mullokintyre
Posted: Sun Oct 11, 2009 11:40 pm Post subject: Alternator cooling |
Thanks Jim, its neither of those two - its the L60 belt driven alternator
that replaces the standard Auto alternator from the front of the engine..
I also have installed the SD-8 as a backup on the vacuum pad.
The documentation did not say anything about cooling for it either.
Mick
| Quote: | ________________________________ Message 6
_____________________________________
Time: 05:55:19 PM PST US
Subject: Re: B & C Alternator cooling
Which B&C unit are you installing----the SD-8 or SD-20? The SD-8 is
driven off the vacuum pump pad at the top right rear of Lycomings
accessory case and I think the SD-20 is also mounted there. They are
both PM units with external regulators provided. The SD-8 is happy
without any external cooling air provision. Don't "think" that is any
different for the SD-20.
Jim McCulley
Mick Muller wrote:
> <mmul6471(at)bigpond.net.au>
> Howdy All,
> I recently bought a B & C alternator for my RV and am installing it to
> replace the ole internally regulated automotive one. The old Auto type
> alternator
> required some fancy cooling work to bring blast air into the face of the
> unit. Of course no part of the existing set up will work with the B & C
> unit.
> To anyone who has fitted on or knows anything about them, do you also
> have to cool the B & CF unit??
> I was hoping that with its internal cooling fan going the right way, it
> would not
> need fancy cooling shrouds etc. I posted a question to B & C but have
> had no response from them as yet.
> Mick
Posted: Mon Oct 12, 2009 6:34 am Post subject: Alternator cooling |
At 02:25 AM 10/12/2009, you wrote:
That's because there are no installations on the
front of a Lyc where cooling has been identified
as a critical or even questionable issue. Hence,
nothing in the instructions about cooling.
( -Thomas Paine 1776- )
