me(at)parkerthomas.com Guest
Posted: Sun Apr 02, 2006 11:25 pm Post subject: Prop Bolt Torque |
Hi -
Does anyone know what the torque should be on prop bolts for a composite
Aymar Demuth (I'm sure I spelled that wrong) prop? Also for the bolts
holding the 4 inch prop extension to the crank.
Many thanks,
Parker
____________________________________
F. Parker Thomas
ShredFirst
phone 510-433-0200
fax 510-217-5976
parker(at)shredfirst.biz
www.shredfirst.biz
ronlee(at)pcisys.net Guest
Posted: Mon Apr 03, 2006 7:28 am Post subject: Prop Bolt Torque |
| Quote: | Does anyone know what the torque should be on prop bolts for a composite
I am using 26 ft-lbs for the prop bolts on my Aymar Demuth prop. I do not
know if it is solid wood or wood/fiberglass.
Ron Lee
DOUGPFLYRV(at)aol.com Guest
Posted: Mon Apr 03, 2006 7:51 am Post subject: Prop Bolt Torque |
Ron, I think it is all wood. I called them to get torque but do not remember
it now. U can probably find them on internet.
R U going to SnF? We will be there Wed. - Sat.
Doug
C-205-873-2955
Posted: Mon Apr 03, 2006 3:02 pm Post subject: Prop Bolt Torque |
Where did you get the recommendation for 26 ft-lbs? When my Aymar/Demuth
prop was new, it came packaged with a recommended torque of 18 ft-lbs. I
used permanant marker to write that figure in a visible location on the
spinner backplate, so I never forget...
KB
