rveighta(at)comcast.net Guest
Posted: Mon Sep 14, 2009 4:58 am Post subject: Engine Hesitation |
I have a Lycoming IO-360 in my RV8A which exhibits an engine hesitancy or "stumble" that is proving very difficult to diagnose.
This problem shows up when taxiing back in after a flight, and in an RPM range of 750-1300. In flight there is no evidence of a stumble,
and no stumble at initial start up, taxiing out for take off or during run-up. In other words, the engine only exhibits this behavior when it
is warm.
I have talked to some very knowledgable folks and have tried several things: (1) Reset the idle mixture, (2) removed and cleaned the
servo finger screen, (3) removed the nozzles and placed them in a cup of acetone, which was then placed in a sonic cleaner for about
an hour. After the nozzles were reinstalled, I test flew the plane and the stumble was gone. However, a subsequent test flight revealed
that although the engine was running much smoother, an occasional stumble was still there.
Additional facts:
Oil temps are normal (around 180 deg F)
Compression test is normal (all cylinders mid 70's)
I'm using a Catto 3 blade prop
Any and all suggestions you may have will be greatly appreciated.
Walt Shipley
Kellym
Posted: Mon Sep 14, 2009 5:59 am Post subject: Engine Hesitation |
This type of troubleshooting forces you back to basics. Air, spark, fuel
in right proportions at right time. When the engine is hot, vapor
bubbles in fuel lines are possible. Tight valve stem to guide
clearance(minor valve sticking) is possible. Coil faults can show up
with heat.
Stumbles are usually a mixture problem, but you don't say if it happens
with or without throttle movement. You don't say what time is on the
engine. My guess is either some fuel boiling in the injector lines or a
valve sticking, preventing sufficient mixture getting into the cylinder.
Have you done a SB188 valve wobble check? Spark problems are less likely
to be at low power and intermittent.
rveighta(at)comcast.net wrote:
| Quote: | I have a Lycoming IO-360 in my RV8A which exhibits an engine hesitancy
is warm.
Additional facts:
Walt Shipley
KCHD |
Posted: Mon Sep 14, 2009 6:16 am Post subject: Engine Hesitation |
Sounds like you may have a minor case of Vapor-Lock. Like others, increasing the fuel flow makes it go away. Have you tried running your boost pump to see if that helps? There's been some discussion about this in the archives.
mrobert569(at)hotmail.com Guest
Posted: Mon Sep 14, 2009 6:21 am Post subject: Engine Hesitation |
Walt C
have you tried checking for an intake leak. It can cause exactly what you are talking about.
Mike Robertson
Date: Mon C 14 Sep 2009 12:56:45 +0000
To: rv-list(at)matronics.com
Subject: Engine Hesitation
.ExternalClass p {;} I have a Lycoming IO-360 in my RV8A which exhibits an engine hesitancy or "stumble" that is proving very difficult to diagnose.
This problem shows up when taxiing back in after a flight C and in an RPM range of 750-1300. In flight there is no evidence of a stumble C
and no stumble at initial start up C taxiing out for take off or during run-up. In other words C the engine only exhibits this behavior when it
is warm.
I have talked to some very knowledgable folks and have tried several things: (1) Reset the idle mixture C (2) removed and cleaned the
servo finger screen C (3) removed the nozzles and placed them in a cup of acetone C which was then placed in a sonic cleaner for about
an hour. After the nozzles were reinstalled C I test flew the plane and the stumble was gone. However C a subsequent test flight revealed
that although the engine was running much smoother C an occasional stumble was still there.
Additional facts:
Thanks C
Walt Shipley
| Your E-mail and More On-the-Go. Get Windows Li/' target='_new'>Sign up now. [quote][b]
rickpegser(at)yahoo.com Guest
Posted: Mon Sep 14, 2009 8:44 am Post subject: Engine Hesitation |
walt
kelly is right. a little more info is needed . you need to do 97-3 from start to finish to check the fuel system. pressures are critical. what are your chts.
rick
--- On Mon, 9/14/09, Kelly McMullen <kellym(at)aviating.com> wrote:
| Quote: | From: Kelly McMullen <kellym(at)aviating.com>
Subject: Re: Engine Hesitation
Date: Monday, September 14, 2009, 6:57 AM
Air, spark, fuel in right proportions at right time. When
the engine is hot, vapor bubbles in fuel lines are possible.
Tight valve stem to guide clearance(minor valve sticking) is
possible. Coil faults can show up with heat.
if it happens with or without throttle movement. You don't
say what time is on the engine. My guess is either some fuel
boiling in the injector lines or a valve sticking,
less likely to be at low power and intermittent.
> is warm.
> Additional facts:
appreciated.
> Thanks,
> Walt Shipley
Forum -
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Posted: Mon Sep 14, 2009 12:15 pm Post subject: Engine Hesitation |
Mike, I'm not sure what you mean by checking for an intake leak. How do you go about doing that?
Walt
Posted: Mon Sep 14, 2009 12:44 pm Post subject: Engine Hesitation |
Kelly, you're so right. This kind of problem does force you back to the basics. To give you
a bit more info, the stumble doesn't occur when the throttle is pushed up; only at a steady
setting.
I have experimented with tie wrapping foam insulation around the injector lines from the
flow divider to the cylinders, but a test flight afterward revealed the problem was still there,
so it appears fuel vaporization is not the culprit.
Cylinder head temps are between 250-300 deg F on my Grand Rapids monitor.
Total time on the engine is 750 TTSN and 300 STOH, which included new valves.
I have not done a SB188 valve wobble test.
Thanks, Walt
Posted: Mon Sep 14, 2009 1:54 pm Post subject: Engine Hesitation |
Walt C
Try tightening all the clamps and bolts on the intake system from the oil sump to the cylinder head and do a visual check on the rubber connectors for condition. If everything appears ok then C very carefully C spray soapy water on the intake system while the engine is running. You won't see bubbles because it is sucking but the engine will stumble if it a big leak C or you will see EGT and cylinder head temp changes.
Date: Mon C 14 Sep 2009 20:05:03 +0000
.ExternalClass p {;} Mike C I'm not sure what you mean by checking for an intake leak. How do you go about doing that?
Walt
n8zg(at)mchsi.com Guest
Posted: Mon Sep 14, 2009 2:17 pm Post subject: Engine Hesitation |
Safest way is to connect the blower side of your shop vac to the intake and spray soapy water around all the joints looking for bubbles.Â
There are more adventurous methods, but they present serious risk to life and limb…
neal
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of rveighta(at)comcast.net
Sent: Monday, September 14, 2009 3:05 PM
Walt
welchvincent(at)hotmail.c Guest
Posted: Mon Sep 14, 2009 2:44 pm Post subject: Engine Hesitation |
Walt C
I know that it is off the subject but how did you end up with oil temps in the 180's? I also have an RV-8A with an IO-360-A1A and a Hartzell constant speed prop C I have one mag and one lightspeed ignition. On a warm day I will see 205 - 210 in cruise. The only time I see 180 is in the winter. My oil cooler is located behind #4 on the baffle. It has a 1" C-Channel stand off and is well sealed to the baffle. I have cleaned up as much as I can C the baffle seal is good as evidenced by CHT's in the low to mid 300's. I even cut about two inches off the bottom of the cowl to open up the exit a bit. How did you get 180's?????
Vince
is warm.
Additional facts:
Thanks C
Walt Shipley
rick.mcbride(at)me.com Guest
Posted: Mon Sep 14, 2009 3:40 pm Post subject: Engine Hesitation |
Vince,
Just as another point of reference, I have an IO360-A3B6D in my -8 with dual Lightspeed. It has a firewall mounted oil cooler (13 row if I recall). The plenum into the cooler has a butterfly valve. Without shutting the valve I rarely see temperatures about 200 degrees unless in a climb on a hot day. It's not uncommon that I have to close the valve partially to get temps to 180 or above. With the valve open on a warm day my temps are usually in the 170s.
Rick McBride
On Sep 14, 2009, at 6:28 PM, Vincent Welch wrote:
| Quote: | Walt,
I know that it is off the subject but how did you end up with oil temps in the 180's? I also have an RV-8A with an IO-360-A1A and a Hartzell constant speed prop, I have one mag and one lightspeed ignition. On a warm day I will see 205 - 210 in cruise. The only time I see 180 is in the winter. My oil cooler is located behind #4 on the baffle. It has a 1" C-Channel stand off and is well sealed to the baffle. I have cleaned up as much as I can, the baffle seal is good as evidenced by CHT's in the low to mid 300's. I even cut about two inches off the bottom of the cowl to open up the exit a bit. How did you get 180's?????
Vince
Date: Mon, 14 Sep 2009 12:56:45 +0000
From: rveighta(at)comcast.net (rveighta(at)comcast.net)
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
is warm.
Additional facts:
Walt Shipley
Your E-mail and More On-the-Go. Get Windows Li/' target='_new'>Sign up now. | Quote: |
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Posted: Mon Sep 14, 2009 4:00 pm Post subject: Engine Hesitation |
Vince, I too had temps above 200 F on warm days. That was before I installed louvered vents in the lower cowl. Now I have the reverse problem;
hard to get the oil temps up on cold days.
Walt
Posted: Mon Sep 14, 2009 5:59 pm Post subject: Engine Hesitation |
Are you using the cowl louvers also Rick?
Vince
Subject: Re: RV-List: Engine Hesitation
Date: Mon C 14 Sep 2009 19:30:56 -0400
Vince C
Just as another point of reference C I have an IO360-A3B6D in my -8 with dual Lightspeed. It has a firewall mounted oil cooler (13 row if I recall). The plenum into the cooler has a butterfly valve. Without shutting the valve I rarely see temperatures about 200 degrees unless in a climb on a hot day. It's not uncommon that I have to close the valve partially to get temps to 180 or above. With the valve open on a warm day my temps are usually in the 170s.
Rick McBride
On Sep 14 C 2009 C at 6:28 PM C Vincent Welch wrote:
| Quote: | Walt C
Vince
is warm.
Additional facts:
Thanks C
Walt Shipley
Hotmail: Powerful Free email with security barget='_new'>Get it now. [quote][b]
I was looking at the louvers also. I was holding that option as a last resort but it looks like I may have to go that way by next summer. Thanks for the info.
Vince
Date: Mon C 14 Sep 2009 23:54:17 +0000
.ExternalClass p {;} Vince C I too had temps above 200 F on warm days. That was before I installed louvered vents in the lower cowl. Now I have the reverse problem;
Walt
Bruce(at)glasair.org Guest
Posted: Mon Sep 14, 2009 6:22 pm Post subject: Engine Hesitation |
He means to check the intake riser seals where they exit the sump. The easiest way I know, is to spray each riser seal area with engine starter fluid while the engine is running at low idle. If the engine speeds up, you have a leak.
Bruce
www.Glasair.org [quote]
garrys(at)tampabay.rr.com Guest
Posted: Mon Sep 14, 2009 7:13 pm Post subject: Engine Hesitation |
Where can I get info on these "cowl louvers"?
Garry Stout
Posted: Tue Sep 15, 2009 12:14 am Post subject: Engine Hesitation |
Walt
you have already tried the shotgun approach to solve this problem. Without a logging engine monitor, i have to go back to the basics. As said before, it is air, fuel or fire.
you have yet to tell us how old this engine is.
you have played with the fuel side, this is not something you should do without the right tools. if you over lean these engines at max power you will be buying another one.
On the fire side i need to know what you have installed.
One the air side there could be any number of things that could be causing this.
The problem with any experimental airplane, is that it is an experimental airplane. They are all one offs. There is no decent customer support, since almost everyone builds them a little different.
rick
a+p/ia 25+ yrs.
--- On Mon, 9/14/09, Mike Robertson <mrobert569(at)hotmail.com> wrote:
[quote] From: Mike Robertson <mrobert569(at)hotmail.com>
Subject: RE: Engine Hesitation
To: "rv list" <rv-list(at)matronics.com>
Date: Monday, September 14, 2009, 2:50 PM
#yiv892795043 .hmmessage P
margin:0px;padding:0px;}
#yiv892795043 {
font-size:10pt;font-family:Verdana;}
Walt,
If everything appears ok then, very carefully, spray soapy
sucking but the engine will stumble if it a big leak, or you
Date: Mon, 14 Sep 2009 20:05:03 +0000
#yiv892795043 .ExternalClass p
Walt
Posted: Tue Sep 15, 2009 3:55 am Post subject: Engine Hesitation |
No I'm not. I suspect my temps are due to a larger cooler, which is probably not a viable option for you. The louvers sound like a good solution.
Rick
On Sep 14, 2009, at 9:58 PM, Vincent Welch wrote:
| Quote: | Are you using the cowl louvers also Rick?
Vince
From: rick.mcbride(at)me.com (rick.mcbride(at)me.com)
Date: Mon, 14 Sep 2009 19:30:56 -0400
Vince,
Rick McBride
| Quote: | Walt,
Vince
is warm.
Additional facts:
Walt Shipley
Hotmail: Powerful Free email with security barget='_new'>Get it now. | Quote: |
Posted: Tue Sep 15, 2009 5:06 am Post subject: Engine Hesitation |
Rick, thanks for sticking with me on this problem. To answer your questions, the engine is a 1978 IO-360 B4A. It is equipped with two
Bendix Magnitos (R) S4LN-30, P/N 10-51360-29 (L) S4LN-21 P/N 10-51360-37. I am using Unison Aviation plugs, UREM37BY.
Sparkplug wires are standard Lycoming.
Thanks again.....
Walt
khorton
Joined: 18 Jun 2006 Posts: 4 Location: Ottawa, Canada
Posted: Tue Sep 15, 2009 4:18 pm Post subject: Re: Engine Hesitation |
| rveighta(at)comcast.net wrote: | I have a Lycoming IO-360 in my RV8A which exhibits an engine hesitancy or "stumble" that is proving very difficult to diagnose.
is warm.
Fuel injected Lycomings quite commonly run rough at idle if the engine is hot, as the fuel vaporizes in the fuel injection lines from the "spider" to the fuel injectors (it may be vaporizing in the spider too, so simply insulating the injection lines might not be an adequate test). They run OK at higher power, as the pressure in the spider and those lines increases as the fuel flow increases. At higher power the fuel pressure is high enough to keep the fuel from vaporizing.
If this is the cause of your rough running, you might be able to improve things by switching to fuel injection nozzles from Air Flow Performance. They sell nozzles with many different diameters. Smaller nozzles require higher line pressure to get the same fuel flow, so this reduces the chances of fuel vaporizing at idle. If you go down this road, you need to be sure you are still getting enough fuel flow at take-off power. I don't know if you can just install these smaller nozzles and go flying, or if the fuel injection servo needs to be set up on a flow bench. Don at AFP would know.
_________________ Kevin Horton RV-8
Ottawa, Canada
http://www.kilohotel.com/rv8 |
