s.hamer(at)verizon.net Guest
Posted: Sat Dec 05, 2009 5:12 pm Post subject: It's a mystery to me |
The flap motor on my RV-6 was occasionally not wanting to run so I took it apart and cleaned up the excess grease per Van's instructions. All went well but when I put it back in the plane it was running backwards...down was up and up was down with the flap switch. I didn't switch the wiring because I had a two wire plug that only goes one way. I changed the wires to make it work correctly.
So, what did I do to the motor when I put it back together to make it run in reverse? I'm just curious.
Steve Hamer
RV-6 flying
Apple Valley, Ca
Posted: Sat Dec 05, 2009 7:20 pm Post subject: It's a mystery to me |
At 07:05 PM 12/5/2009, you wrote:
| Quote: | The flap motor on my RV-6 was occasionally not wanting to run so I took it apart and cleaned up the excess grease per Van's instructions. All went well but when I put it back in the plane it was running backwards...down was up and up was down with the flap switch. I didn't switch the wiring because I had a two wire plug that only goes one way. I changed the wires to make it work correctly.
So, what did I do to the motor when I put it back together to make it run in reverse? I'm just curious. |
Did you put witness marks on the end-bell that
holds the brushes? I believe this is a permanent
magnet motor. Simply installing the brush holders
180 degrees out of position has the same effect
as flipping the two wires. Similarly, the field
ring that mounts the magnets may have been clocked
180 degrees out.
How was grease getting into the motor? Normally,
there are no lubricants in a motor that put the
brushes/commutator at risk for contamination.
Gooey stuff on the comm is VERY hard on surface
life.
Bob . . . [quote][b]
Posted: Sat Dec 05, 2009 10:37 pm Post subject: It's a mystery to me |
Bob,
The brushes are housed in a unit that only goes on one way. I must have got the magnets in 180 out. There was a batch of these units that apparently had too much grease in the gear box and it somehow migrates past the o-ring that seals between the gear box and the motor. The current flap motors don't seem to have the problem.
Thanks for clearing up my mystery.
Steve
n8zg(at)mchsi.com Guest
Posted: Sun Dec 06, 2009 4:50 am Post subject: It's a mystery to me |
Bob –
This failure mode is common among the early flap motors. There was no seal between the motor and the lead-screw mechanism, and grease would eventually work into the motor housing. The design has changed, but the “fix” was a SB to disassemble / clean / reassemble.
Neal
life.
wgill10(at)comcast.net Guest
Posted: Sun Dec 06, 2009 7:15 am Post subject: It's a mystery to me |
I have the later version of the flap motor assembly and it too is prone to the same problem. After 500 hours, my flap motor became inoperative due to grease in the brush area. The disassemble, clean and reasemble process solved the problem.
Best regards,
Bill
RV-7 N151WP
Lee's Summit, MO
