skin pimples
woxofswa
PostPosted: Sun Oct 04, 2009 6:00 pm    Post subject: skin pimples Reply with quote
As I was riveting my QB wing skin, my well meaning neighbor helped me buck some rivets. When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped, but unfortunately, the rags didn't get moved enough and sure enough, we ended up with a couple of skin "pimples" on the upper outer skin surface.
Is there a prescribed way to deal with said pimples?
I thought of maybe trying a spring punch and then superfil, but haven't tried that yet.
Thanks in advance.
Myron Nelson
Mesa, AZ
Flew May 10 2014
ricksked(at)embarqmail.co
PostPosted: Sun Oct 04, 2009 6:22 pm    Post subject: skin pimples Reply with quote
Tell the neighbor thanks but no thanks..... Pop them back in with a body hammer and fill them prior to paint....
Strasnuts
PostPosted: Sun Oct 04, 2009 6:24 pm    Post subject: Re: skin pimples Reply with quote
I'm sure there are better methods but I got every little bump and wave out of my skins by pushing the other end of a sharpie against the aluminum. Use the edge of the back of the marker (not a fine point). It is just soft enough plastic to work with the aluminum. Don't hammer on the skin unless you back it up with a lead shot bag or similar. If you back up the skin with something hard you will thin the aluminum and oil-can it. I think most people just make sure it is an innee and not an outee and fill it in before painting with filler.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
AV8ORJWC
PostPosted: Sun Oct 04, 2009 8:39 pm    Post subject: skin pimples Reply with quote
Kent White of OSH Metalworking Class fame has a technique for shrinking the material.  It would be considered advanced by some RV-10 builders.  There is a hammering technique to limit the additional stretch of material that is worthy of planishing before resorting to weight adding body fillers.
Wetsuit material laid inside the work area is a great line of defense for natural human occurances.
John Cox
Sent: Sun 10/4/2009 7:00 PM
Subject: RV10-List: skin pimples
[quote]--> RV10-List message posted by: "woxofswa" <woxof(at)aol.com> As I was riveting my QB wing skin, my well meaning neighbor helped me buck some rivets. When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped, but unfortunately, the rags didn't get moved enough and sure enough, we ended up with a couple of skin "pimples" on the upper outer skin surface. Is there a prescribed way to deal with said pimples? -------- Myron Nelson Mesa, AZ Emp completed, legacy build fuse in progress Read this topic online here: http://forums.matronics.com/viewtopic.php?p=266508#266508
planesmith(at)hotmail.com
PostPosted: Mon Oct 05, 2009 7:41 am    Post subject: skin pimples Reply with quote
If you are interested in pursuing this further Kent has a DVD at https://www.tinmantech.com/html/vid_basic_damage_repair_alu.php. Not all of the techniques are appropriate for working with 2024 aluminum C but some work very well.
Vern Smith #40324
Subject: RE: skin pimples
Date: Sun C 4 Oct 2009 21:31:47 -0700
John Cox
As I was riveting my QB wing skin C my well meaning neighbor helped me buck some rivets. When I do it myself I keep rags on the lower inside skin in case the bucking bar gets dropped C but unfortunately C the rags didn't get moved enough and sure enough C we ended up with a couple of skin "pimples" on the upper outer skin surface.
Myron Nelson
Mesa C AZ
Emp completed C legacy build fuse in progress
ky·èžÛ"ÍíÃÙÊ%¢½4ÓM4}§Ü7(º¸ž®w°r‹«‰ê÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷ 8^E]t.+-f¢”Z+ºmÃRÇ­…㶺'‰Ë ŠËEy«n­ë jø jÚ+¶†ë£ Ü;azf§È¸¬¶ëb–+bzË.r¬.+-RÒ¹»®*mЉ÷ ܆+ÞIæ«rèÂyhiÞÃk k£  ­7 øh¶‹!j·š�Ù®r®r¨­íÃÜ6¡­ç÷m§ÿðà š¶º'‰Ë¢oÍjø jÚ+E]t.+-†Ûiÿü0Âf­®‰ârÇ(›óZ¾(¶ŠÑW] ŠËkp÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷ ÀDãH %„S‘PÄ· &¦z Þj×(ž×§µ©l¡«ÚŠV›•ëâjØ^YæÅ¢»¦³p÷ ¨kyýÆÛiÿ÷è®é¬™«k¢xœ±Ê&†Ûiÿ÷è®é¬™«k¢xœ±Ê&ý­ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ=ÃÜ2â²Ð¨žÚânëb¢užm(­{pÓ…©äÊ‹Ÿ¢¼¨º¸�êèºË.¦š+·pÌjÛC­©ex¸¬´fŠ}ÃjÞpá¶Úÿ 0™«k¢xœ±Ê&ýÊ'¶¸›ºØ¨žm§ÿðà š¶º'‰Ë¢oÜ¢{k‰»­Š‰ÿkp÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷p÷öÿ~‰íþšÞýºËømš Hotmail: Powerful Free email with security by Micro='_new'>Get it now. [quote][b]
