Dick Sipp
Posted: Sat Apr 08, 2006 8:01 pm Post subject: ELT Antenna |
Looking for some ideas on a location to mount the ELT antenna other than on top of the fuselage.
I am thinking about mounting on a corner plate where the top longeron meets the rear baggage bulkhead with the wire end secured in a cushion clamp.
Other ideas?
Dick Sipp
40065
10flyer(at)verizon.net Guest
Posted: Sat Apr 08, 2006 9:05 pm Post subject: ELT Antenna |
I put my ELT on the aft deck between the trim cables after I saw Vans' there. I have the antenna attached to the last bulkhead of the tailcone where the top skin ends, facing aft and protruding under the fiberglass intersection fairing. Works great, lasts a long time. Mark(40016) 50hrs
jesse(at)itecusa.org Guest
Posted: Sun Apr 09, 2006 3:03 pm Post subject: ELT Antenna |
We have done this and I think a lot of others also, because we got the idea from Randy. We mounted it on the tail under the fairing (the ELT, that is), and mounted the antenna in the rear bulkhead that the aft most tailcone top skin rivets to at the back. The antenna then is completely hidden by the fairing and invisible. Also, if the plan crashes, the tail is most often the part that is left in tact from what I have heard, so it will do its job better.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
I'm in Ecuador right now and should be back in the country by the end of May. You may call me at 352-505-1899 and leave a message that I can check from down here. Any I-TEC questions can be directed to the I-TEC office at 352-465-4545.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Sipp
Sent: Saturday, April 08, 2006 10:58 PM
Subject: ELT Antenna
Other ideas?
Dick Sipp
40065
dmasys(at)cox.net Guest
Posted: Sun Apr 09, 2006 5:33 pm Post subject: ELT Antenna |
I have mine mounted horizontally under the empennage fairing. Lots of RV'ers do it that way.
(See http://www.romeolima.com/RV8/Pictures/Mvc-447x.jpg )
Probably not ideal for signal propogation, but it turns out nothing is ideal, since any outside antenna has a chance of ending up under the plane and/or sheared off after the crash.
-Dan Masys
Quote: | From: "Richard Sipp" <rsipp(at)earthlink.net>
Date: 2006/04/08 Sat PM 11:57:42 EDT
Other ideas?
Dick Sipp
40065
JSMcGrew(at)AOL.COM Guest
Posted: Mon Apr 10, 2006 6:43 am Post subject: ELT Antenna |
Dick,
I put my ELT antenna in the right aft corner of the baggage compartment. I riveted a small .063 plate with a hole in it onto the .125" aluminum angle. I attached the antenna to that plate. I glassed an AN3 bolt onto the inside of the canopy top just above and used this to bolt on a cushioned clamp that secures the top end of the antenna. Since my ELT is just behind the baggage compartment bulkhead there, the antenna wire run is all of about 3'.
Jim "Scooter" McGrew
40134
Time: 09:01:47 PM PST US
of the fuselage.
Other ideas?
Dick Sipp
40065
jjessen(at)rcn.com Guest
Posted: Mon Apr 10, 2006 8:02 am Post subject: ELT Antenna |
Jim,
Might you have a picture or two of the install?
John Jessen
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Monday, April 10, 2006 7:41 AM
Dick,
40134
of the fuselage.
Other ideas?
Dick Sipp
40065
JSMcGrew(at)aol.com Guest
Posted: Tue Apr 11, 2006 10:49 am Post subject: ELT Antenna |
Attached is a picture of the antenna install. I just have a digest subscription, do pictures get forwarded out to the list?
-Jim McGrew
40134
Time: 09:02:26 AM PST US
Subject: RE: ELT Antenna
Jim,
John Jessen
_____
Dick,
40134
top
of the fuselage.
the
Other ideas?
Dick Sipp
40065
jsmcgrew(at)aol.com
Description: |
Filesize: |
22.13 KB |
Viewed: |
328 Time(s) |
Tdawson(at)avidyne.com Guest
Posted: Tue Apr 11, 2006 10:57 am Post subject: ELT Antenna |
Looks nice. Anyone want to comment on how well the signal can get through the cabin lid?
TDT
40025
Sent: Tuesday, April 11, 2006 2:49 PM
-Jim McGrew
40134
Jim,
John Jessen
_____
Dick,
40134
top
of the fuselage.
the
Other ideas?
Dick Sipp
40065
jsmcgrew(at)aol.com
Dick Sipp
Posted: Tue Apr 11, 2006 4:49 pm Post subject: ELT Antenna |
As posted last night, I talked to Airteck about this and they said there should be no problem with a vertically mounted antenna under fiberglass. They were concerned that a horizontal mounting under the rudder, as many have done on RVs, would seriously degrade the antenna.
Dick
40065
Posted: Tue Apr 11, 2006 6:36 pm Post subject: ELT Antenna |
Interesting. Who is Airteck?
Is your ELT 121.5 or 406 MHz?
TDT
40025
Dick Sipp
Posted: Tue Apr 11, 2006 7:04 pm Post subject: ELT Antenna |
Ah, sorry for the typo. The company is Artex Aircraft Supplies Inc., a
Chelton Co.
www.artex.com
The unit I have is the ME406 and is both 121.5 and 406.
Dick Sipp
40065
Posted: Tue Apr 11, 2006 7:27 pm Post subject: ELT Antenna |
That's a good data point - thanks. We are also planning a 406 MHz unit, so maybe we will copy your idea . . .
TDT
40025
From: owner-rv10-list-server(at)matronics.com on behalf of Richard Sipp
Sent: Tue 4/11/2006 11:04 PM
Subject: Re: ELT Antenna
Chelton Co.
www.artex.com
Dick Sipp
40065
Tim(at)MyRV10.com Guest
Posted: Tue Apr 11, 2006 8:22 pm Post subject: ELT Antenna |
Correction...... http://www.artex.NET
Chelton Co.
www.artex.com
Dick Sipp
40065
Posted: Tue Apr 11, 2006 8:27 pm Post subject: ELT Antenna |
You Chelton EFIS guys should have an Artex ELT and an S-Tec autopilot, since they all belong to the Chelton family!
TDT
40025
From: owner-rv10-list-server(at)matronics.com on behalf of Tim Olson
Sent: Wed 4/12/2006 12:21 AM
Chelton Co.
www.artex.com
Dick Sipp
40065
wcurtis(at)core.com Guest
Posted: Wed Apr 12, 2006 5:34 pm Post subject: ELT Antenna |
[quote]You Chelton EFIS guys should have an Artex ELT and an >S-Tec autopilot, since they all belong to the Chelton family! Tim, This is the second time you have made this statement, so I'm compelled to inquire. All my research indicates that the Chelton Group (Artex, Chelton Avionics, Comant, NAT, etc) and Meggitt (UK) Ltd. (Meggitt Avionics, S-Tec, etc) are NOT the same company. Also, D2A is NOT part of the Chelton group, they only have a dealer relationship with Chelton Flight Systems. Can you point me to the relationship between Meggitt (S-Tec) and Chelton? http://www.chelton.com/common/group_chart.asp Chelton has the EFIS SV line of EFIS, and Meggit has the MAGIC line (http://www.magic.aero/) of EFIS. William Curtis http://wcurtis.nerv10.com/
Posted: Wed Apr 12, 2006 6:58 pm Post subject: ELT Antenna |
I may have been overcome by the fumes off the new office carpet when I wrote that . . .
TDT
