know where to source that. I looked around at
Aircraft Spruce but didn't find anything. Do you know where I can find
this?
Thanks for finding the diode issues. I'll correct them in the drawing.
There is over voltage protection internal to the main alternator since
it is a plane power unit.
The schematic was written in visio with the aeroelectric stencil set:
http://www.lucubration.com/open-source-projects/aeroelectric-visio-symbols.html
Converting to pdf is a little bit more involved but not bad (right
Tim?). Simply install any postscript compatible printer (I like the
apple color laser PS models), then tell windows that the port used is
"save as file." When you print to that printer then it will prompt you
for a file name, call the file drawing.ps or whatever, then use a
postscript to pdf converter to make the pdf. A free online one is
http://ps2pdf.com . The advantage to doing it this way is postscript is
a vector based image not raster. This means that it isn't a 'picture'
as much as a set of points what the printer fills in (not unlike a cad
file.) This is why the file size is so small and why you can zoom in as
close as you want and the edges are still sharp. The pdf viewer can
re-render the image at any ratio.
Clear as mud?
schu
Posted: Mon Jan 04, 2010 11:59 am Post subject: Questions about circuit protection |
user9253 wrote:
Quote: | The spike protection diode is missing from the dynamo relay coil. The arrow should point towards positive.
Joe,
I looked at the dynamo relay coil but it is wired exactly as shown in
Z-25 and Z-13/8.
Bob, I would be very grateful if you could explain what the two diodes
are for on the self exciting SD-8 drawing since since they are wired
differently than the other relays.
schu
user9253
Posted: Mon Jan 04, 2010 12:02 pm Post subject: Re: Questions about circuit protection |
Schu,
Thanks for the info about using Visio.
As for an oil pressure switch, your engine needs an oil pressure port and the switch threads would have to match. I do not know where to buy it.
There was a recent discussion on AeroElectric about Hobbs meters. Read what others said:
http://forums.matronics.com/viewtopic.php?t=66204&highlight=hobbs
Joe
user9253
Posted: Mon Jan 04, 2010 12:25 pm Post subject: Re: Questions about circuit protection |
Quote: | I looked at the dynamo relay coil but it is wired exactly as shown in
Z-25 and Z-13/8. |
Schu,
It looks like I was wrong about the diode missing from your dynamo relay coil. The over-voltage protection probably shorts out any spike and thus the diode is not needed.
As for the two diodes, they isolate the two power sources from each other. The dynamo is one source and the other source is a combination of the battery and main alternator.
Joe
tim2542(at)sbcglobal.net Guest
Posted: Mon Jan 04, 2010 12:55 pm Post subject: Questions about circuit protection |
Matt wont your EFIS track your hours for you? Maybe you don't need a Hobbs
at all. I know the GRT stuff does this, I believe it tracks engine and
flight time separately and automatically. I bet your AFS does as well.
Posted: Mon Jan 04, 2010 3:55 pm Post subject: Questions about circuit protection |
It does, but I want something more reliable than the EFIS, and it also
serves as total time which is nice, but your right, I can go without it.
schu
Posted: Mon Jan 04, 2010 6:07 pm Post subject: Questions about circuit protection |
Whenever this “fuses versus circuit breakers” discussion comes afloat, I always wonder why TC aircraft always used circuit breakers…
Carlos
[quote] --
Posted: Mon Jan 04, 2010 8:25 pm Post subject: Questions about circuit protection |
At 01:56 PM 1/4/2010, you wrote:
Joe,
Z-25 and Z-13/8.
Those are "steering" diodes that make power available
from either the battery or a spinning alternator to
get the relay to energize.
The relay doesn't need an coil suppression diode
with an OV module installed.
bakerocb
Posted: Tue Jan 05, 2010 5:38 am Post subject: Questions about circuit protection |
1/3/2010 -- 1/5/2010
Hello Bob Nuckolls, May I "Make your day by showing you where you are
wrong?"
You wrote (see your posting copied below):
"First, 14 CFR 91.205 doesn't apply to an amateur built airplane."
and
"....... but you have no obligation to consult these documents that apply to
type certificated aircraft only."
Those statements are not correct. Each experimental amateur built aircraft
will be issued an initial airworthiness certificate in accordance with FAA
Order 8130.2F (or the current version of that order). That airworthiness
certificate will include a number of Operating Limitations, written in
accordance with that order, that apply to that specific aircraft.
Per FAA Order 8130.2F the Operating Limitations will state: "After
completion of Phase I flight testing, unless appropriately equipped for
night and/or instrument flight in accordance with 91.205, this aircraft is
to be operated under VFR, day only."
That sentence means that if one is operating his aircraft at night or in
instrument conditions it must be equipped in accordance with 91.205. The
attached document will provide additional details on this subject.
Time: 10:38:19 PM PST US
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Questions about circuit protection
Quote: | Hold on, back the truck up. Are you saying that if I put the fuses
"un-certifiable".
Description: |
 Download |
Filename: |
ABEA_Minimum_Inst_Requirements_9.doc |
Filesize: |
35 KB |
Downloaded: |
412 Time(s) |
Posted: Tue Jan 05, 2010 7:04 am Post subject: Questions about circuit protection |
At 06:52 PM 1/4/2010, you wrote:
Quote: | Whenever this “fuses versus circuit breakers” discussion comes afloat, I always wonder why TC aircraft always used circuit breakers…
Carlos |
They didn't. The first airplanes to get electrical
systems at Cessna used fuses. They were cartridge
fuse holders with caps that could easily be dropped
on the floor and be difficult to find. When miniature,
low cost breakers came along, they offered a means
by which operational and environmental concerns
for the use of glass cartridge fuses could be
addressed.
It wasn't until the blade fuse came along that
environmental issues were resolved for re-considering
fuses in airplanes. It wasn't until we address the
ideas of failure tolerant system design that the
operational issues were resolved.
If the TC aircraft guys were so disposed, they
could do exactly what we're doing right now. But
regulatory inertia makes this unlikely to happen.
Bob . . . [quote][b]
Posted: Tue Jan 05, 2010 9:04 am Post subject: Questions about circuit protection |
At 07:15 AM 1/5/2010, you wrote:
wrong?"
Thanks for posting the review of instrumentation
requirements! With your permission, I'll post it
to aeroelectric.com and index it in the reference
documents section.
