tfisher(at)commandergroup Guest
Posted: Sat Aug 29, 2009 9:32 am Post subject: Simulated single-engine settings |
Folks,
I'm going to do some single-engine work but I am not sure what the numbers should be for MAP & RPM that I should use to simulate a feathered engine environement.
Tom
C-GISS
680FLP (Mr.RPM)
| | - The Matronics Commander-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Commander-List |
nico(at)cybersuperstore.c Guest
Posted: Sat Aug 29, 2009 11:33 am Post subject: Simulated single-engine settings |
I remember 17" and 2300 on a direct drive engine. Could be wrong. I don't know if those settings will keep a geared motor out of trouble, though.
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of Tom Fisher
Sent: Saturday, August 29, 2009 10:33 AM
Subject: Simulated single-engine settings
Folks,
Tom
C-GISS
680FLP (Mr.RPM)
href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
John Vormbaum
Joined: 21 Aug 2006 Posts: 273 Location: SF Bay Area, CA
Posted: Sat Aug 29, 2009 11:56 am Post subject: Simulated single-engine settings |
I thought I used around 13" and 2300 or so on my 500B direct-drive engines. I don't know if those settings will yield zero-thrust on an IO-720 though...
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of nico css
Sent: Saturday, August 29, 2009 12:31 PM
Subject: RE: Simulated single-engine settings
Folks,
Tom
C-GISS
680FLP (Mr.RPM)
white_rhino_ps(at)yahoo.c Guest
Posted: Sat Aug 29, 2009 12:11 pm Post subject: Simulated single-engine settings |
I use 18" and 2600 rpm on my IGO 540'sCraig
Sent via BlackBerry by AT&T
Date: Sat, 29 Aug 2009 12:31:01 -0700
To: <commander-list(at)matronics.com>
Subject: RE: Commander-List: Simulated single-engine settings
I remember 17" and 2300 on a direct drive = engine. Could be=20 wrong. I don't know if those settings will keep a geared motor out of = trouble,=20 though.
From: = owner-commander-list-server(at)matronics.com=20 [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of =Tom=20 Fisher
To:=20 commander-list(at)matronics.com
Subject: Commander-List: = Simulated=20 single-engine settings
Folks,
I'm going to do some single-engine work but I am = not sure=20 what the numbers should be for MAP & RPM that I should use to = simulate=20 a feathered engine environement.
Tom
C-GISS
680FLP (Mr.RPM)
| Quote: | | href=3D"http://www.matronics.com/Navigator?Commander-List">http://www.mat= ronics.com/Navigator?Commander-List href=3D"http://forums.matronics.com">http://forums.matronics.com href=3D"http://www.matronics.com/contribution">http://www.matronics.com/c= _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - The Commander-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D --> http://www.matronics.com/Navigator?Commander-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D - List Contribution Web Site - _-=3D Thank you for your generous support! _-=3D -Matt Dralle, List Admin. _-=3D --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
aquadiver99(at)yahoo.com Guest
Posted: Sat Aug 29, 2009 4:30 pm Post subject: Simulated single-engine settings |
I use 22" and 2300 rpm thereabouts
Donnie Rose
205/492-8444
Sent: Saturday, August 29, 2009 2:47:20 PM
Folks,
Tom
C-GISS
680FLP (Mr.RPM)
href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-Listhref="http://forums.matronics.com">http://forums.matronics.com
| http://www.matronics.com/N======================== forums.matronics.com/" rel=nofollow target=_blank>http://forums.matroni--> [/quote]
start: 0000-00-00 end: 0000-00-00 [quote][b]
cschuerm(at)cox.net Guest
Posted: Sat Aug 29, 2009 5:32 pm Post subject: Simulated single-engine settings |
Donnie Rose wrote:
| Quote: | I use 22" and 2300 rpm thereabouts
For simulated zero thrust?!? That's a LOT more than zero thrust on most
direct drive engines.
Chris
BobsV35B(at)aol.com Guest
Posted: Sat Aug 29, 2009 6:15 pm Post subject: Simulated single-engine settings |
Good Evening Chris and All,
I agree with Chris in that 22' and 2300 sounds way high to me.
However, I do not think there is a canned number that can be used.
Too many variables.
What I would suggest is that you set the RPM at a low number that feels smooth. Somewhere between 2000 and 2300 RPM. Then, throttle back until the RPM drops out of the governing range. Follow that by adding enough MP to make the RPM get back up to the governing range. Choose a MP that is about an inch below what it took to get to the governing range. That will be close enough to zero thrust for the particular weight, configuration, and speed at which the airplane is flying.
Still just a WAG, but close enough for anyone's purpose.
There ARE valid reasons to use a higher power for a few training purposes just as there are valid reasons to use a lower power. Once again, too many variables to discuss in this forum, but the method described previously will get awfully close to whatever performance would be available with the propellor actually feathered.
If someone tells you that you must use such and such a number, all they are telling you is that they do NOT know what they are talking about!! <G>
Happy Skies,
Old Bob
AKA
Bob Siegfried
Stearman N3977A
Brookeridge Air Park,
Downers Grove, Illinois
In a message dated 8/29/2009 8:33:11 P.M. Central Daylight Time, cschuerm(at)cox.net writes:
| Quote: | --> Commander-List message posted by: Chris <cschuerm(at)cox.net>
direct drive ===============================================
_-= Use the ties Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Posted: Sat Aug 29, 2009 7:09 pm Post subject: Simulated single-engine settings |
Thanks Bob, that was a flurry of answers, I like your method.
Tom
C-GISS
680FLP (Mr.RPM)
Posted: Mon Aug 31, 2009 7:51 am Post subject: Simulated single-engine settings |
BobsV35B(at)aol.com wrote:
| Quote: | Choose a MP that is about an inch below what it took to get to the
governing range.
I've used that technique as well Bob. I've compared carefully measured
performance with one actually feathered (which I do occasionally for
practice) to your method and the numbers are certainly close enough to
provide valid simulation.
For my two cents, I think some practice with one engine at idle (more
drag then actually feathered) is valuable too. Dragging one around in
that configuration for a while makes the real thing feel a lot easier.
I also do occasionally make landings (under safe conditions of course)
with one actually feathered. Landings ARE different with an actual
feathered engine versus simulated zero thrust.
chris
Posted: Mon Aug 31, 2009 9:51 am Post subject: Simulated single-engine settings |
Me Too Chris!
That's why I said higher and lower powers are often handy for training purposes.<G>
As Always, It All Depends!
Happy Skies,
Old Bob
In a message dated 8/31/2009 10:52:24 A.M. Central Daylight Time, cschuerm(at)cox.net writes:
governing range.
feathered engine versus simulated zero ================================================[b]
