raimo.toivio(at)rwm.fi Guest
Posted: Tue Nov 24, 2009 9:28 am Post subject: Safety improvement list |
Wau, Graham
are you talking about same man?
What a talent producer of Europa Enhancement Equipments!
If I still were in a building phase, I would obviously have liked to get those Wing Root Fairings by UFACI
(Uncle Fred´s Aviation Composite Industrial) LTD.
Now it is too late I am afraid (only one life I have).
But who knows, maybe there will be a future winter delay and nothing to do...how is that Fred?
Raimo OH-XRT from Suomi
Posted: Tue Nov 24, 2009 10:05 am Post subject: Safety improvement list |
Graham,
I did not. You wrote
"the rubber hose gets eroded every time it (a filter)
That was my point only.
If you change a filter let is say 5 to 10 times during rubber hose´s life time, they do not get eroded at all.
That is surely The Fact.
Quote: | It is possible to block the filter in one tank filling
That is of course true. I know it because I have been there.
But NEVER again. Why?
Because I am now a better pilot and
1) my tank is totally clean since that incidense.
2) there will never ever be any contaminants any more in my tank becauce
a) I use only carefully filtered (by me) unleaded autopetrol (Mogas)
b) I use only totally clean 100LL which is a self-evident truth (at least in Finland)
When refueling our planes we have to be very carefull !
For example it (Andair) does not help if we refuel JetA1...I mean it doesn´t make wonders.
I think Europa´s idea to use two parallel installed inline filters is good.
One for main and one for a reserve tank. It is reasonable.
And - BTW - those in-line filters are also checkable before EVERY flight.
I do it every 5 flight hours (like removing the upper cowling same time also).
Nice to change ideas with you, Graham.
Raimo OH.-XRT from Suomi
PS: should I take a photo from Rotax Original -type in-line filter?
Posted: Tue Nov 24, 2009 10:25 am Post subject: Safety improvement list |
On Nov 24, 2009, at 9:28 AM, Raimo Toivio wrote:
Quote: | If I still were in a building phase, I would obviously have liked to
Raimo,
The truth is that the fairings would be a relatively easy retrofit to
a completed aircraft during a season when flying is curtailed and a
workshop or hangar is available where you can rig and de-rig the
wings. One would, of course, have to surmount the psychological
barrier of getting out the Dremel, sandpaper, some resin, etc. and
going back to the painters.
(The stock XS wing root fairings, if installed per the manual, would
have to be removed on the upper surface of the wing aft of the spar.)
Flight tests with and without the fairings by Jeff Behrens on his
trigear show improvements in L/D of 11 to 14% at various airspeeds and
3.75% increase in rate of climb; if you're interested I would be happy
to send you the documentation; perhaps I should post it somewhere on
the Europa Builders website...yes, I will do that.
Aesthetics are pretty subjective, but IMHO, they do improve the
Europa's appearance.
Fred
Posted: Tue Nov 24, 2009 10:36 am Post subject: Safety improvement list |
Raimo Remember that the reserve side will be the most likley to
recieve any contaminant since that is where the filler is, so.........
should there ever be a major contaninant event when you switch to
reserve it just may not be quite so ready to provide fuel.
Bob Harrison .
Quote: | ----Original Message----
Date: 24/11/2009 18:04
Subj: Re: Safety improvement list
fi>
Quote: |
Graham,
> > is removed."
becauce
Quote: | a) I use only carefully filtered (by me) unleaded autopetrol
(Mogas)
Quote: | b) I use only totally clean 100LL which is a self-evident truth
good.
Quote: | One for main and one for a reserve tank. It is reasonable.
flight.
Quote: | I do it every 5 flight hours (like removing the upper cowling same
time also).
Posted: Tue Nov 24, 2009 5:25 pm Post subject: Safety improvement list |
Fred
can't argue with that! Very impressive performance results too, be nice
to see someone else confirm, I think Justin claims an improvement too
Graham
Fred
paul.the.aviator(at)gmail Guest
Posted: Tue Nov 24, 2009 8:57 pm Post subject: Safety improvement list |
Hi, I was wondering if Justin ever published his numbers. - Paul
On Tue, Nov 24, 2009 at 7:03 PM, Graham Singleton <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]--> Europa-List message posted by: Graham Singleton <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)>
Fred
can't argue with that! Very impressive performance results too, be nice to see someone else confirm, I think Justin claims an improvement too
Posted: Wed Nov 25, 2009 6:01 am Post subject: Safety improvement list |
Bob The Mosquito
I use regularly reserve side (to know it is usable).
The reserve side filter is always as clean as it was when new.
Believe me, my tank is clean and it will be so.
Posted: Wed Nov 25, 2009 6:37 am Post subject: Safety improvement list |
Raimo Toivio wrote:
Quote: |
Bob The Mosquito
Raimo
I assume you always filter fuel as it enters the tank? This is the only
way to be sure. I do not believe visual check of Purolator sis good
enough . Some debris is invisible when wet with fuel, bits of polythene
tank swarf for example.
regards
Graham
Posted: Wed Nov 25, 2009 7:00 am Post subject: Safety improvement list |
way to be sure.
Graham, I am sure!
I wrote 24.11. as follows:
Quote: | 2) there will never ever be any contaminants any more in my tank
becauce
(Mogas)
Thanks for care,
Raimo OH-XRT
Posted: Wed Nov 25, 2009 7:38 am Post subject: Safety improvement list |
Graham,
do not worry - we are all in the same boat eh plane.
Raimo
