Mono Inner Tyre Failures
pjeffers(at)talktalk.net
PostPosted: Sat Sep 19, 2009 5:35 am    Post subject: Mono Inner Tyre Failures Reply with quote
Slime works very well to improve pressure retention. One reservation is that you have to be careful about the amount you add to Tri Gear nose wheels. I initially used the amount recommended and then got quite severe nose wheel shimmy on both take off and landing. Since removing most of the slime all has been well.
Pete Jeffers
