sarg314(at)gmail.com Guest
Posted: Thu Nov 12, 2009 2:41 pm Post subject: bleeding brakes? |
I will soon need to pour some brake fluid into my RV-6A and, I presume, to bleed the brakes. I've never done this on a car, let alone a plane. Can some one direct me to a web page that explains the process?
Tom Sargent, RV-6A final assembly.
Posted: Thu Nov 12, 2009 2:59 pm Post subject: bleeding brakes? |
No website, but my best advice would be to get someone from your local
EAA chapter (you should already be a member!!!) to help you do it the
first time. It's easy to end up with spongy brakes.
Lacking that, the simple and best way is to use a squeeze-type oil can
and force fluid through the bleed fitting on the brake cylinder. An
adapter with a short piece of hose on the master cylinder will allow you
to catch overflow in a container. Bleed one side, then the other.
Linn
thomas sargent wrote:
| Quote: | I will soon need to pour some brake fluid into my RV-6A and, I presume,
carlosh(at)structuralaz.c Guest
Posted: Thu Nov 12, 2009 3:37 pm Post subject: bleeding brakes? |
Here you go. http://www.vansairforce.com/community/showthread.php?t=33493&highlight=brake+bleeding
Carlos in AZ
thomas sargent wrote: [quote]I will soon need to pour some brake fluid into my RV-6A and, I presume, to bleed the brakes. I've never done this on a car, let alone a plane. Can some one direct me to a web page that explains the process?
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Carlos Hernandez <carlosh(at)sec-engr.com> (carlosh(at)sec-engr.com)
Structural Engineers Company
2963 W. Elliot Rd. - Suite 3
Chandler, AZ 85224
Phone: 480.968.8600
Fax: 480.968.8608
www.sec-engr.com
CONFIDENTIALITY NOTICE
The information in this email may be confidential and/or privileged.
This email is intended to be reviewed by only the individual or
organization named above. If you are not the intended recipient or
an authorized representative of the intended recipient, you are hereby
notified that any review, dissemination or copyingof this email and
its attachments, if any, or the information contained herein is
prohibited. If you havereceived this email in error, please
immediately notify the sender by return email and delete this email
from your system.[b]
johnciolino(at)comcast.ne Guest
Posted: Fri Nov 13, 2009 7:14 am Post subject: bleeding brakes? |
There was a recent thread (yesterday) on Vans Air force about brake bleeding complete with pictures. Take a look and I think it will answer your questions.
John Ciolino
RV-8 with 18 hours
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: Thursday, November 12, 2009 5:36 PM
To: rv-list
Subject: bleeding brakes?
Tom Sargent, RV-6A final assembly. | Quote: | | www.aeroelectric.com | 0123456789012345678
