Fox5flyer Guest
Posted: Fri Dec 04, 2009 4:32 am Post subject: kitfox 3 (VGs) |
Thanks, Pat. The only thing that comes to mind with that arrangement is that my stab is the symmetrical airfoil shape, not flat like the 1/2/3. I wonder if they would still be placed the same, but that is probably something for the manufacturer to answer.
Good luck with your inspection. Being it's the FAA it should be a piece of cake. They're generally just interested in the paperwork.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
[quote] Deke, The supplier of my VG's recommended 1" infront of rear edge of horiz stab and parallel to the hingeline or rear edge of horiz stab. My horiz stab wasn't mounted yet so I didn't have to lay on my back. FAA is coming tomorrow for airworthiness certificate.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Thu, Dec 3, 2009 at 10:12 AM, fox5flyer <fox5flyer(at)idealwifi.net (fox5flyer(at)idealwifi.net)> wrote:
[quote] Mike, how far back from the leading edge did you place them? Did you place them horizontal to the hinge line or did you follow the leading edge line?
Deke Morisse
Mikado Michigan
pchristensen10(at)austin. Guest
Posted: Fri Dec 04, 2009 1:44 pm Post subject: kitfox 3 (VGs) |
I found a 3/4" Clear plastic Miller Corner Guard at Lowes for about $3-$4 for an 8' piece. One piece will do 48 +/- VG's and it's already bent into a 90.
Pete
