albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Wed Oct 28, 2009 1:10 pm Post subject: princeton fuel sending probe |
Anyone have a picture of how they mounted theirs? The one I received with my Grand Rapids EIS just has a rubber grommet. There are 5 holes around the outside of the sending unit but from what I can gather it is just a pressure fit in the tank with the rubber grommet... is this correct. If you use the screw holes with self tappers how do you seal it?
_________________ Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop |
rickofudall
Posted: Wed Oct 28, 2009 1:27 pm Post subject: princeton fuel sending probe |
Tony, I don't know if the Princeton is the same one Westach uses, but here's how I did mine. I do know that self tapping screws will not seal, learned that one the hard way.
Rick Girard
On Wed, Oct 28, 2009 at 4:10 PM, albertakolbmk3 <cheriebraun(at)xplornet.com (cheriebraun(at)xplornet.com)> wrote:
Quote: | --> Kolb-List message posted by: "albertakolbmk3" <cheriebraun(at)xplornet.com (cheriebraun(at)xplornet.com)>
Tony B.
Kolb MKIII C
Rotax 582
C Gearbox 3.00:1
WD 66" 3 Blade Prop
http://forums.matronics.com/viewtopic.php?p=269898#269898
le, List Admin.
Description: |
 Download |
Filename: |
Mounting_a_Westach_fuel_sender_on_a_plastic_tank.pdf |
Filesize: |
366.78 KB |
Downloaded: |
494 Time(s) |
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Wed Oct 28, 2009 1:53 pm Post subject: princeton fuel sending probe |
The rubber grommet only is correct for a top mount. I believe you can get a
copy of the installation instructions online. If not then I'll copy mine &
email them to you.
George
lcottrell
Posted: Wed Oct 28, 2009 4:23 pm Post subject: princeton fuel sending probe |
[quote] Anyone have a picture of how they mounted theirs? The one I received with my Grand Rapids EIS just has a rubber grommet. There are 5 holes around the outside of the sending unit but from what I can gather it is just a pressure fit in the tank with the rubber grommet... is this correct. If you use the screw holes with self tappers how do you seal it?
Tony B.
Tony,
I use the Princeton and have used the westach senders both of them with just the grommet. I haven't had any problems with either of them as far as the fuel is concerned. I have been using them that way for approx. 400 hours.
Larry C Oregon
HKS 66 hours
503 200 hours
447 287 hours[b]
