sgyak18t(at)bigpond.com Guest
Posted: Wed Aug 12, 2009 2:43 pm Post subject: M14PEngines-List Digest: 3 Msgs - 08/11/09 |
I notice there is a typographical error below, where it says
" hot less than 1 kgf/cm". This is just a typographical error, it is
actually NOT less than 1 kgf/cm. The units are kilograms force/centimetre
squared.
Another significant piece of information is that the oil temperature
readings, are all done on the inlet to the engine rather than the outlet.
Good luck
SG
Stewart Graham sgyak18t(at)bigpond.com
________________________________ Message 3
_____________________________________
Time: 09:50:36 PM PST US
Subject: Re: Re: M14PEngines-List Digest: 0 Msgs -
08/10/09
From: Jeff Micheal <westcoastkitplanes(at)gmail.com>
Here's a bit of info I have, hope it helps:
Main line oil pressure (measured through special connection on oil pump):
Operating ratings ................................
.................................... 4 to 6 kgf/cm
Minimum speed of rotation ........................
............................. Hot less than 1 kgf/cm
When gliding at idle rating, oil pressure should not drop below 1 kgf/cm ,
Short-time
(up to 0.5 s) engine inlet oil pressure drop to 0.5 to 1 kgf/cm at near-zero
and
negative accelerations as well as to a pressure of 1.8 kgf/cm for up to 5 s
is allowed in flight. The total
time of engine operation under such conditions shall not exceed 5 min during
service life.
Jeff
On Tue, Aug 11, 2009 at 6:47 PM, Javier Carrasco
<javiercarrascob(at)yahoo.com>wrote:
| Quote: | Hello Guys,
Open Question: any buid knows what are the minimun values for oil pressure
on an m-14p in a conventional gear plane, after landing?
There is nowhere in my manuals that I can find that and the values are
going into the yelow arc.
Thanks.
Checked by AVG - www.avg.com
18:27:00
| | - The Matronics M14PEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?M14PEngines-List |
westcoastkitplanes(at)gma Guest
Posted: Wed Aug 12, 2009 6:26 pm Post subject: M14PEngines-List Digest: 3 Msgs - 08/11/09 |
Posting is directly from M14P Maintenance Manual -- English Version (maybe I should just stick to Russian).
On Wed, Aug 12, 2009 at 3:39 PM, SRGraham <sgyak18t(at)bigpond.com (sgyak18t(at)bigpond.com)> wrote:
[quote]--> M14PEngines-List message posted by: "SRGraham" <sgyak18t(at)bigpond.com (sgyak18t(at)bigpond.com)>
squared.
Good luck
SG
Stewart Graham sgyak18t(at)bigpond.com (sgyak18t(at)bigpond.com)
08/10/09
From: Jeff Micheal <westcoastkitplanes(at)gmail.com (westcoastkitplanes(at)gmail.com)>
Short-time
and
service life.
Jeff
<javiercarrascob(at)yahoo.com (javiercarrascob(at)yahoo.com)>wrote:
> Hello Guys,
> Thanks.
18:27:00
List" target="_blank">http://www.matronics.com/Navigator?M14PEngines-List
http://forums.matronics.com
le, List Admin.
george(at)gesoco.com Guest
Posted: Thu Aug 13, 2009 4:51 am Post subject: M14PEngines-List Digest: 3 Msgs - 08/11/09 |
The complete manuals along with other data are available at motorstarna.com
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
http://coyafct.com/[/url]
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com [mailto:owner-m14pengines-list-server(at)matronics.com] On Behalf Of Jeff Micheal
Sent: Wednesday, August 12, 2009 10:26 PM
To: m14pengines-list(at)matronics.com
Subject: Re: RE: M14PEngines-List Digest: 3 Msgs - 08/11/09
squared.
Good luck
SG
08/10/09
..................................... 4 to 6 kgf/cm
.............................. Hot less than 1 kgf/cm
Short-time
and
service life.
Jeff
Thanks.
Checked by AVG - [url=http://www.avg.com]www.avg.com
18:27:00
le, List Admin.
href="http://www.matronics.com/Navigator?M14PEngines-List">http://www.matronics.com/Navigator?M14PEngines-List
Posted: Thu Aug 13, 2009 8:57 am Post subject: M14PEngines-List Digest: 3 Msgs - 08/11/09 |
Thanks George.
Cheers.
Jeff
On Thu, Aug 13, 2009 at 5:51 AM, George Coy <george(at)gesoco.com (george(at)gesoco.com)> wrote:
[quote] The complete manuals along with other data are available at motorstarna.com
George Coy
CAS Ltd.
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
SKYPE george.coy
From: owner-m14pengines-list-server(at)matronics.com (owner-m14pengines-list-server(at)matronics.com) [mailto:owner-m14pengines-list-server(at)matronics.com (owner-m14pengines-list-server(at)matronics.com)] On Behalf Of Jeff Micheal
To: m14pengines-list(at)matronics.com (m14pengines-list(at)matronics.com)
squared.
Good luck
SG
08/10/09
Short-time
and
service life.
Jeff
Thanks.
18:27:00
le, List Admin.
