Posted: Wed Dec 30, 2009 9:34 pm Post subject: Overhead map and panel lighting options |
I'm looking for some suggestions for overhead lighting. I have Dave
Saylor's mini console and would like to choose some lights to install in
it.
Stein and ACS have some swivel LED lights and they look good.
Perihelion goosenecks look interesting but not sure how they really look.
I assume dimming them would be a good thing but not mandatory. Or
switches are required.
I'm thinking a white light and a separate red or blue would the
solution. I've flown with red but never with blue. Not sure what the
trade-offs are.
BTW, I'm installing the 430W GPS antenna directly over the mini-console
with the cable going thru the center post. I'm also in the process of
installing 2 more GPS antenna (GRT & ADI) on the windshield lip so that
they will clear any paint. They will be angled slightly forward but I'm
thinking that will work well. All of those cables plus power for the
lights seems to be fitting in the center post.
What do you think?
Bill "ready for some NYE celebration" Watson
Posted: Wed Dec 30, 2009 10:19 pm Post subject: Overhead map and panel lighting options |
Bill Mauledriver Watson wrote:
<MauleDriver(at)nc.rr.com>
in it.
I'm building my own overhead console and going to use it to duct fresh
air overhead and a place to put overhead lights. I also looked at
Stein's lights. The base is reasonable, but the LED lights that fit are
$50!!! I'm probably going to order one base and see if I can't use a
$15 LED turn signal.
http://www.amazon.com/VOLVO-replacement-blinker-light-signal/dp/B000LL9W4I
| Quote: | I assume dimming them would be a good thing but not mandatory. Or
I'd definitely provide a switch for each light. Dimmable is a good idea.
| Quote: | I'm thinking a white light and a separate red or blue would the
trade-offs are.
Well, I found out that the magenta on a chart disappears with red
light! I plan on giving each seat a white light
| Quote: | BTW, I'm installing the 430W GPS antenna directly over the
mini-console with the cable going thru the center post. I'm also in
the process of installing 2 more GPS antenna (GRT & ADI) on the
windshield lip so that they will clear any paint. They will be angled
slightly forward but I'm thinking that will work well. All of those
cables plus power for the lights seems to be fitting in the center post.
What do you think?
I think you're on the right track.
Linn
Phil.Perry(at)netapp.com Guest
Posted: Wed Dec 30, 2009 10:25 pm Post subject: Overhead map and panel lighting options |
Bill "up too late" Watson,
Have you checked out these from Aveo Engineering? They have switches
and dimmers built directly into the light frame and use touch sensing
like the old iPods.
This one is a white/red combo:
http://www.aveoengineering.com/Aviation/Airplane_LED_Lights/cockpit_LED_
lights/EyeBeam_Touch/index.php
This one is a white/red/green/blue combo:
lights/EyeBeam_Touch_NVG/index.php
I'm not sure if they're available for sale yet, but it might be worth a
phone call just to check. I'm hoping to get serious about light
purchases at OSH this year, so if they aren't available - I hope they
are by OSH.
Phil
Posted: Wed Dec 30, 2009 10:33 pm Post subject: Overhead map and panel lighting options |
I put one each of Stein's swivel LEDs in the front edge or our console. I had to go back later and really slather up the securing nuts with flox to make them stay tight. No problems now, though. Nice and tight. They're dimmed by pots on the panel.
I recently put one of Van's $9 white LEDs pointing straight down in the same console. It runs off a little overhead toggle switch. I understand it'll run off a 9V battery, and it would be cool to have another position on the switch to select that, you know, just in case...
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Wed, Dec 30, 2009 at 9:16 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
I'm looking for some suggestions for overhead lighting. I have Dave Saylor's mini console and would like to choose some lights to install in it.
Stein and ACS have some swivel LED lights and they look good. Perihelion goosenecks look interesting but not sure how they really look.
I assume dimming them would be a good thing but not mandatory. Or switches are required.
I'm thinking a white light and a separate red or blue would the solution. I've flown with red but never with blue. Not sure what the trade-offs are.
BTW, I'm installing the 430W GPS antenna directly over the mini-console with the cable going thru the center post. I'm also in the process of installing 2 more GPS antenna (GRT & ADI) on the windshield lip so that they will clear any paint. They will be angled slightly forward but I'm thinking that will work well. All of those cables plus power for the lights seems to be fitting in the center post.
What do you think?
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
"_blank">www.howtocrimp.com
le, List Admin.
http://forums.matronics.com
Posted: Wed Dec 30, 2009 10:44 pm Post subject: Overhead map and panel lighting options |
Spruce has the Aveo lights for sale for $139 each (cough)...plus $9 for the faceplate and $5 for the sticky stuff to hold 'em on.
I kind of like the reassuring snap of a toggle switch.
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
On Wed, Dec 30, 2009 at 10:24 PM, Perry, Phil <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)> wrote:
[quote] --> RV10-List message posted by: "Perry, Phil" <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)>
like the old iPods.
are by OSH.
Phil
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Thu Dec 31, 2009 7:54 am Post subject: Re: Overhead map and panel lighting options |
I bought the Aveoflash position lights and overhead lights (eyebeams). I thought after seeing how cool the position lights were, I had to buy the eyebeams. They are not as cool as you think. Mine came from Aircraft Spruce and looked as if they had been demo models. The face plates were falling off and they looked like someone rubbed their finger up and down them a million times. Come to find out Aircraft Spruce sells the bezels and adhesive separate because I'm sure everyone who bought these wants to replace the bezels after a short period of use. They are also big, 3-1/16 diameter. I am now trying to find a place on Geoff's awesome carbon fiber overhead to fit them. I may put one up front and one in back, if I keep them. I called Aircraft Spruce about the Eyebeams' bezels, they are so good about returns. I had them send me two new bezels and adhesive (free) so I can replace mine that I haven't even used yet. I plan on buying some protective plastic material like the one on Iphones if using the lights.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Jim Berry
Posted: Thu Dec 31, 2009 9:49 am Post subject: Re: Overhead map and panel lighting options |
Bill,
I went with Stein's led lights; one for each seat. Based on the recommendation of an ophthalmologist friend who has a stable of 6 planes( C150, C180 on floats, Pitts S2, C421, Fuqua jet, Citation) I got the blue ones. His short explanation is that blue is better for seeing things inside the cabin( maps, charts, etc.) while red is better for seeing stuff outside.
The swivel on Stein's lights plus a dimmer makes for a very flexible lighting system.
Jim Berry
40482
N15JB
Posted: Wed Jan 06, 2010 11:40 am Post subject: Overhead map and panel lighting options |
I think I'm going to do the same. Sounds like you didn't use the base
but just threaded them directly with added flox for reinforcement. Got it.
Did you get the red ones? That's my plan. They are basic panel
illumination for anything unlit (not much that is).
The Aveos look sweet but a little too pricey. Some sort of cheap white
button unit like the Vans unit sounds right. I may just go for a
separate battery-only unit. for the backup. Then I'd have 2 dimmable
red units and an undimmed white unit.
That little console is working out nice. Nutserts work well for the
screwing. The 430W attenna goes in perfectly. Good position on the
plane, covered by the mini-console nicely. Good solution overall. I
may try to post a pic or two to the list.
Thanks.
Dave Saylor wrote:
| Quote: | I put one each of Stein's swivel LEDs in the front edge or our
Dave Saylor
AirCrafters LLC
140 Aviation Way
831-722-9141 Shop
831-750-0284 Cell
install in it.
really look.
the trade-offs are.
the center post.
What do you think?
le, List Admin.
