Vetterman Exhaust Hangars
Tim Popp
PostPosted: Sun Sep 06, 2009 6:43 pm    Post subject: Vetterman Exhaust Hangars Reply with quote
Does any one have some photos of how the Vetterman exhaust hangars fit on a RV-7 IO-360 standard 4-pipe installation? The instructions seem to indicate that you can either attach the hangars to the rear of the sump or to the engine mount. It sounds like you're supposed to keep the clamps on the exhaust as far aft as possible. If you do that, it doesn't apper that the hangar rods are long enough if you want to hook them to the sump? What have othesr done here?
Thanks for any help.
RV-7 963P FWF
____________________________________________________________
Online Fashon Degrees
Start earning an online fashion degree from the Art Institutes
bobbyhester(at)newwavecom
PostPosted: Sun Sep 06, 2009 7:20 pm    Post subject: Vetterman Exhaust Hangars Reply with quote
Do not attach them to the engine mount. They need to be attached to the engine, the exhaust has to move with the engine, I don't have pictures available but I'm sure someone does.
Surfing the web from Hopkinsville, KY
Check out the latest on my website at:
http://home.newwavecomm.net/bobbyhester/2009AugDecFlying.htm
c172.58(at)juno.com (c172.58(at)juno.com) wrote: [quote]
RV-7  963P  FWF
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Site Admin
PostPosted: Mon Sep 07, 2009 8:42 am    Post subject: Vetterman Exhaust Hangars Reply with quote
I have the 4-into-4 Vetterman exhaust on my RV-8. The instructions stated to mount the hangers to the engine mount. Here are some pictures of my installation. There might be more options on the RV-7, don't know.
RV-8 #82880 N998RV
http://www.mykitlog.com/dralle
>RV-7 963P FWF
 Filesize:  176.92 KB
 Viewed:  6670 Time(s)
 Filesize:  197.69 KB
 Filesize:  156.75 KB
 Filesize:  146.1 KB
Site Admin
PostPosted: Tue Sep 08, 2009 8:05 am    Post subject: Vetterman Exhaust Hangars Reply with quote
Let us know what Larry has to say. Maybe post some pictures when you've figured it out...
RV-8 #8288- N998RV
Finishing Up The Cowling...
At 06:19 AM 9/8/2009 Tuesday, you wrote:
Thanks Matt. Beautiful installation. The mount on the 7 is quite a bit different than the 8 by the looks of things but the concept of the hangars is the same. I'm going to give Larry a call today to see what he recommends. I'm probably just missing something but I'm also concerned that the hangar is going to interfer with the location of the scat tube for the heat muff. I didn't see where you had your heat muff installed yet. On my setup, the instructions say to put it over tubes 1&3 (it's a double heat muff) as far aft next to the hangar bracket as you can. Since it's a double muff, you can't rotate it on the pipe, and the heat outlet would be right under one of the hangar rods. I'm sure Larry has an answer - I can't be the first.
Thanks again.
Tim Popp
RV-7 N963P
<mailto:C172.58(at)JUNO.COM>C172.58(at)JUNO.COM
Time: 09:42:03 AM PST US
From: Matt Dralle <<http://webmaila.juno.com/webmail/new/8?folder=Inbox&msgNum=00000PW0:001AdWJ_00000Xg^&block=1&msgNature=all&msgStatus=all&count=1252414493&content=central#>dralle(at)matronics.com>
Subject: Re: Vetterman Exhaust Hangars
RV-8 #82880 N998RV
<http://www.mykitlog.com/dralle>http://www.mykitlog.com/dralle
