dlm46007(at)cox.net Guest
Posted: Tue Sep 22, 2009 8:54 pm Post subject: Ice |
Any 10 encounters with ice that can be shared. I plan to take a late fall trip and might encounter. Having flown (reluctantly) some ice in my C177RG over the past 30 years, it would be nice to know how the 10 reacts with rime or clear?
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Sep 23, 2009 7:54 am Post subject: Re: Ice |
You probably won't like my answer since my 10 is not flying, but knowing if a plane (not made for icing) does kind of okay is probably best not knowing. There have been several Cirrus aircraft that was legal for inadvertent icing encounter and crashed from it. Now the new Cirrus are certified for known icing. I fly a Citation Jet for a company and maybe I don't know enough but you never can tell how much ice is going to accumulate on the aircraft. I personally believe it is a very hard question to answer and to try not to get in icing. If you think the plane will do okay in it, it may persuade you to stay in it. Having said all of that I have been in icing in a plane not made for it. I got out of it as soon as I could.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Wed Sep 23, 2009 10:45 am Post subject: Ice |
Having flown a Cessna in the Midwest (OK,MO,IL,IN) during all seasons. One
sets some ground rules. If one is going to fly during the winter in the
Midwest the aircraft is going to accept minimal icing or accept some very
hazardous VFR underneath. My rules are no continuous flight in icing
conditions. No flight near freezing rain. I do accept that I may have to
endure 3-5 minutes of climb in IMC to get on top. I may have to accept 3-5
minutes of ice on the approach. Of course the approach must be certainty
(well above minimums). I also refuse clearances that will take me into icing
until I am ready. SGF approach once offered a lower altitude at 30NM out. My
then current temperature was a +2C and the SGF surface temperature was -8C.
I refused the descent until vectored and cleared for the ILS approach about
7NM out). At 120KIAS to the marker and then 90KIAS, my exposure to ice would
be about 4 minutes. Conditions on the surface were 500 and 2. Yes I picked
up some ice during the approach but the runway was long the approach speed
was +20KIAS above normal landing speed. I now live in the mountainous west
where MEAs are very high and would guarantee icing in IMC except for a few
summer months. The rules out here are VFR underneath unless the freezing
levels are above freezing at the planned altitude.
thane
Posted: Thu Sep 24, 2009 3:35 pm Post subject: Ice |
One should never consider even being dispatched, if there were a chance for
icing conditions. I fly for a living and I would never fly my RV-10 near
ice. period
How many lessons do we need to look back at to understand it is not worth
the risk.
Just me 2 cents, fly safe and have fun
Thane States
321BY
_________________ Working on finish kit: I hate fiberglass!! |
Posted: Thu Sep 24, 2009 6:58 pm Post subject: Ice |
As an A&P I have examined/studied the TKS, boots and bleed air solutions to
the icing problem. The question is how much ice is too much. In the Midwest
in the winter, a pilot might as well put the aircraft in storage if they
only fly cross country in CAVU VFR in the mid western winter. As a CFII I am
not suggesting that anyone challenge a strong winter storm; I do know that
after the winter storm front passes that there is usually considerable
overcast conditions behind the front where the overcast may be relatively
low and may only be 1-2 thousand feet thick, Perhaps 1-2 minutes climb in
the RV10. If the temperatures are below freezing then the overcast will
probably contain rime ice which may or may not adhere to the aircraft. Once
on top the ice will begin to sublimate away even though the temperatures are
below freezing. A trip in the blue skies in smooth air is preferred over
bumping along under the overcast (probable limited visibility) with
potential of encountering some tall TV antennas. In OK there are two (1400
AGL and 1900 AGL) near Tulsa and three (all 1500 AGL) near the ILS into OK
city. So poking around VFR underneath can also be hazardous.
Lest we think that the heavy iron icing systems will save us; I can relate a
personal experience of a pilot mechanic from Mesa AZ about three years ago.
He was a pilot and mechanic flying a Aero commander twin turboprop with full
de icing boots into Cortez Colorado. The aircraft was certified for known
ice and he flew into icing in SW Colorado. The icing was severe and on his
approach into Cortez his circle to land maneuver produced a stall spin and a
crash near the airport. The SAR people found large amount of ice on the
airframe. On that same day, same time a corporate jet at the flight levels
encountered severe icing in the same area and made it to safety using its
anti ice/deice systems. It did experience over $1M of aircraft damage due to
ice striking the aircraft as the ice was leaving the aircraft
In the 1970s I was scheduled to leave JEFF CO airport north of Denver in the
winter. There was a major winter storm moving through. KS and MO had sleet
and freezing rain. My father was complaining about needing to get back to
work on Monday. He wanted to rent a car and drive to Peoria IL. I told him
we were not flying since I did not want to die today. The next day we left
and traveled East at about 11000 enroute. By MKC I could see the remnants of
an overcast below me at about 3000 MSL. Upon our arrival in the Peoria area
I informed my parents that we would probably pick up a little ice since we
had to descend through a thin overcast into 3MY. Upon landing I parked and
my parents deplaned. Mom said we did not get any ice. I took her over to the
wing and had her place her hand on it as the heat of her hand melted the
thin ice layer and water dripped on the ground.
My point: Systems will not save you; judgment will. If you are not going to
store the aircraft from October to April, then you will need to develop some
judgment about what is flyable and what is not. An IFR rating and the
ability to use it will be very helpful; ATC will give you any assistance you
request short of flying the aircraft for you if you are on an IFR clearance.
You may not get their attention if VFR unless you precede your call with a
MAYDAY. Study the 1228H accident last week. Look at the NTSB report; look
at the pilot data on the FAA files. Sometimes judgment develops from
anothers accident.
Strasnuts
Posted: Thu Sep 24, 2009 7:28 pm Post subject: Ice |
I've poked through fairly small clouds in the Citation over the Wasatch
Mountains over Utah and picked up enough ice to create snail trails past the
heated leading edge and cover the windshield despite the bleed air. The
windshield gets covered a lot of the time but the leading edges usually take
care of the ice on the wings. It took a short time to accumulate past the
leading edge in this circumstance and I sure as hell wouldn't want to be in
a plane without anti-ice or boots. This was during one hold on a gps
approach that was about three total minutes in the cloud. After I did my
missed, Salt Lake wanted me to go back to the hold and I told them unable
due to severe icing.
780 Hours
