rickofudall
Posted: Wed Oct 28, 2009 6:10 am Post subject: cylinder nuts |
Mike, all, a little late to help with your engine, but it might save someone else some grief. Snap On Tools has torque adapters like the one pictured. They're available in metric sizes of 10, 13, 15, and 18 mm. Like all Snap On stuff they're pricey, $30 for the 13mm. On the other hand a 3300 lists for $16,500. Cheap when you consider what can go wrong. Snap on makes them so it's 2" (50.8 mm) between centers and includes formulas for calculating corrections in torque readings when the adapter is used in line with the torque wrench.
Rick Girard
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
56.21 KB |
10268 Time(s) |
info(at)flylightning.net Guest
Posted: Wed Oct 28, 2009 6:20 am Post subject: cylinder nuts |
Also called a “Crows-foot” wrench if ordering from other places.
Nick
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Richard Girard
Sent: Wednesday, October 28, 2009 9:10 AM
To: jabiruengine-list
Subject: JabiruEngine-List: cylinder nuts
Rick Girard
naftalih(at)hotmail.com Guest
Posted: Wed Oct 28, 2009 8:59 am Post subject: cylinder nuts |
The correct size is 7/16" C not 13 mm.
To: jabiruengine-list(at)matronics.com
Subject: RE: cylinder nuts
Date: Wed C 28 Oct 2009 09:17:07 -0500
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman';} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.ecxEmailStyle17 {font-family:Arial;color:navy;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.ecxSection1 {page:Section1;}
Nick
Sent: Wednesday C October 28 C 2009 9:10 AM
Subject: cylinder nuts
Mike C all C a little late to help with your engine C but it might save someone else some grief. Snap On Tools has torque adapters like the one pictured. They're available in metric sizes of 10 C 13 C 15 C and 18 mm. Like all Snap On stuff they're pricey C $30 for the 13mm. On the other hand a 3300 lists for $16 C500. Cheap when you consider what can go wrong. Snap on makes them so it's 2" (50.8 mm) between centers and includes formulas for calculating corrections in torque readings when the adapter is used in line with the torque wrench.
Rick Girard
-List">http://www.matronics.com/Navigator?JabiruEngine-List
ronics.com
ww.matronics.com/contribution
| New Windows 7: Find the right PC for you. Learn more. [quote][b]
rickofudall
Posted: Wed Oct 28, 2009 9:55 am Post subject: cylinder nuts |
Nick, this is a crow foot wrench, I did a search for a box end crow foot and found only one source, available only in a set and the drive was wrong for using a torque wrench with them. If you go to Sears and ask for a crow foot this is what you get, and as Mike experienced they don't work out too well. The first picture I posted is the torque adapter I bought to torque the heads on my Shovelhead Harley about 15 years ago. Always gives a correct reading and never rounded a head bolt. Do what you wish, it's a free country, but I buy tools as good as the project. Saves money and time in the long run to do the job right the first time.
Rick Girard
On Wed, Oct 28, 2009 at 11:51 AM, Naftali Horowitz <naftalih(at)hotmail.com (naftalih(at)hotmail.com)> wrote:
| Quote: | The correct size is 7/16", not 13 mm.
From: info(at)flylightning.net (info(at)flylightning.net)
To: jabiruengine-list(at)matronics.com (jabiruengine-list(at)matronics.com)
Subject: RE: JabiruEngine-List: cylinder nuts
Date: Wed, 28 Oct 2009 09:17:07 -0500
Nick
From: owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com) [mailto:owner-jabiruengine-list-server(at)matronics.com (owner-jabiruengine-list-server(at)matronics.com)] On Behalf Of Richard Girard
Rick Girard
14.66 KB |
10264 Time(s) |
Posted: Wed Oct 28, 2009 10:49 am Post subject: cylinder nuts |
The question than begs what is the project?
nick
Sent: Wednesday, October 28, 2009 12:44 PM
Subject: Re: JabiruEngine-List: cylinder nuts
Rick Girard
Nick
Rick Girard
New Windows 7: Find the right PC for you. Learn more. | Quote: | | ist" target="_blank">http://www.matronics.com/Navigator?JabiruEngine-Lista>http://forums.matronics.com | 01
rickofudall
Posted: Wed Oct 28, 2009 11:16 am Post subject: cylinder nuts |
In this case it's loosening and torqueing cylinder, or in my case, head bolts.
Rick
On Wed, Oct 28, 2009 at 1:47 PM, flylightning <info(at)flylightning.net (info(at)flylightning.net)> wrote:
nick
Rick Girard
Nick
Rick Girard
0 1
Posted: Wed Oct 28, 2009 12:52 pm Post subject: cylinder nuts |
Meant what aircraft are you building?
nick
Sent: Wednesday, October 28, 2009 2:16 PM
Rick
nick
Subject: Re: cylinder nuts
Rick Girard
Nick
Rick Girard
234567
89 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 0 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 1 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 2 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 3 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 4 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 5 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 6 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 7 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 8 | Quote: | | -List">http://www.matronics.com/Navigator?JabiruEngine-List | 901234567
rickofudall
Posted: Wed Oct 28, 2009 12:59 pm Post subject: cylinder nuts |
Oh, I have a Kolb Mk III that desperately wants a 2200.
Rick
On Wed, Oct 28, 2009 at 3:52 PM, flylightning <info(at)flylightning.net (info(at)flylightning.net)> wrote:
nick
Rick
nick
Rick Girard
Nick
Rick Girard
0 1
23 4
5 6 7
89 01 23 45 6 78 9 0
Posted: Wed Oct 28, 2009 1:55 pm Post subject: cylinder nuts |
Ok, it’s a good engine.
nick
Sent: Wednesday, October 28, 2009 3:59 PM
Rick
nick
Rick
nick
Rick Girard
Nick
Rick Girard
234
5 67
01234567890123456789
mhilderbrand
Posted: Thu Oct 29, 2009 1:34 pm Post subject: cylinder nuts |
Hey, Rick... and others. I will throw a link out there to a tool I made that works. Thanks to another fellow on this list!
Michael Hilderbrand
Derby, Kansas
Http://www.kansasflying.com
To: jabiruengine-list <jabiruengine-list(at)matronics.com>
Sent: Wednesday, October 28, 2009 9:09:35 AM
Rick Girard
