DrHook
Joined: 06 Apr 2006 Posts: 13 Location: Knights Landing CA
Posted: Thu Apr 06, 2006 4:03 am Post subject: Rivet removal question |
I am doing a re-cover job on my firestar want to know if I should try and remove all the rivets that are used for the fabric tape on the ribs.
My question is should I leave them in, and just cover over them?
By leaving them in, I would have to put more on the new tape and it might compromise the strenght of the ribs.
By removing them, there will be rivet peices stuck in the middle of the ribs aluminum tubing.
I am leaning on removing and using the same holes to re-rivet the fabric tape.
Anyone have suggestions or have done a re-cover?
Also I found this rivet removing tool at Aircraft Spruce. Is this tool a must have? or can I just use a 1/8" drill and remove them?
Here is the link to the tool. Anyone use it?
Thanks in Advance, Chris
http://www.aircraftspruce.com/catalog/topages/rivetremoval.php
_________________ Kolb Firestar owner, Rebuild-Recover job at hand. |
Posted: Thu Apr 06, 2006 4:52 am Post subject: Rivet removal question |
Drill them out and reuse the same holes. No problem.
All old Kolbs have rivet ends in them. Except for when handling the
wings
for removal, etc, you will never notice them.
-BB
ribs.
fabric tape.
http://forums.matronics.com/viewtopic.php?p=26708#26708
biglar
Posted: Thu Apr 06, 2006 4:59 am Post subject: Rivet removal question |
I wouldn't leave them in. Drilling them out with a 1/8" drill will work
fine, but the rivets will tend to spin, and enlarge the hole a bit. John
Hauck built a tool to stop this that works very well. As I recall, he took
a piece of a hacksaw blade and ground the teeth off a section, then cut a
"V" in the end. Sharpen the V on one side, so that you can press it under
the head of the rivet and apply pressure while you drill. Be very careful
with *every* single rivet, so the bit doesn't jump and mar the aluminum.
Use light pressure, and a new, sharp drill bit. I think I remember this
correctly - some one else who isn't at SnF might remember a link to a
picture of it, or it may be in the archives. I also like to use a sharp
pointed snap punch to knock the broken stub out of each rivet before
drilling them. Makes it much quicker and more accurate.
Lar.
Larry Bourne
Palm Springs, CA
Building Kolb Mk III
N78LB Vamoose
www.gogittum.com
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
John Cooley
Joined: 10 Jan 2006 Posts: 17 Location: Lucedale, Ms.
Posted: Thu Apr 06, 2006 6:00 am Post subject: Rivet removal question |
Hi Gang and DrHook,
Just drill the old ones out. The aluminum fabric rivets don't spin nearly as
bad as the old steel or especially the ss rivets. The ss ones can be a real
pain in the butt. I have also recovered a Kolb and this is what I did with
no problems. Matter of fact, flew that very plane yesterday. First time I've
been up in a possum's....errr coon's age. Sorry Possum, have a hard time
differentiating between coons and possums.
Later,
John Cooley
_________________ Be Safe,
John Cooley |
Duncan McBride
![](images/avatars/13676828554407a57b28446.jpg)
Joined: 16 Jan 2006 Posts: 5 Location: Fort Myers, FL
Posted: Thu Apr 06, 2006 9:35 am Post subject: Rivet removal question |
Those are aluminum rivets and should drill out very easily. With a sharp new bit, you can drill at a slight angle to keep it from spinning and they should only take a moment to drill through.
-------------- Original message --------------
Lar.
Larry Bourne
Palm Springs, CA
N78LB Vamoose
www.gogittum.com
_________________ Mk III, 319DM |
ElleryWeld(at)aol.com Guest
Posted: Thu Apr 06, 2006 4:03 pm Post subject: Rivet removal question |
You can just use a 1/8 inch drill to remove the rivits and take the leading
edge or the trailing edge tube off and get the pieces out of the ribs or
another option it to send them to the end of the ribs and squirt a small ammount of
epoxy in to hold them from raddling around inside
I wouldnt concider covering over them it wouldnt look to good on a finished
wing
you can cash this in for what its worth [just some other options] for you
Ellery in Rebuilt Firestar
DrHook
Posted: Fri Apr 07, 2006 3:21 am Post subject: Re: Rivet removal question |
Thanks, Guys,
I will drill them out, I think the heads are wide enough where I can use a small pair of vice grips on them, to keep em from spinning and will still have room for drilling.
My supplies I ordered from Aircraft Spruce showed up yeserday. This weekend its all about workin on this baby.
At first I was a bit overwelmed with all the work, but now, I think I can, I think I can. Oh Hell, I know I can!!!
You guys are great. I sincerley appriciate the advice here. Mike, "planecrazzzy" was right, this is the forum to be at. I will keep you posted on the progress, & I am sure, I will need some more questions answered.
Again, Mucho thanks Fellas, Chris
