Had A Bad Day with a Perspex Window
avi8ordave(at)YAHOO.COM
PostPosted: Thu Aug 06, 2009 7:25 pm    Post subject: Had A Bad Day with a Perspex Window Reply with quote
--- On Sun, 7/19/09, Karl Heindl <kheindl(at)msn.com> wrote:
Subject: RE: Had A Bad Day with a Perspex Window
Date: Sunday, July 19, 2009, 9:05 PM
#yiv620195600 .hmmessage P { margin:0px;padding:0px;} #yiv620195600 { font-size:10pt;font-family:Verdana;}
Ron, that's a good idea. I had a disaster situation where the open door fried near a 500W
halogen ceiling lamp. I cried, but then I had the bright idea of fitting a ventilator in that location. which was just behind my head . It worked out well as it extracts the incoming air from the Naca scoops.
Karl
Subject: Re: Had A Bad Day with a Perspex Window
Date: Mon, 20 Jul 2009 00:13:47 +0300
--> Europa-List message posted by: "rparigoris" <rparigor(at)suffolk.lib.ny.us>
Hi Richard
I am not sure I understand if your lifting Perplex is on the door or front windscreen, doesn't matter, could you put in an Ultimate ventilator in that area?
http://www.europaowners.org/modules.php?set_albumName=album277&op=modload&name=gallery&file=index&include=view_album.php
If above not feasible, if it is in the corner where if you were to make window smaller and visability would be acceptable, you could cut out lifting corner out and re-establish a rebate with some glass. I would lay up first ply wet out with Redux, then peel ply, after cure use aeropoxy plies.
Good luck
Ron Parigoris
Ron Parigoris
Visit - www.EuropaOwners.org
&g============
blank" href="http://www.matronics.com/Navigator?Europa-List">http://www.m rel="nofollow" target="_blank" href="http://forums.matronics.com">ht -->
