emrath(at)comcast.net Guest
Posted: Mon Nov 30, 2009 5:55 am Post subject: Mystery Washer |
Folks,
I'm in finally assembly of my RV-6A and have a couple AN970-516 washers
(sort of a "fender" washer). Can any -6A builder's advise me where these
are to be utilized? It seems to me the only -5 bolt is the one attaching
the rear spar to the fuselage spar carry thru fork; my drawings show using
AN960 washers in this application. Thanks for your assistance in advance.
Marty in Brentwood TN
david.nelson(at)pobox.com Guest
Posted: Mon Nov 30, 2009 6:56 am Post subject: Mystery Washer |
Hi Marty in Brentwood TN,
On the -7A's, I think these washers are used on the front axle to provide for a
slot of sorts for the nose gear fairing. Perhaps it's the same on -6A's.
/\/elson
~~ Lately my memory seems to be like a steel trap .... without any spring. ~~
On Mon, 30 Nov 2009, emrath wrote:
Folks,
mrobert569(at)hotmail.com Guest
Posted: Mon Nov 30, 2009 9:23 am Post subject: Mystery Washer |
As there are only two they may be the ones used on the wing leading edge to fuselage attaching point.
Mike Robertson
Das Fed
[quote] Date: Mon C 30 Nov 2009 08:53:35 -0600
To: rv-list(at)matronics.com
Subject: Re: Mystery Washer
--> RV-List message posted by: "David E. Nelson" <david.nelson(at)pobox.com>
Hi Marty in Brentwood TN C
On the -7A's C I think these washers are used on the front axle to provide for a
Regards C
/\/elson
~~ Lately my memory seems to be like a steel trap ... without any spring. ~~
On Mon C 30 Nov 2009 C emrath wrote:
> --> RV-List message posted by: "emrath" <emrath(at)comcast.net>
> Folks C
Hotmail: Trusted email with Microsoft's powerfu01/ ' target='_new'>Sign up now.
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Could they be for the wing leading edge/tank mount where the bolt is
adjusted to slide out of the bracket in an accident that pushes the wing
aft?
| Quote: | Folks,
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Tue Dec 01, 2009 8:38 pm Post subject: Mystery Washer |
Thanks for the idea Nelson, but my kit was prior to this mod for the nose
wheel. I've since order the updated parts and modified mine and I believe
the axle is a AN6 bolt not a AN5 but my plans are at the hanger.
Always great to hear from Das Fed :>), but I already checked this and the
leading edge tank to fuselage bolt is a AN4 so "NO JOY" here.
Great ideas of things to check, I'm still trying to sort this out.
Perhaps a call to Van's is in order.
Marty
Time: 09:23:02 AM PST US
Subject: RE: Mystery Washer
Mike Robertson
Das Fed
| Quote: | slot of sorts for the nose gear fairing. Perhaps it's the same on
-6A's.
Regards C
/\/elson
spring
> Folks C
> washers (sort of a "fender" washer). Can any -6A builder's advise me
> where thes
e
| Quote: | > are to be utilized? It seems to me the only -5 bolt is the one
> attachin
g
| Quote: | > the rear spar to the fuselage spar carry thru fork=3B my drawings
> show
using
| Quote: | > AN960 washers in this application. Thanks for your assistance in
> advanc
e.
| Quote: | > Marty in Brentwood TN
