dlm46007(at)cox.net Guest
Posted: Mon Dec 07, 2009 9:12 am Post subject: EFIS repairs |
Just a reminder to those making the EFIS decision. Consider the repair options of the EFIS you choose. I have had a couple of unsolicited reboots of one of my Chelton DU1s in-flight. The reversion to the PFD on the other display went as planned. I probably have a voltage dip but will trouble shoot locally. just for reference I checked with Chelton/Cobham regarding repairs. A simple check of no problem found is $650 flat rate. A simple minor repair is $1200 flat rate and a major problem is $2400 flat rate. Sounds like certified repair prices for experimental systems. Fortunately a lot of this computer equipment fails of infant mortality or lasts a very long time. Keep in mind the warranties and repair policies when selecting an EFIS.
Jim(at)CombsFive.Com Guest
Posted: Mon Dec 07, 2009 11:07 am Post subject: EFIS repairs |
FYI,There is supposed to be a diode on the Master relay. It is in Vans Web store and should be already included on currently shipping relays. But if you are already flying you will most likely not have the diode. AFS for one "REQUIRES" the diode. Apparently there is a pretty ugly voltage spike introduced on the power bus if you don't have it.Jim Combs (N312F - Flying 145+ hours)------------------------------------------------Just a reminder to those making the EFIS decision. Consider the repair options of the EFIS you choose. I have had a couple of unsolicited reboots of one of my Chelton DU1s in-flight. The reversion to the PFD on the other display went as planned. I probably have a voltage dip but will trouble shoot locally. just for reference I checked with Chelton/Cobham regarding repairs. A simple check of no problem found is $650 flat rate. A simple minor repair is $1200 flat rate and a major problem is $2400 flat rate. Sounds like certified repair prices for experimental systems. Fortunately a lot of this computer equipment fails of infant mortality or lasts a very long time. Keep in mind the warranties and repair policies when selecting an EFIS.
AeroElectric http://www.matronics.com/contribution
external link will open in a new window" target="_blank"
Posted: Mon Dec 07, 2009 11:18 am Post subject: EFIS repairs |
Here is a link:http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1260213107-202-72&browse=electrical&product=diodesJim C
partner14
Posted: Mon Dec 07, 2009 11:35 am Post subject: EFIS repairs |
Jim, I think I remember installing the diode.... but I want to ck and make sure.... will not be home for several days, but for me and anyone else with the need to know.... where should the diode be installed? Between switch and Efis?
Don McDonald
--- On Mon, 12/7/09, Jim(at)CombsFive.Com <Jim(at)CombsFive.Com> wrote:
Subject: Re: EFIS repairs
Date: Monday, December 7, 2009, 11:05 AM
FYI,
_blank rel=nofollow>www.aeroelectric.com
/" target=_blank rel=nofollow>www.buildersbooks.com
=_blank rel=nofollow>www.homebuilthelp.com
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
40636 |
Bob Turner
Posted: Mon Dec 07, 2009 11:44 am Post subject: Re: EFIS repairs |
The diode goes on the Master relay, from the coil to the battery terminals.
_________________ Bob Turner
RV-10 QB |
Posted: Mon Dec 07, 2009 11:59 am Post subject: EFIS repairs |
I have diodes on the master relays; this voltage dip (?) rarely occurs but in flight after lock on. Chelton suggested that it may be a drop below 10V which causes the reboot. Since it is unique to a single PFD and causes no indication on the other MFD or the GRT Sport backup, I suspect something in the power or ground on the connector for the PFD; will check there first.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jim(at)CombsFive.Com
Sent: Monday, December 07, 2009 12:06 PM
FYI,
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Jim Berry
Posted: Mon Dec 07, 2009 1:42 pm Post subject: Re: EFIS repairs |
The diode protects against voltage spikes, not low voltage. If you need hardware repair on a Chelton unit, it might be worth checking with Brent Regan at www.regandesigns.com. He was the original developer for the Chelton unit (then Sierra) and it is my understanding that his son's do repairs. Might be a better price than Chelton gave you.
Jim Berry
40482
N15JB
Posted: Mon Dec 07, 2009 2:24 pm Post subject: EFIS repairs |
Thanks ; I will keep that in mind; I was aware of the Regan connection but
unaware of his son's involvement. My avionics is turned on by a toggle
circuit breaker; hence no coil and no spike from a expanding/collapsing
magnetic field.
