henrysfork1(at)msn.com Guest
Posted: Mon Sep 21, 2009 9:24 am Post subject: Throttle change question |
I changed to the friction vernier throttle cable. Just cut it to fit. It does a good job.
Insert movie times and more without leaving Hotmail®. See how.
Pat Reilly
Posted: Mon Sep 21, 2009 5:20 pm Post subject: Throttle change question |
Dave, Why do you want to go from vernier to friction throttle?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Mon, Sep 21, 2009 at 9:16 AM, dave <dave(at)cfisher.com (dave(at)cfisher.com)> wrote:
[quote]--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
Has anyone changed the vernier style throttle in a Kitfox 2 to a friction style? And what one did you use ? ACS has ones listed but they start at 3 feet , can you just get a solid wire one and cut it shorter ?
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=264115#264115
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Float Flyr
Posted: Tue Sep 22, 2009 5:15 pm Post subject: Throttle change question |
Funny thing that... I kinda liked the Vernier throttle once I got used to
pushing the button to disengage the screw.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
cliffh(at)outdrs.net Guest
Posted: Tue Sep 22, 2009 6:16 pm Post subject: Throttle change question |
I put the push pull throttle with the friction lock on my 912ULS.
I also didn't like the strong spring pulling the throttle open so I replaced
the springs with lighter ones.
Still have to use the friction lock but it is much easier.
Floran Higgins
Helena, Mt
Speedster
912ULS
dave
Posted: Wed Sep 23, 2009 12:56 am Post subject: Re: Throttle change question |
THanks for the input on the throttle. I TH ink I will settle on this for owner
http://www.aircraftspruce.com/catalog/appages/a820.php
A-820 CONTROL 36" BLACK KNOB 05-09436 $50.50
They have 11 in stock locally here in Canada and I can cut to length.
Thanks again for inputs.
I have the vernier on mine and prefer it over the friction lock.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Dick Maddux
Posted: Wed Sep 23, 2009 4:12 am Post subject: Throttle change question |
I too went with the Vernier throttle because the friction adjustment would not hold the throttle position very well on the old one. I always had to tighten it. The Vernier was much better but on a few occasions I accidentally hit the center knob with the palm of my hand and ended up going around on a short strip as the engine went to full power because of the carb springs (Vernier disengagement)
I now have a counter balancing spring going from the throttle bell crank to a spot next to the Vernier attachment point at the throttle quadrant. It is a long automobile throttle return spring about 10 inches long. I now have a perfectly balanced system. I can push the Vernier button in and the throttle will advance very slowly or not at all. It's GREAT! just like a "normal" throttle system. Thanks to Lowell Fitt for this idea.
This particular solution will not work if you don't have the older bellcrank system but perhaps you could come up with something similar.
Dick Maddux
Fox 4
Milton,Fl
