FS450 calibration
kheindl(at)msn.com
PostPosted: Fri Jul 31, 2009 12:46 pm    Post subject: FS450 calibration Reply with quote
I am trying to calibrate the K (fudge) factor for the above fuel flow computer. I have only one transducer and want displays in liters.
My re-computed K-factor is way above the limit of the input field C which is limited to 2 digits.
There is supposed to be a way of using just the one transducer C but how do you do it ?
Perhaps the automatic option ? The guy at JPI tells me that I must have 2 transducers.
Any help appreciated.
Karl
davidjoyce(at)doctors.org
PostPosted: Mon Aug 03, 2009 12:13 am    Post subject: FS450 calibration Reply with quote
Karl, What engine? David Joyce
kheindl(at)msn.com
PostPosted: Mon Aug 03, 2009 4:23 am    Post subject: FS450 calibration Reply with quote
912s. I don't think there is a solution C except that second transponder. I set the K to 99.99 C but flow rate is 27 litres. the automatic option should work C but the crappy software seems to truncate the internally computed k-factor also.
Karl
[quote] From: davidjoyce(at)doctors.org.uk
Subject: Re: FS450 calibration
Date: Mon C 3 Aug 2009 09:10:23 +0100
--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk>
Karl C What engine? David Joyce
rlborger(at)mac.com
PostPosted: Mon Aug 03, 2009 4:47 am    Post subject: FS450 calibration Reply with quote
Karl,
If you are using a return line to the fuel tank (as in my 914) you must use two transducers. There is no way to calibrate a system with a return line using only one transducer.
Bob Borger
N914XL
XS Mono, 914, Airmaster C/S Prop
[quote]---
kheindl(at)msn.com
PostPosted: Mon Aug 03, 2009 5:25 am    Post subject: FS450 calibration Reply with quote
Bob C
that was my original assumption C but i was told that several europa owners managed to get away with one and accurate readings. i have done the wiring for two C but was trying to save the $300+.  it is really a software problem by not allowing the input or calculation of the k-fudge factor above 99.99.
Karl
[quote] Date: Mon C 3 Aug 2009 07:37:05 -0500
Subject: Re: Europa-List: FS450 calibration
--> Europa-List message posted by: Bob Borger <rlborger(at)mac.com>
Karl C
Bob Borger
N914XL
XS Mono C 914 C Airmaster C/S Prop
PostPosted: Mon Aug 03, 2009 12:15 pm    Post subject: FS450 calibration Reply with quote
Karl, I have a 914 with FS450 and 2 transponders. My understanding is that
the flow through the filters, pump/s and pressure valve and return line is
considerably in excess of the normal fuel consumption, and depends on the
efficiency of your pumps how clean the filters are, and the calibre of the
fuel lines. Although the flow to the pressure valve will increase with
greater engine power & fuel consumption, it will not be in strict proportion
as there is considerable flow through the valve and the return pipe when the
engine is not running. In consequence you cannot hope to get a reliable
indication of fuel consumption without measuring fuel flow out & return &
getting the instrument to subtract them. Regards, David Joyce, G-XSDJ
kheindl(at)msn.com
PostPosted: Mon Aug 03, 2009 12:49 pm    Post subject: FS450 calibration Reply with quote
David C
you are right of course C but i have been led to believe that the other solution works okay also and gives accurate readings by changing this k-factor. maybe if i change to gallons C but i have no interest in gallons. i just won't use it for a while.
Karl
Date: Mon C 3 Aug 2009 20:54:06 +0100
Karl C I have a 914 with FS450 and 2 transponders. My understanding is that
the flow through the filters C pump/s and pressure valve and return line is
considerably in excess of the normal fuel consumption C and depends on the
efficiency of your pumps how clean the filters are C and the calibre of the
greater engine power & fuel consumption C it will not be in strict proportion
getting the instrument to subtract them. Regards C David Joyce C G-XSDJ
rholder(at)avnet.co.uk
PostPosted: Mon Aug 03, 2009 2:09 pm    Post subject: FS450 calibration Reply with quote
Karl Heindl wrote:
you are right of course, but i have been led to believe
change to gallons, but i have no interest in gallons. i
There is a solution using one transponder.
Re-arrange things so that the fuel comes out of the
mechanical fuel pump, to a high point from where the
return feed to the tank is taken, then put in the
transponder and then split the line to each of the carbs.
The tank return must be the highest point in the whole
fuel system.
Ergo. One transponder measuring exactly the fuel flow INTO
the carbs.
I know this can be done as it is how the factory built
Sport Cruiser is set up. I have seen under the cowling of
their demonstrator !
I failed to take a photo but I assure you that was how it
was set up. (Don't ask me how I got to see under the hood
on a SC !)
The transponder requirement is 100mm straight line hose
before it and 50mm after it so a total (including the
transponder) of around 225 mm. Easily found !
Richard
G-OWWW no fuel flow !
kheindl(at)msn.com
PostPosted: Mon Aug 03, 2009 4:16 pm    Post subject: FS450 calibration Reply with quote
Thank you for that richard. i'll take a look at it and do what you say C unless there is good reason not to change the fuel lines. I think i called it a transponder as well C but it should be transducer C whatever that is.
Karl
[quote] Date: Mon C 3 Aug 2009 23:07:08 +0100
--> Europa-List message posted by: R Holder <rholder(at)avnet.co.uk>
mechanical fuel pump C to a high point from where the
return feed to the tank is taken C then put in the
fuel system.
the carbs.
on a SC !)
Richard
G-OWW========================>
bberube(at)tampabay.rr.co
PostPosted: Mon Aug 03, 2009 5:11 pm    Post subject: FS450 calibration Reply with quote
Karl,
We have set up several Europas with a single transducer with good results. I am sure it is in the archives but some years back. In fact we are in the midst of doing one now and would be happy to walk you through it if you give me a call.
Bob Berube
Flight Crafters
813 695-1120
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Karl Heindl
Sent: Monday, August 03, 2009 7:52 PM
Subject: RE: FS450 calibration
Thank you for that richard. i'll take a look at it and do what you say, unless there is good reason not to change the fuel lines. I think i called it a transponder as well, but it should be transducer, whatever that is.
Karl
> Date: Mon, 3 Aug 2009 23:07:08 +0100
> From: rholder(at)avnet.co.uk
> To: europa-list(at)matronics.com
> fuel system.
> the carbs.
> on a SC !)
> Richard
Checked by AVG - www.avg.com
08/02/09 05:56:00
