BuckWynd
Posted: Sun Aug 23, 2009 11:21 pm Post subject: Z-12 Master switch question |
I was studying various Z diagrams over the last several weeks and noticed that the Z-12 diagram has a single DPDT switch to control the main electrical system. It has a single switch instead of a split-type master switch like you see in Cessnas. With no Alternator Field switch, are there times with a Z-12 system when one might wish for a split switch, or two seperate switches? How is this system different from the electrical systems on most factory-built aircraft that separate the functions?
Thanks in advance for educating me.
Buck
_________________ Buck Wyndham
RV-8 N18XL (working on fuselage & systems)
Northern Illinois |
Posted: Mon Aug 24, 2009 5:47 am Post subject: Z-12 Master switch question |
At 02:21 AM 8/24/2009, you wrote:
The S700-2-10 switch (B&C p/n) shown in the
Z-figures is a progressive transfer switch
that emulates the split rocker used on many
type certificated single-engine airplanes.
See chapter on switches in the 'Connection
Alternatively, one may consider a simple double
pole, double throw switch to bring battery and
field on together. In this case, pulling the
breaker (required for crowbar ov protection
system) disables the alternator field path
when the DC power switch is on for extended
periods of time with the engine not
running.
( -Thomas Paine 1776- )
