saolesen(at)sirentel.net Guest
Posted: Sun Dec 06, 2009 5:03 pm Post subject: Cold Engine |
I went flying yesterday when the temp was about 20 F. I was flying
LOP at about 60% power and had cylinders that were in the 250's and
oil at 140. The oil cooler has a cockpit actuated valve that
controls airflow to the cooler and it was fully closed. I know I
need to block the airflow into the engine. What's the best way to
accomplish this and how much reduction will be needed?
Sheldon Olesen
N475PV 127 hours
speckter(at)comcast.net Guest
Posted: Sun Dec 06, 2009 7:15 pm Post subject: Cold Engine |
This certainly isn't the most elegant way but duct tape off about 1/2 of the
inlet area on your cowl to start. If you get a warm day, peal off the tape.
If you want to spend the time you can build some aluminum baffles to mount
on the front of the inlet for a more elegant solution.
Gary Specketer.
