naumuk(at)windstream.net Guest
Posted: Tue Dec 22, 2009 3:25 pm Post subject: Prop choice |
All-
I'm interested in hearing about your prop choices for HDSs (Corvair or 100hp), size, type, pitch and performance. Thanks, and Merry Christmas!
Bill Naumuk
Townville, Pa.
HDS N601MG/Corvair 95%
Posted: Wed Dec 23, 2009 7:03 am Post subject: Prop choice |
Hi Bill,
70-inch, 3-blade, Warp Drive, 17-degree pitch, 130-mph.
Best advantage of the Warp Drive prop is being able to adjust from
15-degrees for learning to fly the plane, then progressively
adjust the pitch thru 16, and 17 degrees for a best cruise of 120 or
so. I think 3 blades are smoother and quieter. 2-blades are reported
to be more efficient, but if you pick the wrong pitch, it can be an
expensive mistake.
Bill Naumuk wrote:
| Quote: | All-
Merry Christmas!
Bill Naumuk
Townville, Pa.
z601c(at)anemicaardvark.c Guest
Posted: Wed Dec 23, 2009 7:52 am Post subject: Prop choice |
Larry, I'm not an aerodynamicist, but I was once told by one that the most
efficient number of blades was an infinite number. In other words, all other
things being equal, the more blades the better. I would suspect weight
eventually catches up with the advantage gained.
I'm out of my area of expertise, but intuitively, it sounds right.
On Wednesday 23 December 2009 09:01, LarryMcFarland wrote:
Hi Bill,
expensive mistake.
Bill Naumuk wrote:
> All-
> Merry Christmas!
> Bill Naumuk
> Townville, Pa.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Mathematics and alcohol do not mix.
Do not drink and derive.
jaybannist(at)cs.com Guest
Posted: Wed Dec 23, 2009 9:04 am Post subject: Prop choice |
Jim,
I'm not an aerodynamicist either, but I've been told the exact opposite -- that is that the most efficient propeller has only one blade (counterbalanced, of course), and that two blades are more efficient than three. Those big ole' warbirds nearly always had four, but I think that was to take advantage of the available power while respecting maximum blade length.
>From what I see, I think a lot of it has to do with whether the propeller is ducted or not. Obviously, ducted fans and turbojet engines have many, many blades. I have to believe that must be for a very good reason.
Jay Bannister
Posted: Wed Dec 23, 2009 10:51 am Post subject: Prop choice |
Actually there was a one bladed prop patented, built and sold in the 30's and 40's. I believe the idea is to minimize the turbulence that the blade see from the upstream blade.
Here are some pictures and original articles on the Everel single bladed
prop:
http://www.notplanejane.com/aeromatic.htm
http://www.notplanejane.com/everel.htm
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com
Sent: Wednesday, December 23, 2009 8:25 AM
Subject: Re: Zenith-List: Prop choice
Jim,
| Quote: | From what I see, I think a lot of it has to do with whether the propeller is ducted or not. Obviously, ducted fans and turbojet engines have many, many blades. I have to believe that must be for a very good reason.
Jay Bannister
-----Original Message-----
Sent: Wed, Dec 23, 2009 10:01 am
Subject: Re: Prop choice
| Quote: | --> Zenith-List message posted by: Jim Belcher <z601c(at)anemicaardvark.com (z601c(at)anemicaardvark.com)>
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.howtocrimp.com">www.howtocrimp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
jonbateman(at)HOTMAIL.COM Guest
Posted: Wed Dec 23, 2009 10:52 am Post subject: Prop choice |
On my first plane I had a 3 blade in-flight adjust IVO prop. It did two things for me. It was quieter and had better prop to ground clearence. After 100 hours I changed it to two blades for better performance. Also running behind a Rotax 503 it didn't sound as much as a flying lawnmower. My 601XL is going to be powered by a Lyc. O-290D. I know it is a little heavy but I can change out a few heavy items Prop C starter C alt. and mags and loose a lot of weight. I am tossing around either a three blade warp or 2 blade Ed Strerba wood prop. I have a freind that has owned two Sterba props on both a Soneri and Thorpe. He can't say enough good about them and plans it for his next project
Jon Bateman
Date: Wed C 23 Dec 2009 11:24:49 -0500
Jim C
I'm not an aerodynamicist either C but I've been told the exact opposite -- that is that the most efficient propeller has only one blade (counterbalanced C of course) C and that two blades are more efficient than three. Those big ole' warbirds nearly always had four C but I think that was to take advantage of the available power while respecting maximum blade length.
| Quote: | From what I see C I think a lot of it has to do with whether the propeller is ducted or not. Obviously C ducted fans and turbojet engines have many C many blades. I have to believe that must be for a very good reason.
Jay Bannister
bryanmmartin
Most turbofan engines, which are basically a gas turbine running a ducted fan, are producing thousands of horsepower. They need all those blades to make use of all that power. On a turbo jet engine, on the other hand, the blades you see in the intake have little to do directly with producing thrust, they just compress the air for the combustion process. The jet exhaust produces all the thrust. Pure turbojets aren't used much anymore, most "jet" aircraft use turbofans.
On Dec 23, 2009, at 11:24 AM, jaybannist(at)cs.com wrote:
| Quote: | Jim,
Jay Bannister
Bryan Martin, BSAE
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
bryanmmartin
Posted: Wed Dec 23, 2009 10:53 am Post subject: Prop choice |
Actually, the most efficient number of blades on a propellor is one. The more blades you have, the lower the overall efficiency. A single blade prop with a counterweight has actually been used on some aircraft. There is a recent self launching glider that uses one, the prop is designed to be folded back inside the fuselage while soaring. Of course, this is a very low power application. Two bladed props are the norm for small aircraft because it's the easier to implement. Instead of engineering a counterweight to counteract the forces of one blade, you just use two identical blades. It's also minimum number of blades that eliminates the off-center thrust of a single blade, so it runs smoother.
The main reason multi-bladed props are used is that, with more powerful engines it gets tough to get the prop to absorb the extra power and still have adequate ground clearance unless you add blades. A three blade prop can absorb the same power as a much longer two blade prop. Another reason for using a three blade prop where a two blade prop will do is that the three blade prop will run smoother and can greatly reduce propellor noise. Some aircraft make a gawd-awful racket on takeoff with a two blade prop due to sonic effects at the tips. Using a shorter three blade prop can greatly reduce the noise and keep the neighbors happier. And some people think a three blade prop just looks cooler.
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Bryan Martin
do not archive. |
On Wednesday 23 December 2009 10:24, jaybannist(at)cs.com wrote:
| Quote: | Jim,
length.
It has little to do with Zeniths, but Piper once tried a single blade prop on
the J3 with a couterweight. Their reasoning was yours: a single blade would
be better. For whatever reasons, things didn't work out. I doubt any of those
J3s survive today.
Do not archive.
Jim B Belcher
A&P/IA
n801bh(at)netzero.com Guest
Posted: Wed Dec 23, 2009 12:26 pm Post subject: Prop choice |
One blade is optimum,, two is faster, three is ALOT smoother,,,, Pick your poison.
Ben Haas
N801BH
www.haaspowerair.com
carlossa52(at)gmail.com Guest
Posted: Wed Dec 23, 2009 1:25 pm Post subject: Prop choice |
There's an interesting overview of this subject here:
[url=http://www.gnrtr.com/Generator.html?pi 11&cp=3]http://www.gnrtr.com/Generator.html?pi 11&cp=3[/url]
Carlos
klaus(at)utdallas.edu Guest
Posted: Wed Dec 23, 2009 3:02 pm Post subject: Prop choice |
Hi,
Recently I replaced the original 3-blade GSC propeller with a
2-blade composite Sensenich propeller. Both propellers are ground
adjustable,
but the Sensenich propeller is substantially more efficient. Pictures and
preliminary flight data are on the website
http://www.utdallas.edu/~klaus/Airplane/airplane.html
At 5400 rpm of the 80 hp Rotax, having done 1220+ hrs, the 601HDS
achieves 115kts = 132 mph. This with a climb setting, where max rpm in level
flight is somewhere between 5500 and 5600 rpm.
Adjustment of the Sensenich propeller is very easy since a center delrin
piece assures symmetric adjustment of the two blades, just the way
a constant speed prop does though not with delrin material.
Finally, the blades are extremely light, which is a big advantage for
geared engines.
Happy flying,
Klaus
