kitfox 3
Goto page Previous  1, 2, 3, 4, 5  Next
skyflyte(at)comcast.net
PostPosted: Thu Dec 03, 2009 6:06 pm    Post subject: kitfox 3 Reply with quote
OOps, I haven't posted lately, but I live in S. Berwick, ME, and my Kitfox was born at the Hampton Airport in NH, a great grass airport with lots of antiques and homebuilts.
hlang(at)bluewin.ch
PostPosted: Fri Dec 04, 2009 5:07 am    Post subject: kitfox 3 Reply with quote
Agreed, I also have put Stolspeed on my KF, bottom of horiz. stabilo and
wings.
Heinz
KF 4-1200, R582LC
msm_9949(at)yahoo.com
PostPosted: Fri Dec 04, 2009 9:27 am    Post subject: kitfox 3 Reply with quote
Elevator authority is definitely an issue with the Model 2. Has anyone ever tried a larger elevator on the 2 and, if so, to what effect?
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Thu, 12/3/09, dave <dave(at)cfisher.com> wrote:
Subject: Kitfox-List: Re: kitfox 3
Date: Thursday, December 3, 2009, 2:40 PM
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
I tried them I think an inch or two ahead of the hinge line parallel to the hinges. They did little for my IV . I have found they help alot on super cubs. The model 2 has less elevator effectiveness than a model IV so I would think they would see more benefit.
I think you guys should post some videos of how much better they work. I don't think a model 2 will be able to drag the tailwheel down the runway. My Model IV is marginal at doing it .
VG's do seem to have a few attributes. I have had them on my IV Kitfox for over 1000 hours and I have not removed them yet. I would like to alter some of the spacing and placement but it flys so damn well I just don't find it high on the priorities.
[quote="Fox5flyer"]Mike, how far back from the leading edge did you place them? Did you place them horizontal to the hinge line or did you follow the leading edge line?
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=276011#276011
nbsp; (And Get Some AWESOME FREE Gifnbsp;--> http:========================
Pat Reilly
PostPosted: Fri Dec 04, 2009 3:25 pm    Post subject: kitfox 3 Reply with quote
Marco, Have you got gap seals on that elevator? Hey guys, got my airworthy cert. today. The inspector noticed my flaperons aren't rigged properly. Right one doesn't go up as far as left one. I measured it there is a 10 degree difference. I'll have to adjust the rigging. I have to admit I haden't measured it. I put the bell crank level and hooked them up. I must have changed something when I replaced the bent push rod under the seat.
Pat Reilly
mod 3 582 Rebuild
Rockford, IL
On Fri, Dec 4, 2009 at 11:18 AM, Marco Menezes <msm_9949(at)yahoo.com (msm_9949(at)yahoo.com)> wrote:
[quote] Elevator authority is definitely an issue with the Model 2. Has anyone ever tried a larger elevator on the 2 and, if so, to what effect?
Marco Menezes N99KX
--- On Thu, 12/3/09, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
From: dave <dave(at)cfisher.com (dave(at)cfisher.com)>
Subject: Re: kitfox 3
To: kitfox-list(at)matronics.com (kitfox-list(at)matronics.com)
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
Deke Morisse
Mikado Michigan
Realtime Kitfox movies to separate  the internet  chatter from the truth
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
rliebmann(at)comcast.net
PostPosted: Fri Dec 04, 2009 6:13 pm    Post subject: kitfox 3 Reply with quote
I put the Speedster larger elevator on my Model 2 back in 1992 with great results.   ron N55KF
Sent: Friday, December 04, 2009 11:18 AM
Subject: Re: Re: kitfox 3
Marco Menezes N99KX
Deke Morisse
Mikado Michigan
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Lynn Matteson
PostPosted: Fri Dec 04, 2009 8:38 pm    Post subject: kitfox 3 Reply with quote
One of my flaperons goes further than the other, and I can guarantee
you that mine are rigged according to the book....Model IV. I can't
see how they could possibly move the same when the bellcrank is set
to 26° on one side and 32° on the other (as I recall the numbers).
If you set the bellcrank "level", that might be the problem, because
as I recall it, aren't the flap control arms set to different angles?
Maybe the Model 3 is different....
Congrats on the AC, Pat.
Lynn Matteson
Jabiru 2200, #2062, 818.9 hrs
Countdown to 1000 hrs~185 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
Pat Reilly
mod 3 582 Rebuild
Rockford, IL
On Fri, Dec 4, 2009 at 11:18 AM, Marco Menezes <msm_9949(at)yahoo.com>
effect?
Marco Menezes N99KX
benefit.
Deke Morisse
Mikado Michigan
truth
http://forums.matronics.com/viewtopic.php?p 76011#276011
"_blank">www.aeroelectric.com .com/"
="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/
contribution arget="_blank">http://www.matronics.com/Navigator?
Kitfox-List ttp://forums.matronics.com
Lynn
Kitfox IV-Jabiru 2200
N369LM
Pat Reilly
PostPosted: Sat Dec 05, 2009 9:37 am    Post subject: kitfox 3 Reply with quote
Hey KFer's I have the builders  manual for the Mod 3 but don't see flapperon rigging instructions. I have the mod 4 rigging instructions. Is the llapperon rigging the same. I thought I read that it was not. And, Lynn, I did set the flaperon bellcrank level so that is my problem if the 3 is rigged similar to the 4. My problem evolved because the pushrod from the forward bellcrank that runs under the seat had been damaged and the previous owner had built a new one. It wasn't installed and was too long with the flapperon central bellcrank level (which I assumed was correct). I sectioned about 1/2" out of it. Live and learn. I'll have to make a new push rod or extend this one back to original length.
Pat Reilly
On Fri, Dec 4, 2009 at 10:33 PM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
One of my flaperons goes further than the other, and I can guarantee you that mine are rigged according to the book....Model IV.  I can't see how they could possibly move the same when the bellcrank is set to 26° on one side and 32° on the other (as I recall the numbers).
If you set the bellcrank "level", that might be the problem, because as I recall it, aren't the flap control arms set to different angles? Maybe the Model 3 is different....
Lynn Matteson
[quote]Marco, Have you got gap seals on that elevator? Hey guys, got my airworthy cert. today. The inspector noticed my flaperons aren't rigged properly. Right one doesn't go up as far as left one. I measured it there is a 10 degree difference. I'll have to adjust the rigging. I have to admit I haden't measured it. I put the bell crank level and hooked them up. I must have changed something when I replaced the bent push rod under the seat.
Pat Reilly
mod 3 582 Rebuild
Rockford, IL
Marco Menezes N99KX
Deke Morisse
Mikado Michigan
"_blank">www.aeroelectric.com .com/" target="_blank">www.buildersbooks.com ="_blank">www.homebuilthelp.com _blank">http://www.matronics.com/contribution arget="_blank">http://www.matronics.com/Navigator?Kitfox-List ttp://forums.matronics.com
=======================ur Lists This Month --
9;s Terrific Free Incentive Gifts provided
he Builder's Bookstore www.buildersbooks.com
s.com/contribution" target="_blank">http://www.matronics.com/contribution
                             -Matt Dralle, Li    - The Kitfox-List Email Forum -
fox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List<      - MATRONICS WEB FORUMS -
=   --> h
thesupe(at)hotmail.com
PostPosted: Sat Dec 05, 2009 11:09 am    Post subject: kitfox 3 Reply with quote
The mixer controls for the flaperons are completly different on the model 3 to 4.  The 1-3 used a setup like the Avid Flyer C the 4 is a all new design.  Take care C  Jim Chuk  Avids C Kitfox 4  Mn
Date: Sat C 5 Dec 2009 11:31:40 -0600
Hey KFer's I have the builders  manual for the Mod 3 but don't see flapperon rigging instructions. I have the mod 4 rigging instructions. Is the llapperon rigging the same. I thought I read that it was not. And C Lynn C I did set the flaperon bellcrank level so that is my problem if the 3 is rigged similar to the 4. My problem evolved because the pushrod from the forward bellcrank that runs under the seat had been damaged and the previous owner had built a new one. It wasn't installed and was too long with the flapperon central bellcrank level (which I assumed was correct). I sectioned about 1/2" out of it. Live and learn. I'll have to make a new push rod or extend this one back to original length.
Pat Reilly
On Fri C Dec 4 C 2009 at 10:33 PM C Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
One of my flaperons goes further than the other C and I can guarantee you that mine are rigged according to the book....Model IV.  I can't see how they could possibly move the same when the bellcrank is set to 26° on one side and 32° on the other (as I recall the numbers).
If you set the bellcrank "level" C that might be the problem C because as I recall it C aren't the flap control arms set to different angles? Maybe the Model 3 is different....
Congrats on the AC C Pat.
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 818.9 hrs
On Dec 4 C 2009 C at 6:18 PM C Patrick Reilly wrote:
Marco C Have you got gap seals on that elevator? Hey guys C got my airworthy cert. today. The inspector noticed my flaperons aren't rigged properly. Right one doesn't go up as far as left one. I measured it there is a 10 degree difference. I'll have to adjust the rigging. I have to admit I haden't measured it. I put the bell crank level and hooked them up. I must have changed something when I replaced the bent push rod under the seat.
Pat Reilly
mod 3 582 Rebuild
Rockford C IL
On Fri C Dec 4 C 2009 at 11:18 AM C Marco Menezes <msm_9949(at)yahoo.com (msm_9949(at)yahoo.com)> wrote:
Elevator authority is definitely an issue with the Model 2. Has anyone ever tried a larger elevator on the 2 and C if so C to what effect?
Marco Menezes N99KX
--- On Thu C 12/3/09 C dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
Date: Thursday C December 3 C 2009 C 2:40 PM
[quote="Fox5flyer"]Mike C how far back from the leading edge did you  place them?  Did you place them horizontal to the hinge line or did you  follow the leading edge line?
Deke Morisse
Mikado Michigan
Desert C  in five years there'd be a shortage of sand."
Rotax Dealer C Ontario Canada
                             -Matt Dralle C Li    - The Kitfox-List Email Forum -
fox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List =   --> h
lectric.com
/">www.buildersbooks.com
ebuilthelp.com
ronics.com
Chat with Messenger straight from your Hotmail inbox. Check it out [quote][b]
Lynn Matteson
PostPosted: Sat Dec 05, 2009 11:33 am    Post subject: kitfox 3 Reply with quote
Hi Pat-
I hope somebody can answer the question of whether the 3 and the 4
are the same in regards to rigging....I sure can't. But the 4 is
definitely rigged strangely. I just looked into my manual, and there
are two bellcranks....a flap bellcrank and an aileron bellcrank,
combined, and called the "Flap-Aileron Bellcrank assembly" in the 4
manual. That is, in the "original" 4 manual. I built my plane using
the original 4 manual, referring also to the Classic IV manual, which
called for slightly different angles (12° as opposed to 11.4°) In
frustration, I called Skystar and got it straightened out. They had
changed the angle but the part numbers remained the same for the
bellcranks, so it was a matter of them discovering something that led
to the angle change, and not a part change. All this is to say that
you'd better be finding rigging instruction for your *exact* model
plane....maybe even down to the color of your exact plane....well,
that may be stretching it, but you get the point.
And while you're at it, look at the angle that the flap control horn
(I think that's what it's called...some of my pages are at the
hangar, not here) attaches to the control tube...the one that runs
the length of the flaperon, inside the flaperon. On the left side,
the control horn (on the 4, this is) hangs down at about a 10-15°
angle, while the right side is pretty straight. It is because of this
difference that the bellcrank must be set to the 26° and 32° angles
that I mentioned earlier, 26° being for the left side, according to
my manual for the Model 4. I say all this just to give you something
to think about while waiting for the "3 gang" to help you. If, in the
meantime, you find these bellcranks and horn angles to be like I just
described, then maybe the 3 and 4 are rigged similarly after all.
Lynn Matteson
Jabiru 2200, #2062, 819.7 hrs
Countdown to 1000 hrs~180 to go
Pat Reilly
On Fri, Dec 4, 2009 at 10:33 PM, Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Pat Reilly
mod 3 582 Rebuild
Rockford, IL
effect?
Marco Menezes N99KX
benefit.
Deke Morisse
Mikado Michigan
truth
contribution
Email Forum -
= --> h
Lynn
N369LM
Pat Reilly
PostPosted: Sat Dec 05, 2009 2:34 pm    Post subject: kitfox 3 Reply with quote
Lynn, Thanks for input. Jim Chuk says the mod 3 & 4 flapperon linkage are totally different. I thought I had heard that somewhere. My builders manual is at the hangar. I will look at it again, but I swear it didn't give detailed instructions as to rigging the flapperons. Mine was assembled when I got it except for the pushrod under the seats that I shortened by a 1/2". I'll have to pull the seat out and figure out what the hell is wrong. I bet if I lenghten that pushrod everything will line up.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Sat, Dec 5, 2009 at 1:27 PM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote] --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Hi Pat-
I hope somebody can answer the question of whether the 3 and the 4 are the same in regards to rigging....I sure can't. But the 4 is definitely rigged strangely. I just looked into my manual, and there are two bellcranks....a flap bellcrank and an aileron bellcrank, combined, and called the "Flap-Aileron Bellcrank assembly" in the 4 manual. That is, in the "original" 4 manual. I built my plane using the original 4 manual, referring also to the Classic IV manual, which called for slightly different angles (12° as opposed to 11.4°) In frustration, I called Skystar and got it straightened out. They had changed the angle but the part numbers remained the same for the bellcranks, so it was a matter of them discovering something that led to the angle change, and not a part change. All this is to say that you'd better be finding rigging instruction for your *exact* model plane....maybe even down to the color of your exact plane....well, that may be stretching it, but you get the point.
And while you're at it, look at the angle that the flap control horn (I think  that's what it's called...some of my pages are at the hangar, not here) attaches to the control tube...the one that runs the length of the flaperon, inside the flaperon. On the left side, the control horn (on the 4, this is) hangs down at about a 10-15° angle, while the right side is pretty straight. It is because of this difference that the bellcrank  must be set to the 26° and 32° angles that I mentioned earlier, 26° being for the left side, according to my manual for the Model 4. I say all this just to give you something to think about while waiting for the "3 gang" to help you. If, in the meantime, you find these bellcranks and horn angles to be like I just described, then maybe the 3 and 4 are rigged similarly after all.
Lynn Matteson
Pat Reilly
Lynn Matteson
Pat Reilly
mod 3 582 Rebuild
Rockford, IL
Marco Menezes N99KX
Deke Morisse
Mikado Michigan
=   --> h
vember is the Annual List Fund Raiser.  Click on
-=     * AeroElectric www.aeroelectric.com
omebuiltHELP www.homebuilthelp.com
http:/r generous support!
ronics List Features Navigator to browse
s.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Lynn Matteson
PostPosted: Sat Dec 05, 2009 3:01 pm    Post subject: kitfox 3 Reply with quote
I don't think that lengthening the pushrod will correct the 10°
difference between the flaps/ailerons. That difference (to me) points
to an error in setting the flaperons up initially. With the Model 4,
they have you build two devices that clamp around the flaps, and
establishes the neutral position, then the linkages are connected,
and so each flap *starts* at a neutral setting. Further "upstream" of
the flaps...that is, closer to the stick, and the stick itself is
further neutralized, and the angles of the bellcrank arms are set to
whatever angle the manual suggests.
Unless the Model 3 is WAY unlike the 4, the rigging should start with
setting the fuselage to level...side-to-side, and fore-and-aft...then
setting the stick to plumb (at least side-to-side plumb). I would
think that this initial setting should be the same for both models,
and then Lord knows where it goes from there, but I would also think
that a neutral flap should also be part of the rigging.
Lynn Matteson
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Lynn
N369LM
kenjrichter
PostPosted: Sat Dec 05, 2009 4:07 pm    Post subject: Re: kitfox 3 Reply with quote
I'm not sure if the flaperon problem has been solved yet but I do have the builders manual for my model 3 if this can be of any help I do know the flaperon controls changed completely from the model 3 to 4 the model 4 was improved to differential control meaning the flaperon moving up moves more than the one moving down helping with the adverse yaw problem so I would think the rigging is much different.
Ken Richter
Osceola,Wi
model 3 speedster
582/GSC prop/Grove gear
Pat Reilly
PostPosted: Sat Dec 05, 2009 4:27 pm    Post subject: kitfox 3 Reply with quote
Ken, Thanks for the info. Yes, I  the 3 & 4 model flapperon linkages are totally different. If you would look at your builders manual and see if it details the flapperon rigging, I would appreciate it. Mine is at the hangar. I looked at it and it only instructed you how to mount the flapperons. I couldn't find any rigging detail. I am the 4th owner, and that portion of the manual may have gotten misplaced along the way. Or maybe I'm just blind.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Sat, Dec 5, 2009 at 6:07 PM, kenjrichter <kenrichter(at)centurytel.net (kenrichter(at)centurytel.net)> wrote:
[quote]--> Kitfox-List message posted by: "kenjrichter" <kenrichter(at)centurytel.net (kenrichter(at)centurytel.net)>
Ken Richter
Osceola,Wi
model 3 speedster
http://forums.matronics.com/viewtopic.php?p=276386#276386
PostPosted: Sat Dec 05, 2009 4:46 pm    Post subject: kitfox 3 Reply with quote
Hi Lynn and Pat.  I have a few pics of the mixers one a 3 and 4.  The blue is the 4 C the other is a bit hard to see C but I'm sure Pat will recognize it as looking like his.  The picture of the 4 is when I had it on the trailer bringing it home C and the 3 project is when I was putting it on ebay.  It had been in a trailering accident  (wing came loose and unfolded and hit a sign) before I bought it C and I never did a whole lot with it other than rob parts off it (like the engine) for my first Avid.  Take care C  Jim Chuk  Avids C Kitfox 4  Mn
Date: Sat C 5 Dec 2009 17:56:24 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
to an error in setting the flaperons up initially. With the Model 4 C
they have you build two devices that clamp around the flaps C and
establishes the neutral position C then the linkages are connected C
the flaps...that is C closer to the stick C and the stick itself is
further neutralized C and the angles of the bellcrank arms are set to
Unless the Model 3 is WAY unlike the 4 C the rigging should start with
setting the fuselage to level...side-to-side C and fore-and-aft...then
think that this initial setting should be the same for both models C
and then Lord knows where it goes from there C but I would also think
Lynn Matteson
Jabiru 2200 C #2062 C 819.7 hrs
On Dec 5 C 2009 C at 5:29 PM C Patrick Reilly wrote:
> Lynn C Thanks for input. Jim Chuk says the mod 3 & 4 flapperon
> again C but I swear it didn't give detailed instructions as to
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford C IL
Get gifts for them and cashback for you. Try Bing now.
 Filesize:  51.33 KB
 Viewed:  29287 Time(s)
 Filesize:  257.68 KB
Pat Reilly
PostPosted: Sat Dec 05, 2009 6:17 pm    Post subject: kitfox 3 Reply with quote
Jim, Thanks. Yes the yellow one is like mine.The 4 model is totally different design.
Pat Reilly
On Sat, Dec 5, 2009 at 6:34 PM, Jim_and_Lucy Chuk <thesupe(at)hotmail.com (thesupe(at)hotmail.com)> wrote:
[quote] Hi Lynn and Pat.  I have a few pics of the mixers one a 3 and 4.  The blue is the 4, the other is a bit hard to see, but I'm sure Pat will recognize it as looking like his.  The picture of the 4 is when I had it on the trailer bringing it home, and the 3 project is when I was putting it on ebay.  It had been in a trailering accident  (wing came loose and unfolded and hit a sign) before I bought it, and I never did a whole lot with it other than rob parts off it (like the engine) for my first Avid.  Take care,  Jim Chuk  Avids, Kitfox 4  Mn
Date: Sat, 5 Dec 2009 17:56:24 -0500
Lynn Matteson
> Electroair direct-fire ignition system
> Pat Reilly
> Mod 3 582 Rebuild
> Rockford, IL
kenjrichter
PostPosted: Sat Dec 05, 2009 7:22 pm    Post subject: Re: kitfox 3 Reply with quote
Pat, I looked through my manual and I do have some info on flaperon rigging on page cf-18 it shows (flaperon neutral position rigging details) this page doesn't say which model it is but the figure looks like a model 3 wing and then on page cf-n-1 it has flaperon rigging instructions but its says model 4 on that page so this probably won't help you,my manual has different model numbers throughout the book not sure why this is.
Ken Richter
Osceola,Wi
model 3 speedster
dave
PostPosted: Sun Dec 06, 2009 4:13 am    Post subject: Re: kitfox 3 Reply with quote
Pat the tube that runs under your seat will only chenge stick position Left to right. You will get less travel one way now possibly.
I think the Model 3 mixer is the same as the model 2 unless it has been retrofitted to the mod 4 upgrade. If you you will have aileron differential.
Take some pics of what you got .
I have the model 2 and 4 manual her if you need them scanned or likely Mc Bean does as well.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Pat Reilly
PostPosted: Sun Dec 06, 2009 10:21 am    Post subject: kitfox 3 Reply with quote
Dave, Thanks for info. My linkage is definetly model 3. I will dig into it next week.
Pat Reilly
mod 3 582 Rebuild
Rockford, IL
On Sun, Dec 6, 2009 at 6:13 AM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
[quote]--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
http://forums.matronics.com/viewtopic.php?p=276437#276437
Pat Reilly
PostPosted: Sun Dec 06, 2009 2:38 pm    Post subject: kitfox 3 Reply with quote
Ken, I was at the hangar today. I pulled out the seat, extended the pushrod under the seat by about 1/4" using the rod end adjustments. Low and behold full alieron left and right has only between 1 to 2 degrees of difference. They originally had 10 degrees difference. Seems close enough to me. I didn't look at the manual to see if I might have the pages you cited. I will.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Sat, Dec 5, 2009 at 9:22 PM, kenjrichter <kenrichter(at)centurytel.net (kenrichter(at)centurytel.net)> wrote:
Ken Richter
Osceola,Wi
model 3 speedster
http://forums.matronics.com/viewtopic.php?p=276413#276413
kenjrichter
PostPosted: Sun Dec 06, 2009 7:17 pm    Post subject: Re: kitfox 3 Reply with quote
Pat, I'm glad you got it figured out if for some reason you do need some info from my manual I can fax it or copy and mail it to you, I've never really checked mine for travel it seems the flaperons have so much more authority than standard ailerons that you would probably never use full travel anyway but its good to have it set up right, I'm waiting to fly my plane with the new leading edge installed I have it ready now I just need time and weather to fly.
Ken Richter
Osceola,Wi
model 3 speedster
Page 4 of 5
