wingsdown(at)comcast.net Guest
Posted: Mon Apr 03, 2006 7:40 am Post subject: power to weight |
There has to be someone on the list smart enough to figure out what
each pound of weight does to performance. I guess what I mean is if an
engine weighs 50 pounds more but produces 50 HP more is is better or
worse than an engine that is 50 pounds lighter and make 50 HP less. You
know like a chart that has curves that show two lines that cross or
something. It would take the guess work out of engine selection
somewhat. I guess engine torque would have to be considered as well.
Would be nice to see don't you think?
Rick
john.marzulli(at)gmail.co Guest
Posted: Mon Apr 03, 2006 8:48 am Post subject: power to weight |
Rotax lists the power to weight ratio on their website.
http://www.rotaxservice.com/rotax_engines/rotax_912S.htm
On 4/3/06, wingsdown <wingsdown(at)comcast.net> wrote:
Rick
Posted: Mon Apr 03, 2006 8:54 am Post subject: power to weight |
Well what I mean is what that weight is worth cost in HP, or rather how
much HP does it take to carry a pound of weight over and above the
airframe weight. Kind of hard to express clearly.
Rick
ruebd(at)skymail.csus.edu Guest
Posted: Mon Apr 03, 2006 10:21 am Post subject: power to weight |
Rick
Unlike the other powered vehicles, such as cars, tractors,
boats, with aircraft the weight of anything that is part of the machine
is critical. For a boat it can actually be advantageous to have heavy
engines for the ballast that they contribute. Tractors benefit from
weight also, to a point. Cars will sacrifice handling to a heavy
engine, but if they are judged more on acceleration, then it works.
Dragsters certainly attest to that; but their trip is short.
The first thing that a heavier, more powerful engine has to
carry in an airplane is itself, so the first effect is to reduce the
payload, or useful load. A more powerful engine will also need a
larger, heavier propeller, more weight; not only does this offset the
benefit of having more power, it affects the balance, so now more weight
will be needed in the tail (assuming a conventional layout) to counter
the heavier engine and restore the balance. So now the total weight has
increased even more than by just the heavier engine.
The airframe is what holds all of the major components together
and each of them acts to stress it under turbulent or any high 'G'
maneuvering. The engine's mass is cantilevered out from the main
structure (fuselage) and is always acting to get away from the rest of
the machine by torque, thrust, and the mass that it involves when G
loading is a factor. So here we go again, now you need to beef up the
thrust frame and fuselage to take the extra weight hanging out there, so
now we are stuck with still more total empty weight.
When the thrust developed at cruise power equals the drag
produced by the sum of lift drag and the parasitic drag, the airplane
finds its cruising speed. Since a heavier engine adds weight, the lift
drag factor will be higher with it installed, and the parasitic drag may
also increase, due to a larger cowling or the cooling drag increase that
typically occurs.
Drag reduction is the best way to increase an airplanes speed.
This is borne out time and again by the performance figures of very
clean designs with modest power. On the other hand, airplanes with a
high drag coefficient, such as the Boeing Stearman will not cruise much
faster no matter what engine is doing the towing.
A simple chart to illustrate all of this is just not practical.
You have to take cases and evaluate them as they are defined. All
designs are nested tradeoffs, and this is especially true when they fly.
Small airplanes work best with reliable, not too heavy engines. This
has always been best achieved by using fairly large displacement, low
rotational speed designs that can directly turn the propeller.
Remember the real purpose of that fan turning out front is to
cool the pilot, because when it quits doing that he (she) starts to
perspire almost immediately.
Duane Rueb
Message-----
[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of wingsdown
Sent: Monday, April 03, 2006 8:40 AM
To: Kitfox
Subject: power to weight
Rick
skyflyte(at)comcast.net Guest
Posted: Mon Apr 03, 2006 1:10 pm Post subject: power to weight |
All good points! One more is that the bigger, heavier, more powerful engine will suck more gas, requiring bigger fuel tanks for the same kind of range performance. Light weight, low drag aircraft perform the best.
-------------- Original message --------------
Rick
-- Kitfox-List message posted by: "Rueb, Duane" <RUEBD(at)SKYMAIL.CSUS.EDU>
Rick
&g
t; payload, or useful load. A more powerful engine will also need a
rjdaugh(at)rapidnet.com Guest
Posted: Mon Apr 03, 2006 2:14 pm Post subject: power to weight |
Duane,
I agree with almost all you said and you said it better than I could, but
there is one statement that I feel is wrong:
"This
rotational speed designs that can directly turn the propeller."
I suspect that other 912S drivers may disagree too. There is a point where
that large displacement comes at weight cost. You are better off getting
more horsepower out of the engine using RPM. Compare an O-200 and the 912S.
Randy
lcfitt(at)sbcglobal.net Guest
Posted: Mon Apr 03, 2006 3:15 pm Post subject: power to weight |
While we are on the subject of weight and power, it should be remembered
that our designs are configured around the typical weights of the Rotax
series engines. The heavier engines will most certainly bring on W&B issues
and in many cases larger heavier batteries or other essential equipment or
even dead weight lead is used to bring the W&B into limits, further adding
to the weight penalty.
This is, I believe, one of the reasons an engine reported to be just a few
pounds heavier than the 912, for example, will result in an airplane
significantly heavier than expected, given the engine weight differential.
Lowell
Posted: Mon Apr 03, 2006 3:29 pm Post subject: power to weight |
Excellent points on the auxiliary equipment needed for a particular
engine. That would be an interesting line as well. I think it will be
awhile before any manufacturer experimental or otherwise will publish
that real number. Kind of like performance figures. So the total weight
of the engine and support equipment required to run it should also be
weighed. To really understand an engines value to the airframe one must
consider all the weight, even extra fuel for equivalent range as
mentioned earlier. Then, if aircraft A is equal to B, essentially the
same aircraft, how much HP does it take to move a pound of additional
engine weight?
Rick
Posted: Mon Apr 03, 2006 6:57 pm Post subject: power to weight |
This has been one of the reversals for turboprops
lately. They are much lighter than piston engines for
the HP, but burn so much more fuel that there is some
movement to convert turboprop airplanes back to
pistons. The decision has to include TBO costs, fuel
costs, normal loads carried, and length of a normal
flight for the plane.
I think the same goes for our engine choices. Weight
isn't the only factor. Initial engine cost, TBO,
reliability, parts costs, etc cause us to chose
different engines that fit our particular missions.
There is a 100 HO turboprop available for us that
weighs around 100 lbs, but it burns 11 gal/hr at idle!
I am sure that is why many have chosen the "heavy"
rotax 912's over the turboprop. Right???
Kurt S.
--- skyflyte(at)comcast.net wrote:
| Quote: | All good points! One more is that the bigger,
perform the best.
avidsid(at)yahoo.com Guest
Posted: Mon Apr 03, 2006 7:21 pm Post subject: power to weight |
Kurt,
where is the link to the 100hp turbo..........?
Sid
-------------- just curious
Kurt S.
perform the best.
"Why can't we all just get along?"
markL
Posted: Tue Apr 04, 2006 1:34 pm Post subject: Re: power to weight |
The company at Osh promoting lightweight turbine engines was Innodyn WWW.inndodyn.com And I dont believe they burn 11gph at idle, their website says the following:
How much fuel do the Turbines burn?
On development turbines our fuel flow, tested by measuring the amount of fuel used in the tanks, was comparable to, but slightly higher than internal combustion engines. Measured in all phases of operation with the RV4 and SuperCub, we found in general, our fuel usage to be approximately 7 gallons per 100 hp per hour. This is internal historical data and has not been independently tested or verified. We continue our efforts to gather additional fuel usage data from independent testing and evaluation. Until we have completed this detailed testing on our first full production engines, we cannot provide precise fuel flow rates. We will be conducting detailed integrated testing on fuel flow and associated hp ratings in the near future. Please check back frequently as we will make this further defined information available as soon as testing is completed.
Definitely seems like the future of experimental will be turbine. Especially since they can burn Diesel, Bio-Diesel, Jet A or kerosene.
markL
Posted: Tue Apr 04, 2006 1:40 pm Post subject: Re: power to weight |
ooops typed in the web address wrong its:
http://www.innodyn.com/
Mark
Posted: Tue Apr 04, 2006 7:40 pm Post subject: power to weight |
The company I talked to used the Solar T-62 engine.
Garrett also makes a small one. If you Google the
Solar T-62, you will find a lot of talk about it.
The company I spoke to said theirs burned from 11-17
GPH for up to 100 hp. Not what I wanted witht he
short range it had. I think they gave up too much to
save weight.
The engine is capable of up to 150 hp and weighs less
than 60 lbs without a GB, but the GB's applied can add
up to 100 lbs more though, depending on who is
building what.
I think the BD-5 used a T-62 as a pure jet.
Here are a couple of sites that talk about
applications for small turbos as examples:
http://www.zenithair.com/misc/turbine-power.html
http://www.auctionaz.com/092305aircraft1947.htm
Rotaway is also testing a 150 hp turbine, last I
heard.
Kurt S. S-5
--- markL <mloos(at)pilbal.com> wrote:
| Quote: | The company at Osh promoting lightweight turbine
the following:........
wingnut
