f.miles.tcp.833(at)clearw Guest
Posted: Tue Apr 11, 2006 11:21 am Post subject: Kitfox lll back presssure o stick |
Last fall I purchased a mdl. three and we are now getting around to trying
to fly it. Among the problems that we have encountered is that in level
flight there is an extreme back pressure on the stick. What would be the
best guess of the group is the problem? I have read that on approach there
should be a natural forward pressure but we find it to be more neutral than
anything. Frank
msm_9949(at)yahoo.com Guest
Posted: Tue Apr 11, 2006 12:16 pm Post subject: Kitfox lll back presssure o stick |
Could be a simple rigging problem. Is your elevator approximately neutral when the stick is? If not, I'd start by adjusting the rod ends for elevator push tube. I had the opposite problem on my first flight, had to keep stick forward in level flight. Shortened up the rod ends and now it's fixed.
anything. Frank
Marco Menezes
Model 2 582 N99KX
FLIER(at)sbcglobal.net Guest
Posted: Tue Apr 11, 2006 12:36 pm Post subject: Kitfox lll back presssure o stick |
Frank,
Are you saying you're having to hold back pressure to
keep the nose up in level flight? If so, lower the
leading edge of the horiz. stab a notch or feed in
some flaperon to see if you can trim out the nosedown
tendency.
Ted
--- Original Message ---
From: "Frank Miles" <f.miles.tcp.833(at)clearwire.net>
Subject: Kitfox lll back presssure o
stick
| Quote: | to fly it. Among the problems that we have
| Quote: | flight there is an extreme back pressure on the
| Quote: | best guess of the group is the problem? I have read
| Quote: | should be a natural forward pressure but we find it
Posted: Tue Apr 11, 2006 12:37 pm Post subject: Kitfox lll back presssure o stick |
Marco,
Adjusting the elevator push/pull will only change the
position of the stick hands-off. It won't change the
trim...
Ted
Subject: Re: Kitfox lll back presssure o
stick
<msm_9949(at)yahoo.com>
Frank Miles <f.miles.tcp.833(at)clearwire.net> wrote: -
-> Kitfox-List message posted by: "Frank Miles"
| Quote: | anything. Frank
Marco Menezes
Model 2 582 N99KX
_-
browse
Subscriptions page,
FAQ,
List
| Quote: | _-
| Quote: | _-
Admin.
| Quote: | _-
Posted: Tue Apr 11, 2006 4:24 pm Post subject: Kitfox lll back presssure o stick |
To clarify, I have to push forward. The natural pressure is for it to push
back and want to climb. I have not tried to correct with the flap control.
May be the answer? I also wants to roll right. We have adjust the wing to
try to correct this. Have not flown it since the adjustment so don't know if
that worked.
flier(at)sbcglobal.net Guest
Posted: Tue Apr 11, 2006 5:50 pm Post subject: Kitfox lll back presssure o stick |
Ok, it's forward pressure :
The flaperons probably aren't gonna correct that. They pitch the nose down.
You'll need to move your horiz stab up a notch or so. The roll may be
corrected with the wing wash-out.
Ted
kitfox91je(at)hotmail.com Guest
Posted: Tue Apr 11, 2006 7:02 pm Post subject: Kitfox lll back presssure o stick |
Frank..sorry i dont check all these messages anymore since i sold 91JE to
you but i should respond to your notes about the plane. I cant be sure that
something didn't come out of rig that long on the trailer but i'm assuming
the airplane still flies as given. If so...don't change a thing.
Adjusting the flap lever ..pulling it up will lower your pitch. You will
find that it also will increase lift...and therefore isn't the best trim
system anyones ever come up with. However, You shouldn't be feeling any
"extreme" pressures on the stick. Flying with your fingertips and a little
forward pressure though might be needed at higher end cruise speeds. At
approach speed you'll have to hold the nose up with backpressure...standard
for a fox3 as in the flying manual.
about the roll...remember that the earlier kitfoxes are closer to neutral
stability and need more rudder coordination than certifieds. That took me a
little to get comfortable with...especially with a round cowling. You'll see
that things will stay level with the rudder coordinated. If you get
together with some other foxers you'll see a lot of folks flying wing low.
Check out the ball, airspeed, pitch and flap lever first. Its not going to
feel like a 182 but you shouldn't be using more than light pressures to
correct. If not then best to have a look and see if something is bent.
Dan Johnson
[quote]From: "Frank Miles" <f.miles.tcp.833(at)clearwire.net>
Subject: RE: Kitfox lll back presssure o stick
Date: Tue, 11 Apr 2006 17:21:27 -0700
if
that worked.
Aerobatics(at)aol.com Guest
Posted: Tue Apr 11, 2006 7:24 pm Post subject: Kitfox lll back presssure o stick |
Well said, my KF 2 ( almost the same as a 3) felt a bit that way too, I
added a small trim tab to each elevator so I can fly hands off.....
Enjoy....
Dave
Michel
Posted: Tue Apr 11, 2006 11:21 pm Post subject: Kitfox lll back presssure o stick |
On Apr 12, 2006, at 2:21 AM, Frank Miles wrote:
| Quote: | I also wants to roll right. We have adjust the wing to try to correct
this
My model 3 also wants to roll right. I haven't adjusted the wing but
put a little aluminium plate on the left flaperon, as a trim. It works
fine.
Cheers,
Michel
kerrjohna(at)comcast.net Guest
Posted: Wed Apr 12, 2006 7:35 am Post subject: Kitfox lll back presssure o stick |
both of "fliers" suggestions appear to make the nose pitch down as does holding forward stick.
During the first year, well past the Phase One test period, I tweaked the rig of the wings for dihedral and roll to obtain hands of stability.
With regard to pitch: an interaction between the angle of attack of the stabilizer and the amount of rudder required for coordinated turns. Initially, we had it set for less angle of attack to provide a "carving action in the turn". As a result, measuring the angle of the flaperons upon landing showed that 11 degrees flap was required for straight and level at cruise (90ish) speed. When the stabilizer was raised to the top notch trim of the flaperon was zero at cruise (now closer to 100mph). But a more conscious control input of rudder was required, all of which we deemed to be preferred.
With the addition of fairings on the lift strut rod ends, joy struts, and stabilizer struts, and the elimination of carb heat in favor of separate filters we are now seeing 107mph/gps at 5200rpm.
The whole process of testing, thinking and adjusting, evaluating was very enjoyable.
John Kerr
Classic IV, 912UL
730 hours
-------------- Original message --------------
Ted
Posted: Wed Apr 12, 2006 9:16 am Post subject: Kitfox lll back presssure o stick |
Woops! John just clearly pointed out my reversal
below.
Pulling flaperons causes a pitch DOWN. So, flaperons
should work as trim if you're holding forward
pressure.
Glad it's Wednesday... :
Ted
stick
John Kerr
Classic IV, 912UL
730 hours
| Quote: | >
so. The roll may be
[quote]> corrected with the wing wash-out.
> Regards,
> Ted
Richard Rabbers
Joined: 09 Jan 2006 Posts: 114 Location: Benton Harbor, MI - USA
Posted: Wed Apr 12, 2006 10:45 am Post subject: Re: Kitfox lll back presssure o stick |
| Quote: | | Glad it's Wednesday... : |
the best day of the week..... FLYday.
Hoping to get there one of these days.
_________________ Richard in SW Michigan
Model 1 / 618 - full-lotus floats (restoration) |
