bacstabber(at)cox.net Guest
Posted: Sun Apr 02, 2006 6:26 am Post subject: Ways to remove stipped AN-365 |
I have two stripped AN-365 nuts on my tie down because I over torqued them with my new torque wrench. Now I have the two nuts that I can't loosen or tighten. On the CDI wrench, I expected a loud "Click" sound but only got a bending of the handle at the head. First question...is this normal for click torque wrenches in general or is this just how the CDI works?
My noviced belief is that these nuts need to be replaced but do they really? They seem to be secure and don't want to come off anyway. If they do need to be replaced, I need some advise on how to remove these nuts.
Thank you for your help...
Jack
wgill10(at)comcast.net Guest
Posted: Sun Apr 02, 2006 6:43 am Post subject: Ways to remove stipped AN-365 |
Hello Jack,
Replace the stripped hardware. If able, use a small cut-off wheel in a
dremel or die grinder.
Bill
khorton01(at)rogers.com Guest
Posted: Sun Apr 02, 2006 7:46 am Post subject: Ways to remove stipped AN-365 |
On 2 Apr 2006, at 10:25, Jack Clark wrote:
Jack,
The bolts were also over torqued, and there is no way to know how
strong they are now. If the tie down fails during a wind storm, your
aircraft could be significantly damaged. Replace the bolts and nuts.
I have no experience on removing stripped nuts, so I can't offer any
good ideas there.
Kevin Horton RV-8 (finishing kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
rlundin46(at)yahoo.com Guest
Posted: Sun Apr 02, 2006 8:48 am Post subject: Ways to remove stipped AN-365 |
I don't know how much room you have to work with, but
you could try a nut cracker. Very inexpensive tool
that screws a wedge against the nut and brakes it on
one side.
Good luck,
Rick
--- Jack Clark <bacstabber(at)cox.net> wrote:
the CDI works?
these nuts.
Jack
browse
Subscriptions page,
FAQ,
Admin.
seipel(at)seznam.cz Guest
Posted: Sun Apr 02, 2006 8:49 am Post subject: Ways to remove stipped AN-365 |
I'd replace the nuts and bolts. Your torque wrench did exactly what
mine does, and I expect that's normal. The click over of the head is
very subtle and you have to be paying attention or you'll miss it.
PJ
Jack Clark wrote:
Jack
webmaster(at)flion.com Guest
Posted: Sun Apr 02, 2006 11:08 am Post subject: Ways to remove stipped AN-365 |
Seconding what Kevin said (since I didn't get the original post - that seems
to happen a lot; probably getting stripped by my ISP's spam filter), you
have actually stretched the bolt and weakened it, so it needs replacing as
well as the nut. As such, you don't have to be gentle with the bolt. A
nut-splitter will work, or careful work with a cutoff wheel (don't go
through the washer under the nut and into the structure). You may find that
the nut will still 'grab' the non-stripped threads behind it, allowing you
to simply un-bolt it, so I'd try that first if you already haven't. And,
yes, that is normal for click wrenches; I find that feel is a better
indicator than sound. No one told me how they worked and I was expecting
them to ratchet freely past torque; I just about twisted the bolt apart.
Patrick Kelley - RV-6a - cabin details ongoing...
rice737(at)msn.com Guest
Posted: Sun Apr 02, 2006 1:28 pm Post subject: Ways to remove stipped AN-365 |
Use vice grips to get the nut off if there is room and replace nuts and
bolts.
Paul
RV8 Finish kit,
Buying avionics at Sun and Fun
Posted: Sun Apr 02, 2006 3:50 pm Post subject: Ways to remove stipped AN-365 |
Jack Clark wrote:
Jack
Can you get a large pair of 'dykes' (diagonal cutters) to the
intersection between the nut & washer? If so, you should be able to
squeeze & apply force outward on the nut while turning the nut. Use your
3rd hand to hold the head of the bolt. Goal is to get the nut to
bite on good threads & start unscrewing.
If that fails you might try cutting the bolt even with the nut & then
drill the bolt like drilling out a rivet, but with a slightly larger bit
instead of smaller. The washer will buy you a small safety margin to
keep the bit away from the structure.
Torque wrench issues: If you've never used a torque wrench before, you
will be shocked at the small amount of force needed to torque nuts under
3/8" dia. I'll bet the wrench clicked before you even thought you had
snugged the nut.
Posted: Mon Apr 03, 2006 7:30 am Post subject: Ways to remove stipped AN-365 |
Thanks to everyone that has helped me with their reply. I decided to use the Dremel to cut the nut. I left a small amount of nut in place to help avoid damaging the spar during cutting. The remaining nut was easily separated from the bolt.
Now in my next adventure in plane building, I will learn about replacement hardware purchasing...
HCRV6(at)comcast.net Guest
Posted: Mon Apr 03, 2006 5:20 pm Post subject: Ways to remove stipped AN-365 |
Jack:
It would also be a good idea to check the calibration on your torque wrench. The first one I bought when I was starting my RV-6 turned out to be over 100% in error in the 20 to 25 inch pound range for AN-3's (25 in lbs setting was actually 60 in lbs). Suffice to say that that one went back to seller accompanied by a very nasty letter. BTW, the seller was NOT Avery or Cleveland.
Harry Crosby
RV-6 N16CX, 195 hours
-------------- Original message ----------------------
the bolt.
