rveighta(at)comcast.net Guest
Posted: Wed Sep 16, 2009 4:52 pm Post subject: Louvers |
I guess I started the latest thread on louvers, so let me throw my two cents in: I installed them on my 8A after experiencing
high oil temps. Prior to the louvers, I was running 225 or so on a hot day. Now, I rarely see in excess of 190. So, then I built
an RV8 and having similar temperature issues, I installed a pair of louvers in it as well. Same results, oil temps went down
dramatically. The only problem with both the planes was getting the oil temps HIGH enough in winter (I solved that by making
blanks to install between the inside of the cowl and the louvers).
So, I can only say what worked for me. Maybe louvers won't work for you.
Walt
tracy(at)rotaryaviation.c Guest
Posted: Wed Sep 16, 2009 5:17 pm Post subject: Louvers |
Excellent! Direct before & after results with all else being the same is the best kind of data.
I'd be interested in exactly where you mounted the louvers. I've been assuming that on an RV-8 they would go on either side of the cooling duct 'trough' on the lower cowl. Is that where you put them? I'm assuming you used a pair of the Avery type louvers?
I'll be happy to deal with the low temperatures in winter.
Tracy Crook
On Wed, Sep 16, 2009 at 8:51 PM, <rveighta(at)comcast.net (rveighta(at)comcast.net)> wrote:
Walt
Posted: Wed Sep 16, 2009 5:50 pm Post subject: Louvers |
Tracy,
Have you seen the stuff on the CAFE web site?
http://cafefoundation.org/v2/main_home.php
Click the 'research' tab, then 'cafe reports', then 'local flow I, II, &
III.
II discusses louvers & 'bluff bodies'.
Tracy Crook wrote:
| Quote: | Excellent! Direct before & after results with all else being the same
Tracy Crook
for you.
Walt
Posted: Thu Sep 17, 2009 3:55 am Post subject: Louvers |
gyoung
Joined: 09 Jan 2006 Posts: 211 Location: Republic of Texas
Posted: Thu Sep 17, 2009 10:24 am Post subject: Louvers |
The sides might be better. I heard a report (I think it was an RV-10) that had bottom mounted louvers that did not help much but moving to the side did. The theory was that high AOA on climb pressurized the bottom of the cowling preventing the louvers from being as effective as they were in level flight. Something to consider.
Greg Young
[quote] From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tracy Crook
Sent: Wednesday, September 16, 2009 8:17 PM
To: rv-list(at)matronics.com
Subject: Re: RV-List: Louvers
Tracy Crook
Walt
johnd(at)wlcwyo.com Guest
Posted: Thu Sep 17, 2009 11:23 am Post subject: Louvers |
I had a problem with higher oil temps back in 2002.
I installed vortex generators at the aft end of the cowl opening.
This did wonders for my oil temp. and have never had any problems since.
John Danielson
Tailgummer(at)aol.com Guest
Posted: Thu Sep 17, 2009 12:23 pm Post subject: Louvers |
Ingenious, John! Did these have any effect on your CHT's?
John D'Onofrio
Posted: Thu Sep 17, 2009 12:57 pm Post subject: Louvers |
I thought the higher pressure on bottom of cowl might be a problem as well. Latest test would seem to verify that. I keep changing my mind about what to try first and settled on hinging the -8 cooling exit ramp on the bottom cowl and make it a movable cowl flap. I cut the ramp out starting about 15 inches in front of the aft edge. Before doing the movable flap I did a test flight with the big gaping hole (about 13 X 15") in the bottom cowl just to see what would happen. It ran about 15 degrees cooler than the stock cowl opening but nothing like the 60 deg. drop I got with the cowl off.
Checked out the CAFE data that Charlie suggested and have a few ideas from there I want to try as well.
Tracy
On Thu, Sep 17, 2009 at 2:23 PM, Greg Young <gyoung(at)cs-sol.com (gyoung(at)cs-sol.com)> wrote:
[quote] The sides might be better. I heard a report (I think it was an RV-10) that had bottom mounted louvers that did not help much but moving to the side did. The theory was that high AOA on climb pressurized the bottom of the cowling preventing the louvers from being as effective as they were in level flight. Something to consider.
Greg Young
| Quote: | From: owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com) [mailto:owner-rv-list-server(at)matronics.com (owner-rv-list-server(at)matronics.com)] On Behalf Of Tracy Crook
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Tracy Crook
Walt
| | Quote: |
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
Charles Heathco
Posted: Thu Sep 17, 2009 7:59 pm Post subject: Louvers |
John, could you give some details, maybe pix of those V G's? Charlie
Posted: Fri Sep 18, 2009 12:23 pm Post subject: Louvers |
As I recall, they did not have any effect on the CHT’s, but I could be wrong.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Tailgummer(at)aol.com
Sent: Thursday, September 17, 2009 2:20 PM
Subject: Re: Louvers
John D'Onofrio
| Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
Posted: Fri Sep 18, 2009 12:42 pm Post subject: Louvers |
I am sorry I don't have a photo.
All that I did was take some left over 0.020 aluminum angle and cut it about 1.25" long with an angle cut on one side.
I placed these at the aft end of the cowl (right before the exhaust) at about a 45 deg angle, about 1/2" apart at the leading edge of the vortex generators.
I only placed a total of 4 of these on the bottom of the cowl.
Looks like:
Aft end of cowl
_______________________
Hope this helps.
John Danielson
