		gmosh(at)charter.net Guest
				 Posted: Mon Aug 31, 2009 5:34 pm    Post subject: low suction mystery |
				To all Commander aficionados,
  Having an issue with low suction specifically when running  the left engine alone.  The right engine system is operating normally  without the left engine running producing about 4.2 Hg of suction.  The  left engine alone will only produce 2.2 to 2.3 Hg max even at  higher RPM settings.
  I have a straight 560 fitted with dual wet suction pumps.    The engine driven vac pumps are piped to bulkhead fittings  on each firewall into the nacelle.  The bulkhead fitting is  connected to the regulator (via hose and clamps).  The  regulator is "T"'d  for attaching the low vacuum  switch and check valve, thence to the hardline forward to the  instrument panel.  Ostensibly the dual check valves protect the operating  vacuum source from an open leak on the opposite side
  When I rebuilt the instrument panel I relocated the engine gages,  centering them over/above the throttle pedestal to allow for a panel  mounted radio stack AND I added an artificial horizon, DG (airspeed and  altimeter) to the co-pilot side.
  Harry Merrit sent me a used vacuum pump and regulator; both of  which I installed today.  Best I can get off the left side vacuum pump is  2.2 HG of suction.  The regulator adjustments so far have had a  negligible effect on the suction pressure.  I had thought up until today  the problem resided with the (engine driven) pump and/or regulator ahead of the  check valve in the left nacelle but the pump and regulator still won't get me  the required suction off the left side.
  Anyone out there with a theory as to what I should be looking  for?
  Gary (c.s "Blaster")
  |  | - The Matronics Commander-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?Commander-List |
		yourtcfg(at)aol.com Guest
				 Posted: Mon Aug 31, 2009 8:39 pm    Post subject: low suction mystery |
				Sounds like a bad "used" pump??  Need a greaaaaat pair of props for your 560??  jb
		moe-rosspistons(at)hotmai Guest
				 Posted: Tue Sep 01, 2009 7:08 am    Post subject: low suction mystery |
				Gary,
  Have you tested the pump alone by  connecting a hose directly to the pump with the remainder of the system not in  the loop?
  Moe
  N680RR
  680Fp
  Sent: Monday, August 31, 2009 6:26 PM
  To: Commander Chat (commander-list(at)matronics.com)
  Subject: low suction mystery
 href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
		scottmain
  Joined: 14 Nov 2007 Posts: 29 Location: fort lauderdale, florida
				 Posted: Mon Sep 07, 2009 4:39 am    Post subject: low suction mystery |
				I had similar experience with my L-26. I  isolated each segment of the  plumbing and tested one by one and eventually found the culprit. the hard line  from the inside upper left of the right engine nacelle that goes through the  bulkhead and connects to another hard line just to the right of the oil cover  had chaffed through and had a fairly large hole allowing ambient air to enter  there. I had to take the inspection covers off that area on the wing upper panel  to repair the hole and then all worked fine. a vacuum cleaner connected to the  hose at the pump made enough of a suction noise at the hole  to find the  problem. Probably been that way for years as the pressure controller was cranked  all the way in in an attempt to compensate for the bleed problem.
  hope that helps
  scott
   In a message dated 9/1/2009 11:09:10 A.M. Eastern Daylight Time,  moe-rosspistons(at)hotmail.com writes:
   	  | Quote: | 	 		     Gary,
    Moe
    N680RR
    680Fp
 t href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
 ms.matronics.com/">http://forums.matronics.com
 tp://www.matronics.com/contribution">http://www.matronics.com/contribution
				 Posted: Tue Sep 08, 2009 4:11 am    Post subject: low suction mystery |
				It appears the replacement pump I  received was weak as well.  I'm going to try another pump and report the  results.
  [quote]   ---
