vshimsl(at)live.com Guest
Posted: Wed Oct 14, 2009 2:15 am Post subject: Flap motor - failure, prevention and request |
Hello C
Twenty hours on my RV-8 and the flap motor went south. Inspection reveals the wire insulation right where the wires enter the motor housing opened up (both wires) and shorted then broke. I suspect a lot of the intermittent operatio problems posted on the list are due to the wires internally breaking. The cleaning and reinstallation may temporarily cause the wires to reconnect thus masking the real problem.
Prevention recommendation:
Use some sealant to provide some strain relief where the wires enter the housing. Also loop the wire and attach it to the housing to move the flex point of the wire away from where the wires enter the motor C actually the black plastic brush housing.
The wires themselves do not appear to be teflon. Actually they appear to be quite cheap.
Van's want over $320.00 for this motor. My reaction is "I don't think so...".
If you open up the motor you will see that both wires go into a plastic brush housing. I will attempt to rewire this and report back success or failure.
Just in case my effort fails C has anybody tried to order just the internal plastic brush housing (with wires) from the motor manufacturer? If so could you share the details? Contacts? Price?
Thanks C
Vince H.
Idaho C Washington
RV8 N8432 (20 hours)
Your E-mail and More On-the-Go. Get Winrect/01/' target='_new'>Sign up now. [quote][b]
Jesse Laub
Posted: Wed Oct 14, 2009 1:38 pm Post subject: Flap motor - failure, prevention and request |
Hey Vince...and others,
I have a Flap Motor for an RV8, never used, was installed, tested and
removed. $200 plus shipping and insurance.
Also have a Flap Positioning System and Flap Control Circuit Board (to
control flaps through stick grip)
You can call 541-563-4475 or e-mail jesse(at)casco.net
Jesse Laub
Parting out RV8A project
Waldport, OR
Vincent Himsl wrote:
| Quote: | Hello,
the flex point of the wire away from where the wires enter the motor,
to be quite cheap.
so...".
success or failure.
Just in case my effort fails, has anybody tried to order just the
Vince H.
Idaho, Washington
now.
Speedy11(at)aol.com Guest
Posted: Thu Oct 15, 2009 2:26 pm Post subject: Flap motor - failure, prevention and request |
Vince,
I've heard of a lot of RV-8 flap motor failures, but never has anyone (that I'm aware of) investigated the reason for them - and certainly none have discovered the wiring problems you spoke of.
I am just reaching 20 hours on my RV-8A and I'm going to take your advice and strengthen the wiring. I took care to secure the flimsy wires when building, but I'm going to address the issue again.
Thanks for reporting your info.
Stan Sutterfield
| Quote: | Twenty hours on my RV-8 and the flap motor went south. Inspection reveals t
ect thus masking the real problem. |
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27563 Location: Livermore CA USA
Posted: Thu Oct 15, 2009 2:59 pm Post subject: Flap motor - failure, prevention and request |
At 03:15 PM 10/15/2009 Thursday, you wrote:
| Quote: | Vince,
Stan Sutterfield
Here are a couple of pictures of how I wired up my RV-8 flap motor. Notice how the attached red/black wires are secured to the motor with a couple of wire ties and that there is a generous service loop going into the connector. With this arrangement, there is never any movement of the wires going to the motor connector when the flap motor is moving. Seems like it should be pretty long-term durable...
RV-8 #82880 N998RV
http://www.mattsrv8.com
Adding Rubber Gaskets To Baffling...
119.52 KB |
9071 Time(s) |
117.52 KB |
9071 Time(s) |
_________________ Matt Dralle
rv8a2001(at)yahoo.com Guest
Posted: Thu Oct 15, 2009 6:11 pm Post subject: Flap motor - failure, prevention and request |
The usual reason for failures, at least years ago, was grease from the threaded shaft getting into the brushes. This issue is the first I have heard of.
Scott
RV-8a
--- On Thu, 10/15/09, Speedy11(at)aol.com <Speedy11(at)aol.com> wrote:
Subject: Re: Flap motor - failure, prevention and request
To: rv8-list(at)matronics.com
Date: Thursday, October 15, 2009, 3:15 PM
Vince,
Stan Sutterfield
| Quote: | http://www.matronics.com/Ntarget="_blank" href="http://forums.matronics.com">http://forums.matron - List
gt; |
chriswelsh(at)sbcglobal.n Guest
Posted: Fri Oct 16, 2009 12:23 pm Post subject: Flap motor - failure, prevention and request |
When I was installing the flap actuator, I could not get the bolts on the nylon bushing tight without the actuator binding. I ended up reaming the holes in the nylon blocks out to 5/16 and making some bushings. I also capped the top of the blocks with a piece of .06 aluminum. This allowed me to torque the bolts properly with no binding of the actuator. I have no idea if this will help the longevity of the flap motor, but it can't hurt. The motor was noticeably quieter with no binding as would be expected. The other thing I did was add two zener diodes back to back at the motor connector hoping to alleviate voltage spikes and arcing of the motor brushes. Again, no data yet as to whether or not this increases motor longevity but again it can't hurt.
Chris Welsh
Sent: Thursday, October 15, 2009 3:15:30 PM
Vince,
Stan Sutterfield
30.29 KB |
9063 Time(s) |
Posted: Sat Oct 17, 2009 5:21 pm Post subject: Flap motor - failure, prevention and request |
Chris,
Great info. I did something similar, but not to the extent you did. I'll relook those issues.
Stan Sutterfield
| Quote: | When I was installing the flap actuator, I could not get the bolts on the nylon
Chris Welsh
