naumuk(at)alltel.net Guest
Posted: Mon Apr 10, 2006 3:29 pm Post subject: Bolt spacing |
Here's one for y'all-
Getting ready to drill the gear box/slide holes for my HDS. Manual says "Maintain safe edge distance". Doesn't look like I can hold to the 2x diameter rivet distance with a 3/16" bolt, and there's no information I can find that gives the edge distance calculation for a bolt. No problem centering the hole to the slide flange, it's the ground side end I'm wondering about.
Posted: Mon Apr 10, 2006 4:10 pm Post subject: Bolt spacing |
Bill,
Once you've placed the box on the angles, mark centerlines so that for
A3 bolts,
you've enough distance to avoid the nut being drawn down on the inside
radius of the angle.
Ink mark the angle edge and check the nut for good position before
laying down centerlines on the box. Then
place the box back on the angles, match mark and remove to carefully
drill the holes in the box. Then match mark
and drill the angles. Once you've drilled two holes each side
successfully, put a bolt thru and drill the rest. The most difficult
were the holes that match thru the reinforcing angle, box and guide angles.
http://www.macsmachine.com/images/gear/full/gear-support-brackets-fitti.gif
http://www.macsmachine.com/images/gear/full/gfairingbrackets.gif
Assembly is the most fun though, putting the nuts on from the inside .
http://www.macsmachine.com/images/TJH/gearAW/full/gear-support-nut-holding-wr.gif
If the A3 holes aren't capable of having a 2x edge distance, center the
holes on the short sides of the angles anyway.
Larry
Bill Naumuk wrote:
Posted: Mon Apr 10, 2006 4:58 pm Post subject: Bolt spacing |
Larry-
I wasn't worried about the placement on the width of the slides, more
the distance to the end. I laid everything out, but haven't drilled anything
yet. Suppose I better take another look tomorrow.
Thanks.
Posted: Mon Apr 10, 2006 5:21 pm Post subject: Bolt spacing |
All-
Thought I was offlist to Larry- sorry.
Couldn't wait till tomorrow to measure. Looks like I'll be OK if I
locate to the inside of my existing lines, and the factory steel work is on
the money. Haven't found anything off more than .004".
