dwilde(at)clearwire.net Guest
Posted: Thu Nov 12, 2009 2:12 pm Post subject: 701 Max Flap Extension Speed |
FYI 701 pilots:
This last weekend I was practicing short field takeoffs. I deployed the
flaps (have only one setting at 15 degrees) and had a good takeoff.
After the takeoff I got distracted by the radio or scenery or who knows
what and proceeded to fly to my first destination. After a couple of
minutes, I noticed that my trim tab did not seem to be working correctly
as it was not in the normal position for high speed cruise i.e. 90 mph.
Then it dawned on my that the flaps were still deployed and I was
cruising at 90 well over the flap extension limit of 65 mph. I slowed
the plane down, raised the flaps and everything returned to normal.
During the short time the flaps were deployed at high speed, the plane
did not exhibit any bad behavior. There was no flutter, shaking or
anything else alarming. On landing, I looked over the flaperons closely
and there was no signs of stress.
I am sure I am not the only one who has ever done this but I don't
remember seeing it here so I thought I would mention it.
Dan Wilde
lgold(at)quantum-associat Guest
Posted: Thu Nov 12, 2009 2:39 pm Post subject: 701 Max Flap Extension Speed |
Dan,
I think that we all have left the flaps extended at cruise speed and I hear
nothing about damaged gear caused by this. In fact I fly for hours at 70-MPG
when I'm with the slower planes in my club and keep about 10-degrees of
flaps so that the nose stays down for visibility.
FYI, I really like the Quality Sport Planes flap handle, which allows for
finger tip lowering to 5-10-15-and 20 degrees of flap.
Les
ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Thu Nov 12, 2009 4:57 pm Post subject: Re: 701 Max Flap Extension Speed |
Dan I'm impressed with your frank honesty. So many people today act lick it a great sin to be honest about making a mistake. I guess they don’t think they are lying when they refuse to admit a mistake. I’ve done it more than once and the dead give away to the mistake is I can’t get to normal cruse. She just seems slow and sluggish for the amount of power applied. I’m impressed you got to 90-MPH.
Rick
_________________ 701Driver
N35 26.700, W118 16.743 |
b.carl@sympatico.ca
Posted: Fri Nov 13, 2009 4:53 am Post subject: 701 Max Flap Extension Speed |
Dan
Been close to that point, without damage. For peace of mind I would closely
inspect everything in between the flap lever and the wing skin for wrinkles
in the area of the flapper attach points, with particular attention to the
control rod attach points near the fuselage.
I've added a yellow warning lite on my enunciator when flaps are down. In my
case it helps to counter the age/maturity factor.
Carl
jetboy
Posted: Fri Nov 13, 2009 1:47 pm Post subject: Re: 701 Max Flap Extension Speed |
Dan the specified flaps down speed has never been revised since the change to 1100lbs weight and max flap angle 16 degrees contained in the plans rev.4 so there should be a higher speed that is structurally safe, just that nobody has stated what it is.
The CZAW aircraft are placarded at 55 Kts because they operate in Europe meeting the BCAR-S rules at 1100lbs. (these are microlights in Europe and OZ / NZ rather than homebuilts/ experimental)
I have also had many occasions of flaps down overspeed, although with the Jabiru 2200 it wont cruise much over 55 Kt. With only 16 deg flaps down available, its easy to get 70Kts plus on approach, in this condition theres not much G load though. I inspected the entire control system for problems, nothing found. I did discover a rigging error where my flaps were set with approx. 4 degress reflex (that is they were at minus 4 when should have been 0 setting) and I think this occured when misreading the diagrams rather than any overload occuring) I now recheck regularly.
Ralph
_________________ Ralph - CH701 / 2200a |
ggower_99(at)yahoo.com Guest
Posted: Tue Nov 17, 2009 6:19 pm Post subject: 701 Max Flap Extension Speed |
Lets remember that the 701 is niknamed the air "jeep" as forgiving as the four wheeled original one...
Saludos
Gary Gower
701 912S
"If someone has ever owned an old Jeep, will understand" not the computer dependant new ones.
--- On Thu, 11/12/09, ricklach <rick(at)ravenaviation.us> wrote:
Subject: Re: 701 Max Flap Extension Speed
To: zenith701801-list(at)matronics.com
Date: Thursday, November 12, 2009, 7:57 PM
--> Zenith701801-List message posted by: "ricklach" <rick(at)ravenaviation.us (rick(at)ravenaviation.us)>
Rick
701Driver
http://forums.matronics.com/viewtopic.php?p=272532#27253= * The Builder's Bookstore www.buildersbooks.com= --> http://www.bsp; ========================http://www.matroni --> http:========================
