jay(at)horriblehyde.com Guest
Posted: Mon Sep 14, 2009 12:15 am Post subject: Filter for Hand held devices |
Hi there Bob,
In your Aeroelectric Connection book/ manual you provide a circuit diagram for a ‘Dual Power Conditioner “ (Figure 16.4) where you provide part numbers for the diodes and inductor components. Would you be able to provide specifications for these instead? I tried to search Radio Shack for the inductor part number but had no luck; plus, we have no radio shack in South Africa so I need to be able to get the part by specification.. J
Jay
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Mon Sep 14, 2009 4:28 am Post subject: Re: Filter for Hand held devices |
Are you sure you need the filter? Most modern hand helds supplied with DC power input jacks and automotive cigar lighter power cords are already configured to live in the rough and tumble world of vehicular DC power systems. The discussions on filters and firewalls in the 'Connection are intended to illustrate SOLUTIONS to noise issues should such problems arise. It's not necessary or recommended that such devices be included as an expanded design goal.
Posted: Mon Sep 14, 2009 5:26 am Post subject: Filter for Hand held devices |
I think that I do need one; I am using a cigarette lighter type connection
to power an Ipod power supply. When I connect this to the Ipod no noise is
heard, but when I connect the Ipod to the radio/ intercom system I
immediately get a high pitched noise in the earphones. I separated the
power and signal leads and the noise stayed. I moved the power supply of
the cigarette/ Ipod charger directly to the battery and the noise stayed. I
will still try a twisted pair on the power supply to the radio/intercom but
it seems to me that the noise is generated by the Ipod charger so I thought
that a filter might do the trick. Perhaps even a ferrite bead on the
positive in to the radio will work.
The only other thing that I can think of is that the loop formed by the
plug->Ipod charger->Ipod audio out->radio/intercom is somehow causing the
problem; but how does one get rid of that loop- its intrinsic to the music
input?
So I am going to try all of these out but need the components for the filter
to give it a bash as well...
Posted: Mon Sep 21, 2009 12:37 pm Post subject: Filter for Hand held devices |
At 08:11 AM 9/14/2009, you wrote:
Okay, 'high pitched' is not alternator noise. It
MIGHT be an artifact of the dc/dc converter in your
ipod power adapter. Try first to power the Ipod internally
without the adapter. Does the noise go away? Try powering
the adapter fromits own 12 battery pack NOT connected to the a/c
in any way. A couple of el-cheeso 6v lantern batteries in
series a good diagnostic supply.
| Quote: | I separated the
input?
It's most likely to be a ground loop issue which will be
re-enforced or denied by the above experiments.
In any case, it's almost a certainty that filtering
is not solution for root cause.
We may have to incorporate an isolation transformer
where audio from your Ipod goes to one winding and
audio to the ship's system is taken from the other
winding. See:
http://www.radioshack.com/product/index.jsp?productId 103994
ianxbrown
Posted: Mon Sep 21, 2009 1:22 pm Post subject: Filter for Hand held devices |
Just for information of those on the list, I recently had a faulty 12V charger on an AV8OR. The manufacturer willingly changed it. The symptoms were more your conventional white noise type static, like a very weak radio signal - there when charging the AV8OR, gone when not. It interfered with radio reception in the car and in the aircraft. I'm not proposing it as the cause of the IPOD problem below, just a useful data point. Faulty chargers do indeed seem capable of generating interference but not, in my case, a high pitched noise.
Ian Brown
Bromont, Quebec
| Quote: | | Quote: |
| Quote: | The only other thing that I can think of is that the loop formed by the
input?
winding. See:
Posted: Mon Sep 21, 2009 8:32 pm Post subject: Filter for Hand held devices |
At 04:18 PM 9/21/2009, you wrote:
| Quote: | Just for information of those on the list, I recently had a faulty
The modern DC/DC converter technology has become smaller
and more efficient as the components became available to
operate at high and higher frequencies. The DC to DC
converters that we used in the Cessna Nav/Com 300 in 1965
ran at about 1 Khz . . . and had relatively benign
RF interference potential. That little nugget of electronics
that exists in the cigar lighter plug on your ipod or cell
phone charger probably operates at 1000 to 2000 times higher
frequency. These guys are much more likely to become
noise emitters in the AM radio band. I've had
several devices that I had to throw away and substitute
another brand.
( -Thomas Paine 1776- )
Posted: Mon Sep 21, 2009 10:16 pm Post subject: Filter for Hand held devices |
Thanks Bob,
That does make sense; I had isolated it to the dc/dc converter in the same
manner that you suggest here- by powering the device internally. I knew
that it wasn't alternator noise since I was running off the a/c battery
only. I then found out that the same noise has presented itself on another
installation that I did, so it couldn't be installation specific. There the
owner simply let the Ipod charge up and then disconnected it from the system
and played the music into the audio system using the Ipod internal battery.
I'll try and get an isolation transformer here and see what effect that has;
it is simply a transformer with a 1:1 winding ratio?
Jay
Posted: Tue Sep 22, 2009 12:22 am Post subject: Filter for Hand held devices |
Duh.. scratch that question- its says exactly that on the Radio Shack page;
just noticed now...
I'll provide some feedback when I get the transformer
